Question about NetGear RangeMax WPN824 Wireless Router (WPN824NAR)
Router model #
Im not sure on the model # but it has alot of led lights in the middle of it flashing and ruckus wireless on the side of it. not sure how to get to the page to change the password on it or to unsecure it completely. Nothing on the computer showing netgear but it is transmitting a signal (secured)??? Very confused, netgear wont help b/c had similar problem before and called. They apperantly only help once. Thanks in advance for anymore suggestions.
  • 6,487 Answers
Better to reset the router by pressing the reset button for 30 seconds and then run again the setup CD of the router to reconfigure it back so you will know all the settings on it....
Posted on Nov 05, 2008
Ruckus multimedia vf2825 ip not accepting en my ppc
You mean it won't allow your PC to connect to the wireless network?
See if the troubleshooting tips on page 19 of the manual help:
http://support.alcadis.nl/files/get_file?file=Ruckus/MediaFlex/MF-2111/Manuals/MF2111%20User%20Manual.pdf
Nov 02, 2014 | Ruckus Wireless Ruckus Mediaflex 2825...
WHAT LIGHTS ON LINKSYS ARE SUPPOSED TO BE BLINKING
Note that incoming traffic will cause the WAN (or Internet) light to blink even if it is 'probe' traffic trying to break in to your network. Such traffic is to be expected and is the reason you have firewall functionality in your gateway router.
On the inside, there is a bit of traffic on any LAN when the computers are turned on. Messages generated by the router itself are used to find computers and printers for a lot of different legitimate reasons.
Feb 25, 2013 | Linksys Wireless-G WRT54G Router
How to stop Netgear Ruckus router from interfering with cell phone
Try changing the wireless channel on the Netgear router to a different channel.
Jan 31, 2013 | NetGear Computers & Internet
Have a RUCKUS wireless router. UPC supply my internet wireless broadband, but the router is mine. Just got a new laptop and want to set it up with wireless internet. I forgot the password I used to...
Every router has a reset point/button which can be pressed by finger or ball-pen. Locate this reset. After resetting the router it will accept the the default password.
Aug 30, 2011 | Ruckus Computers & Internet
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
WTF! internet used to work perfectly and now my wireless router is on the fritz and the status light keeps flashing! i have to hook my comp up to the wall to write this message
If the status led light keeps flashing there is a problem on your ISP side. Router is trying to establish connection with internet. Please check led light status on your modem (not router). Also please try to change position of your router as it might be in a "dead spot". For more info about your router please visit: http://www.dlink.com/products/?pid=6
Oct 24, 2010 | D-Link AirPlus Xtreme G DI-624S Wireless...
Linksys WRT160 router doesn't work
Wi-Fi Protected Setup Button
If you have client devices, such as wireless adapters, that
support Wi-Fi Protected Setup, then you can
use Wi-Fi Protected Setup to automatically
configure wireless security for your wireless
network(s).
To use Wi-Fi Protected Setup, run the Setup
Wizard, or refer to the “Wireless > Basic Wireless
Settings” section of “Chapter 3: Advanced
Configuration".
Wi-Fi Protected Setup LED (Blue/Amber) It
lights up blue when wireless security is
enabled. The LED flashes blue for two
minutes during Wi-Fi Protected Setup.
The LED lights up amber if there is an error
during the Wi‑Fi Protected Setup process. Make
sure the client device supports Wi‑Fi Protected
Setup. Wait until the LED is off, and then try again.
The LED flashes amber when a Wi‑Fi Protected
Setup session is active, and a second session
begins. The Router supports one session at a
time. Wait until the LED is off before starting the
next Wi-Fi Protected Setup session.
Jan 01, 2010 | Linksys WRT160N Wireless Router
FN hotkeys Wireless on/off dosent work!!!?????
first configure your wireless router with a ethernet cord on a station pc using the software that router came with ..... it should be a step by step process (self explanatory}once that is done make sure the router is transmitting by trying to log on to a web site
once that is done .......as i will tell all my firends vista isnt for every pc alot of pc or xp based drivers arent compatible on vista , has it ever worked on vista before if yes then try reinstallin the driver for your wirelss card ....good luck
May 06, 2009 | Computers & Internet
I lost my CD
You can reset your Netgear router/wireless MR814 router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless MR814 router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Oct 17, 2007 | NetGear MR814 Wireless Router
Wireless LED blinking, normal?
Same problem here - wireless light starts blinking and I get a network interruption. At that point, I have to walk across the house and downstairs to cycle the power on the router to get it working again. What a pain - and the manual doesn't even mention a blinking status for that light. I'm thinking about hooking the router up to a automated power switch (X12) so I can remotely cycle the power.
Dec 17, 2006 | NetGear RangeMax WPN824 Router
NetGear RangeMax  WPN824 Wireless Router (WPN824NAR) Logo
180 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
