Question about GE (PSS26MSRSS) Side by Side Refrigerator
Side by side refrigerator
Refrigerator lights up but compressor is not running
  • little monke Dec 22, 2008
    Lights are on in both freezer and frig, but compressor is not running. Have unplugged and plugged back up, but still no good results.
  • jpsmit Dec 25, 2008
    is this something I can do? if so where is it and how do I do it?
  • 481 Answers
It sounds like it is stuck in defrost; if so the defrost timer should be changed. or it could be the thermostat, but i would inspect the defrost timer first. they go bad all the time.
Posted on Aug 12, 2008
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: light is on, fan runs, compressor will not come on
Below bottom grate is a defrost timer. Turn slowly clockwise until you hear compressor start. If this works, replace defrost timer.
Let me know, Thanks, Sea Breeze
Posted on Mar 19, 2009
Lights are on but the refrigerator/freezer compressor and fan not running therefore unit not cooling.
It can be the problem with compressor itself or problem with start up capacitor beside compressor.
Click this link below for more details:---
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
This should help.Thanks.Helpmech.
Oct 31, 2011 | Frigidaire FRS3R5EMB Side by Side...
The refrigerator has quit working. Lights come on and fan appears to be running. Not cooling
Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay. Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If it's iced up really heavy you have an auto defrost problem. Melt the ice with a hairdryer and check the defrost system.
Oct 12, 2010 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator side light is out, but the compressor sounds like it's still running, plus the food is still cold. Interesting, when I turn the control knob to off, the light comes back on, but the compressor...
have never seen a ref of this style with a control board I would say you have some sort of wireing short. if the control is turned off the lights will still stay on, but they also should be on when if running
Apr 23, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
REFRIGERATOR OR FREEZER DOES NOT COOL OR FREEZE . LIGHTS WORK. COMPRESSOR GETS REALLY HOT (MAYBE IT'S SUPPOSED TO) FAN WORKS. WHAT'S NOT WORKING?
replace the ptc overload relay on the compressor,(its running on the start windings and not the run windings and not getting into the full run mode),they just unplug and plug into the compressor side and are relatively inexpensive
Apr 19, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Relay on compressor clicks, but does not run
Hi!!! change the current relay in your compressor easy fix..its located inside the case where the wires go connect to the compressor..good luck..
Jan 04, 2009 | Amana ASD2626HE Stainless Steel Side by...
Side by side not working
Make sure the compressor is running and not just a fan motor.
Unplug the ref for 30 min or so and while you are behind the ref plug it back in, listen for the compressor to start. If you hear a clicking noise and the compressor never starts then replace the relay on the compressor. If the compressor runs and still does not cool then you may have a coolant problem.
Dec 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer / Refrigerator not cooling
When the fans are running the compressor should also be running. If the compressor is hot but not running you have a compressor problem. If the compressor is running check for frost on back wall of the freezer compartment which would indicate a defrost system problem. At five years old have you cleaned the condenser where the heat is transferred to the outside air in the room?
Nov 19, 2008 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool gold side by side
if the fans are working, can you detect if the compressor is also working/running?
the compressor is located at the back side , lower portion. remove the back cover and observe the compressor if it is running.
tnx 4 using fixya,
drcool
Oct 07, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
My refrigerator
is the compressor running?. check the compressor at the back side of the refrigerator.
Feb 21, 2008 | Amana ABB1927DE Bottom Freezer...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
60 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
