Question about Xerox WorkCentre M20i All-In-One Laser Printer
Broken Glass on a M20i
Can you tell me how to remove both pieces of glass from the M20i? Thanks
    President:
  • 2,072 Answers
1. Oprn the front door, as if to replace the toner and remove the 2 screws above the toner and drum.
2. Turn the machine around. Disconnnect the one connector to the document feeder. A beige molex connector, lift and remove the feeder.
3. Remove the 6 screws from the back cover, remove the cover.
4. Disconnect the white ribbon cable and black connector with red wires attached to the upper part of the main board.
5. Under the scanner body, on the rear of the machine, locate the 3 screws that hold the scanner to the frame. One on the right, on in the middle and one on the left.
6. Grasp the scanner from the sides and pull back to release the scanner tabs from teh frame.
Once the scanner is removed you then have to remove the 3 screws holding the control panel to the scanner, then the 5 screws that hold the frame holding the glass. I am not sure where you can get that glass. But do a google search for "the parts drop". Give them a call, ask for Britt and see if he can come up with one for you.
Posted on Aug 11, 2008
How do I repace the glass on the front of oven door
Click on this to view the diagram.
Put a thick towel on the counter (or table). Remove the door from its hinges and set it on the towel. Be careful not to damage anything, especially glass and door handle. Remove the door handle (#10 screws). Remove the bottom screws that hold #4 outer panel to #9 inner door panel. You can then set the outer panel aside. Collect broken glass pieces if any and install the new glass. Set the outer panel back on, and repeat the other steps in reverse.
That's about it.
Let us know how it goes...
Thanks
Apr 02, 2012 | GE Kitchen Ranges
Tip
Range/Stove/ Oven Door Glass Replacement
I see many questions come up at Fixya.com about oven door glass that has broken and how to replace the glass. For many ovens it is a relatively simple task. It will take about an hour for most people, depending on the skill level, and the type of door.
To do this job you should have handy a screwdriver, usually a Philips head medium sized, a plastic tarp, especially if your glass in the door is already broken, and of course the new glass. It is also a good idea to measure the new piece of glass to make sure that it is close in size before taking the door apart.
For your safety, make sure that the power is turned off to the oven before starting this job also. The open the oven door and remove the screws on the inside face of the door. If the door can be remove easily you can remove it, but it is not necessary to do that. Make sure that you place the pieces of the door as they come off and the screws in a place to keep them organized for when you put everything back together.
For most ovens you will find the oven glass held in by tabs, similar to a picture frame. Pull the tabs back to release the glass. Carefully remove the old glass from the frame. If it is broken, be very careful not to cut yourself. Also contain the glass on the trap to make cleanup easier. For many newer ovens, you will have three layers of glass. Do the same process for each layer.
When the old glass is removed, then simply replace each layer of glass and press the tabs back in place for each one. Then replace the brackets or inside pieces of the door, and secure with the screws.
This is how easy it is to replace the glass for many of the ovens.
Another word about broken glass in ovens…..
Many of the people that have broken glass state that it broke after running the self-clean feature of their oven. For many of you this warning will be too late…but for those of you that see this before, be warned!
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Mar 22, 2010 | Ovens
Need to release the glass to clean it
There should be screws holding the plastic bezels sealing the glass. Remove the screws and peel up bezel...This should release the glass.
Oct 25, 2010 | Xerox WorkCentre M20i All-In-One Laser...
How do I get the platen glass off of my M20i? Either it is stuck or I'm doing something wrong. I need to clean the under side of the glass. Can anybody help?
1. Remove the Document Feeder
2. Remove the Doc Scanner
3. Find the hooks on the Doc Scanner to the right and left to separate the glass frame from the plastic scanner housing.
That should give you access. Best of luck.
Whit
Item, Inc.
Aug 20, 2010 | Xerox M20I Grayscale Copier
How do I clean document feeder? It is putting
If it is just puting lines on the copies ONLY when using the feeder here is all you need to do to clean that thoroughly.
Get a phillips screw driver. Lift the document feeder, you will see the "seal glass" about 1 inch wide on the left side. Remove the 2 silver screws, One on each end. Lift that glass up and out. Lay it on a white piece of paper. Take some alcohol and a regular piece of copy paper and clean that until you see nothing on that glass by placing it against the white paper. Get every little speck off. Then put the glass back in.
If you want to clean the entire scanner that is a different procedure all together. Let me know .
Feb 10, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Broken scanner glass
You can go thru Xerox possibly but they would probably have you send it in and charge you outrageously.
If you knew how to take apart the scanner I would suggest taking a tape measure and measure the exact size of the glass and then maybe go to a glass place and have them cut one to size for you.
Not sure what the costs would be but if this scanner is one of those where you like it alot and can't do without it then at least this could be an option and you can then put the new glass in and put the scanner back together.
I know this might seem weird but at least its worth a shot and maybe getting a piece of glass is less expensive then sending it in to xerox to get serviced.
Ben
May 20, 2009 | Umax AstraNet E5470 Flatbed Scanner
Zanussi Oven inside glass problem
Hi , i removed the door, and removed two small screws from the bottom of the door,you can the seperate the door into two pieces by slidng them apart,cleaned up the glass,bought a tube of heat resistant silicone and put some around the edges of the door and glass. I then replaced the glass,i left overnight to set and rebuilt the door.
Regards
Eddie
Jan 27, 2009 | Ovens
Xerox workcertre m20i
Most likely not going to find just the glass. Go to google and search for " the parts drop" they will be the first item in your search. Call them and ask for Britt, he will work with you to get what you need at a very fair price.
Oct 15, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Broken glass in top of TR 875 Breadman machine
Hi-
I saw your post and had the same problem. I unscrewed the lid and removed the pieces of glass measured and asked my local glass store to cut me a new circle. I brought them the sample glass (so they knew what kind to use) and they cut 5 1/8" circle that fit perfectly. It was $5. Hope you haven't tossed your yet. Thanks,
Heather
Jun 23, 2008 | Breadman TR875 Bread Maker
Problemas a Imprimir, recuadros y lineas
Sounds like a dirty seal glass. Clean the glass on the left side of the scanner. The 1/2 inch strip of glass.
Feb 12, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
62 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
