Question about IBM ThinkPad T40 2373 Notebook
IBM Thinkpad T40 Problem Booting Up
My T40 has been locking up when I move it even the slightest amount. It freezes the video and locks the system so badly that the only option is a hard reset. Typically when I restart the fan comes on but I get no video and the system does not try to access the hard drive.
From what I have read, I am trying to determine if the issue is with the video chip as described in other postings, a memory problem or something else.
Does anyone know the boot up sequence/ requirements for the T40 Thinkpad? Does it have to see the video chip before it will access the hard drive?
  • jeffsupercnb Sep 12, 2008
    I have the same issue - Thinkpad T40 is 4 years old and when I pulled out the the power plug last night - BOOM - black screen and service. The CD rom functions and the fan works - but you get no screen video display - I noticed that the Hard Drive light does not light up either now when I shut down and restart. I took out the hard drive and put i back in. But no success.
  • 3 Answers
I have a T41 doing this, and pressing on the big ATI video chip (under the wireless card, under the touchpad) would change the machine's mood from bad to good (or vice versa). There are sites saying motherboard flex is the problem, and the solder balls of the video chip (GPU) are the weak link. There is a service on ebay the repairs the solder balls of ATI GPUs for $50, which I will be trying out. Or check Youtube for how to reflow the solder yourself with a 1500 watt heater and an infrared thermometer.
Posted on Sep 15, 2008
    Scholar:
  • 39 Answers
Well if you had an issue with the video you would get a distorted image on the IBM boot image or on the BIOS. Try to click ACCESS IBM and navigate through there is no video issues occur the motherboard is fine from there. I have seen Memory distort and lock up computers if its bad so I would recommend you download from google a program called MEMTEST and burn it to a cd and test your Computer memory and make sure it passes. From there on I would most like think you have a hard drive problem because that would cause the locking up and the video problems too. If the computer is 3-6 years old It might be the hard drive and dont get me wrong the video on the motherboard could be going too but without proplery diagnosing each part I cant fully answer it.Hope my answer gets you closer to a solution.
Posted on Aug 11, 2008
SOURCE:
Find out what is causing noise from full steering lock on right and left , from stationery positon
Depends on what the noise sounds like. Some noise can be normal if you are holding the steering wheel at full lock . That is the pressure from the pump pushing hydraulic fluid through the steering box. If it is usually loud at the slightest turn..could be bad steering pump , leaking hose, leaking seal at steering box, even a bad belt.
Feb 12, 2015 | Cars & Trucks
How do i keep my new bosch nexxt 500 series washer from vibrating so bad
It is necessary to ensure absolutely that the machine has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Sep 04, 2011 | Washing Machines
My ibm type 2372 t40 keeps freezing on startup also how do i make the dvd drive into a portable external dvd drive
is your hard drive ticking or making any nois if so replace hard drive, normaly you can't but you can buy one at staple for around 60 buck's,back too freezing if no nois try reprograming probly have a bad virus,plus check internal battery...
Apr 15, 2011 | IBM ThinkPad T40 2373 Notebook
This is the first time i use its new, i don't know why after one hour starting to be buzzing and moving hardly on the ground it seems that it will explode, i tried to switch it fro 40 to 30 but doesn't...
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Good luck,
John C
Mar 15, 2011 | Washing Machines
My dashbord is freeze
Well, if you have too much data on your hard drive it freezes. If your XBOX freezes at the dashboad, it might mean that you do not have enough RAM (Random Access Memory) to run the operating system and read saves. Games such as Oblivion, Prototype, and other games that cache all your saves often cause freezes. If at any point it runs, make sure you have a memory card inserted and move all of your saves form some games onto it. That will increase the amount of storage on your device and probably free up some RAM. If this does not work, go somewhere like best buy and see if they can fix it.
Apr 11, 2010 | Microsoft Xbox 360 Console
Onboard USB 2.0 hard locks system.Reverting to 1.1 mode solves it
AsRock motherboard having trouble even it another thing to happen like Hard Disk Failure but we know our HDD is fine...
Heres what you do, update the BIOS of your motherboard, www.asrock.com.
This time all the settings on your motherboard hardware are working properly. Good luck!
Jul 20, 2009 | Computers & Internet
I recently bought a IBook for $10 at a yard sale. I knew the previous owners and they got rid of the computer because it glitched so bad. They wiped the hard drive so the operating system isnt even on...
gtabblt.gif Identifying lock-ups and freezes gtabblt.gif Close locked-up programs and locate problem software gtabblt.gif Uninstall and re-install the problem software gtabblt.gif Contact the software vendor gtabblt.gif Understanding backwards compatibility issues gtabblt.gif Change the operating system emulation with the Program Compatibility Wizard gtabseps.gif This document pertains to HP Notebook PCs with Windows Vista. Identifying lock-ups and freezes This document will help you to locate and troubleshoot programs that cause your notebook to hang, freeze, or lock-up. Print this document or save it to your hard disk drive to have the reference available after disconnecting from the internet. Symptoms of notebook lock-ups, freezes, and hangs include:
  • Nothing moves or blinks on the computer display.
  • The computer will not respond to the mouse or keyboard.
  • An error message appears and will not go away.
Freezes, crashes, and lock-ups may be caused by programs locking up resources, software conflicts, or older programs being incompatible with newer operating systems. Follow the steps in this document, in order, until the problem is resolved. Close locked-up programs and locate problem software If your notebook locks up or stops responding while using a program, close the stalled program to continue using other programs. Also, while closing the program, take note of which other programs are running at the same time.
  1. Close the program that is "Not responding" and determine if the lock-ups continue.
  2. If the lock-ups no longer occur after the program is closed, go to Uninstall and re-install the problem software .
  3. If the lockups continue, press ctrl + alt + delete to go back to the Task Manager.
  4. Write down all of the programs that are running when the lock-up occurs. The conflict could have originated by another software application that is running at the same time.
  5. Close other programs that are running one at a time (except for Explorer and Systray) and determine if the lockups continue. Once you find the problematic software application, go to Uninstall and re-install the problem software .
Uninstall and re-install the problem software To resolve the problem that is causing the notebook to lock-up, uninstall the suspected software and then re-install it. If your software came with an uninstaller program, use it first; otherwise, follow the steps below to uninstall and re-install the program.
  1. Click Start > Control Panel .
  2. When the Control Panel window opens, select Uninstall a program.
  3. Select the program that is causing the lockups and right-click it. Then select Uninstall . NOTE: Remove all versions of the same program. Sometimes upgrades will not remove old versions of the software before installing the new version. This leaves multiple versions of the same software on your computer.
  4. After removing the problem programs, close the Control Panel.
  5. Restart the computer.
  6. Re-install the program following the vendor's instructions
Jul 09, 2009 | Apple iBook G4 Refurbished Mac Notebook -...
Dell Latitude D620 locks up when moved
Is this when the ac adapter is plugged in?? Or on Battery??
Feb 06, 2009 | Dell Latitude D620 Notebook
IBM ThinkPad T40 Hard Drive Problem
HI IM LOOKING FOR THE DRIVRS FOR MY LABTOP T40 I NEED ALL OF THEM I LOOKED IN TO IBM SUPPORT.COM BUT I CANT FIND IT SO IF ANYONE KNOW WHERER I MAY FIND IT HELP ME OUT THANK YOU
Sep 22, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
1,056 people viewed this question
Top IBM Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
