HDMI->DVI cable won't work
I have a 26" Ilo brand TV. For use with my computer the DVI works fine, but when I try to plug in my HDMI cable box or HDMI DVD player to the DVI outlet, the TV is not able to pick up a signal. Is this because it's the wrong type of DVI or something like that? If it helps, the computer is a G4 Powerbook, while the cable box is a Scientific Atlantic Explorer 8300HD and the DVD player is part of a Samsung HT-Q70 home theater system. Thanks for your help. when i hook my dvd player to my tv through the hdmi cable it doesnt pick up a signal and it will play the dvd for a second and then it goes to blu screen and the to the movie and it continues to repeat this cycle. i bought a new hdmi cable thing that was my problem and updated the software on my tv but it still does it what is wrong with my setup?
    Problem Solver:
  • 6 Answers
Are you using a HDMI to DVI cable or are you using a HDMI to DVI adapter? Sometimes, though not on all products you have to go into the menu and select which out put your using for each source and whats going through it. You might need to go into your dvd player menu and tell it not to try to run audio through the cable. That way it's not trying to force a signal through the cable that cant be accepted by the TV. That might possible solve your problem for the DVD player. Let me know if it works
Have a Great day
Posted on Aug 11, 2008
2 Suggested Answers
lukster
  • 217 Answers
SOURCE: HDMI->DVI cable won't work
Get another cable box, the scientific atlanta are notorios for these type of problems
Posted on Apr 16, 2007
No signal HDMI or DVI
Do a firmware update. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 26, 2014 | Initial Televison & Video
I have bought a HDMI cable and I cant seem to get my Prosonic to work with my pc. It works on other TV's The cable works fine with dvd player. Is there somewhere on the TV I shall activate first? I...
How many HDMI Inputs are available on the TV? Also, are you trying to project your computer to the TV or get TV on your PC?
I will assume the first scenario. The only thing I can suggest is that if there are multiple HDMI inputs then you will need to choose the correct one to change it to. If it does not give you that option on the TV input switcher menu then you can try to plug and unplug (while everything is on and attempting to project) the HDMI cable into different inputs on the TV until you find the right one.
Alternatively you can use a VGA/DVI cable depending what is on the back of the TV and that will definately work, but won't be HD.
Hope this helps.
May 13, 2011 | Prosonic Televison & Video
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
LG32LZ55 TV GOING INTO DPM MODE
Hi Ben,
Did you ever resolve? I have the same issue.
Jun 18, 2009 | LG Televison & Video
ILO-26HD Audio & Video
I have a ilo 26 lcd tv with built in hdtv tuner and I have a red line down the center of the screen that started today. t
Feb 06, 2008 | iLO 2600 Television
ILO 26" LCD HDMI TV
I had the same problem at first. Then I went back to fry's and bought a new DVI cable. Make sure you bought the right one.
Nov 25, 2007 | iLO 2600 Television
Ilo 27 inch hdmi/dvi hd tv monitor
Hi, I'm afraid that not only a cable is needed but an analog (vga) to digital (dvi) converter/scaler as well. The iLo LCD Display V27DMBX-U12 can hook up to a PC using the DVI-I connection only. As you said, your computer has the standard 1D15 pin VGA connector. Another possibility is if your video card has a composite video output (normally a color yellow RCA female) or an S-Video output which will both connect direct to your iLo LCD Display V27DMBX-U12. For the RCA connection all you need is an ordinary RCA to RCA shielded wire cable and for the S-Video, an S to S Video cable will work. There is of course the question about the quality or the resolution. Good luck and hope that this be of some help to you. Pls post again how things turn up. Kind regards.
Jul 31, 2007 | iLO V27DMBX Television
Connection to a computer
This TV has an HDMI interface, not DVI. If your source is DVI, you can get an DVI to HDMI adapter. The HDMI carries both video and audio data, so you will need to connect your audio separately.
May 10, 2007 | iLO 3200 32 in. LCD Television
Mar 26, 2007 | iLO 2600 Television
Televison & Video Logo
1,911 people viewed this question
Top Televison & Video Experts
Electro Med Services...
