Question about Toshiba Satellite A105 Notebook
Video card i would like to know aside from the video card on the motherboard, is there a external video card on it?if ever none can i buy a video card and install it? thanks a lot i appreciate if you have the answer to my problem
    Genius:
  • 2,028 Answers
There is not an external video card on the machine, nor is there any type of card available, just the one on the motherboard. On these models the video card is built into the board. It is replaceable, but requires a fairly good degree of technical knowledge and skill in order to change it. I realize this probably isn't what you want to hear, but there isn't a simple fix to it, sorry. If you have any more questions, feel free to ask.
Posted on Aug 12, 2008
I have a 'mutt pc' (built from random parts) a
http://www.pcmag.com/encyclopedia/term/38515/beep-codes
HOPE THIS CAN HELP YOU.
Apr 17, 2013 | Computers & Internet
My pc just beeps every 2 to 3 sec no vedio
Either your video card is bad or you might have some bad memory. Does the video ever post anything on the screen when you press the power button to start the computer?
It really sounds like a memory problem.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Apr 02, 2012 | Computers & Internet
Part of the screen stays white in my nc150 netbook Looks like it's a left 1/3 of the screen is always white with some thin black and white vertical stripes but the rest of it works fine. I would like...
Paul -
This absolutely could be the ribbon cable connecting your screen to your motherboard. If you know how to check this, it would be worth trying before spending $150+ on an LCD. Any way you look at it, this is definitely a hardware issue. Just hope it's not the motherboard's onboard video card. Here is a modified answer I gave to a question similar to your issue:
If you turn on your laptop and the display is bad, your issue is with either the LCD screen or the motherboard (since the video card is built-in the motherboard). This will be easy to diagnose.
1.) Plug an external monitor (one which you know works) into the VGA port of your laptop.
2.) Turn on the laptop.
3.) Hold down the FN key (lower-left corner of the keyboard) and press the "CRT/LCD" key (it will be located on the number keys or F1-F12. You do this to tell the laptop that it needs to send the video signal to the external monitor instead of its built-in LCD screen.
If the display is good on the external monitor, then the issue is with the laptop's LCD screen (about $200 for the part plus labor to install). If the display is still messed up on the external monitor, then your problem is with the motherboard ($300-$500 for the part plus a lot in labor cost for installation).
Let me know if this helps you!
Sep 30, 2011 | Computers & Internet
One long beep and two short beeps. the red light flash on the motherboard
Good day.
Commonly, 1 long and 2 short beeps refers to a defective display card.
In a case that you have an external video card (separate from your motherboard - not built-in), turn-off the pc then remove the display card. clean the contact points with a pencil eraser, re-install the card then power-on again. If you received the same beep codes, then there is a need to buy a new video card.
In a case where your video is built-in to your board, to hard, but you need to buy a new board or disable the video adapter in your BIOS and install an external display card.
Just let me know if you need some more help.
Good luck.
Tedmac
Sep 28, 2010 | Computers & Internet
I used ga eg45m ds2h, is it necessary to install eternal graphic software, when im using a third party card say ati hd4550. when i play some games it tends to fliker and exit, automatically... pls. help me...
Operating system have built in drivers that can be used when installing external harware line video card. The problem with this is that sometimes new drivers are released for video cards to fix bugs. So, I suggest you install the latest driver of you video card. If you don't have, just google it you can definite get it.
regards,
Jeep Brainy
Aug 10, 2009 | Gigabyte GA-EG45M-DS2H M-Board,...
Graphic card
A graphic card or graphic adapter is always present on all computer.
When the computer does not have an external graphic card, the video adapter is integrated on motherboard.
By studing multimedia you may need to use software like macromedia director, or 3D modelling software that use a lot of video ram.
If your computer has an internal video adapter with at least 64MB of video RAM, then you can try using the current video adapter, if it is less, then better buying an AGP graphic card.
Here is some choice.
Feb 17, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Hp pavilion ze5500 display monitor still doesn't work
IT could be a motherboard problem with the function key that controls the switching of the video infomation between the LCD screen and the external video connector.
It could be the function key circuitry on the motherboard that controls the back lighting levels on the LCD.
Jan 31, 2009 | HP Pavilion dv6000z Notebook
My computer does'nt boot
Check your Cooling Fan. Sounds a LOT like the fan is getting Sluggish and not cooling the Board Properly.
Jan 20, 2009 | ASUS P5LD2 Motherboard
Upgrading graphics card onto gx280 motherboard
You need to find a "PCI Express" video card. Your Motherboard does not have an AGP slot. There are lots of them to choose from. Better to pay more now and get more memory on the video card than to regret the purchase and buy another one. IMHO
Jan 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
How to disable onboard VGA
I believe if you install an AGP card the onboard VGA is supposed to be automatically disabled. Did you buy an AGP card?
Nov 28, 2007 | Foxconn P4M800P7MA-RS2 Motherboard
Toshiba Satellite A105 Notebook Logo
161 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
