Question about IBM ThinkPad T40 2373 Notebook
Keys Don't Work (U I O P & A)
I have open my IBM T40P laptop computer keyboard for cleaning and when I return it back my keys U I O P & A does not work anymore. there could have been some connection that I have mistakenly move or anything else? Can you please help me on this for a solution if there is any ?
Thank you
rod_nuada2000@yahoo.com
  • rod_nuada200 Aug 13, 2008
    Problem is I could not open my computer because of the Password which is with those U I O P & A that does not work when you press it, I tried to open the terminal connected by a clamp/screw on the top of the keyboard and return it back and my doubt is with this and the plug in terminal just under the terminal.
    Genius:
  • 2,028 Answers
These are the keys for the calculator feature. First try holding the fn key and press the nm lck key. if it's a numbers lock glitch this will take care of it. If this doesn't work, then check the connection. Still not working, then try uninstalling the keyboard drivers from the device manager, and reboot. The machine will find the keyboard and reinstall the drivers. If it's still not working, then you may have damaged the keyboard during the cleaning.
Posted on Aug 12, 2008
Unlock the security chip for a ibm t 60 thinkpad
IBM-branded Thinkpad T60 laptops from Lenovo are mobile computing devices that feature a keyboard lock for data security. When the lock is enabled, pressing the keys on the keyboard does not result in input to the computer. The lock hampers attempts by an unauthorized user from gaining access to your computer and your files. Lock your Thinkpad using the Function key. The Function key used in conjunction with other keys on the keyboard expand the laptop's number of available features.
Locate the "Fn" key in the lower left corner of your Thinkpad keyboard. Locate the "F2" key in the upper left area of the keyboard. Press and hold the "Fn" key, then press the "F2" key to toggle the "Lock" feature. Release both keys. Hope this helps.
Jan 14, 2013 | IBM Computers & Internet
The letter Z key is not responding. I don't know how to fix it
Although having a laptop is certainly convenient, the all-in-one peripheral scheme (mouse, keyboard and speakers) can make individual repairs difficult, and a non-working keyboard can ruin the value of the entire package. However, there are some practical steps you can take to fix a laptop keyboard.
1.Diagnose the problem. When you press a key on your laptop keyboard, does it get stuck? Does the computer respond to your inputs? In almost all of these cases, the solution will lie in opening up your notebook's keyboard. However, to prevent extra work, press every key (do this in a word-processing program) and see which keys are affected. If every single key on a keyboard does not respond, you might have a software issue, which may require specialized help.
2.Clean the area around the keys that are not working. A damp lint-free cloth should be used to clean the surface of the affected keys. If you have stuck keys, use a Q-tip to clean under them, but take care not to pry the keys up, as this could result in further damage to your keyboard.
3.Remove the keys that are not working. Do this by grabbing some fingernail clippers and pulling out the hook-like fingernail cleaner extension. Use the small hook to gently pull the key up , which will expose a collapsible plastic hinge (commonly known as a key retainer) as well as a small rubber circular piece. Gently lift both of these pieces out of the keyboard.
4.Wipe the keyboard sensors clean with a dry cloth. The sensors are the little silver foil-like strips you see after your key components have been removed. Be very careful wiping these down--if they are damaged, they are very expensive to replace. Just gently dab it with a dry lint-free cloth to remove any dust/crumbs/particles that are interfering with your keyboard's functionality. Do not moisten the cloth with water or cleaning solution, as this heightens the risk for damage.
5.Reassemble and replace the keys. Simply fit the key retainer as well the little rubber piece together in the way you found them and then firmly press the key cap back in place.
6.Test your keyboard. Open a word-processing program and then press the replaced keys. If they still don't work, try restarting your computer, or activating a system restore point (to ensure that the problem is not software-related). If the keyboard is still not working, then you may want to think about taking the computer to a repair shop or replacing it altogether. (Keyboard repairs are very expensive.)
Thanks.
Aug 25, 2011 | Dell Inspiron E1505 Notebook
"its working external keyboard but
I hope you find it very helpful. Thanks.
Aug 22, 2011 | HP D8597A Keyboard
Cannot access safe mode via F8 Believe keyboard is not set up correctly.After loss of power cannot control windows screen to select diff options for start
Do you have a mouse if you do you can still access different options in windows start using only a mouse..Try to clean the keys of your keyboard by using a dry paint brush to remove dust that can affect the keys to function don't open the keyboard by unscrewing it because keyboard key is really difficult to return again after opening it and do something with the keys. If still the problem isn't solve I will advice you to buy a new keyboard for you to use your computer without a problem..
Jul 04, 2011 | Computers & Internet
Error 0210: stuck key 01
I assume its a laptop. laptops some times get stuck keys, meaning one of the keys has not fully released after it was depressed. I recommend getting some compressed air in a can and give it a good cleaning. there might be something stopping git from popping back up. then give the keys a little work out. just mash the keys a bit. then turn it back on. if you still have an error, then you might want to consider replacing the keyboard. if you don't, it will not harm you pc in anyway...good luck
May 04, 2010 | IBM ThinkPad 390X 2626 Notebook
Some keys do not work on IBM thinkpad R52 laptop after returning from standby
Unistall the drivers for the keyboard, reboot. If they still don't work replace it.
Jun 23, 2008 | IBM ThinkPad R52 Notebook
Keyboard repair
You should call Acer tech support and enquire about a keyboard. I am sure that they will tell you to take the computer to their rep for your area. Normaly they change the keyboard when there is a fault. If the circuit board under the keys is defective or if one of the IC's on the board failed, this would not be servicable at all. The keyboards on these computers were not really designed to be able to be serviced.
Jerry G.
Apr 19, 2008 | Computers & Internet
Ibm think pad keyboard problem
sounds like something is under the keyboard in that area. anything spill down there? you should be able to open the unit, and remove keyboard,and blow it out with compressed air(DO NOT do that while it's still installed in computer)
Feb 17, 2008 | Computers & Internet
Compaq Presario v2405us Laptop keyboard help
yes u can remove keybord cheak loose connectons also FN button did u hitthat to stop keybord from working sumtime sthat doe sit hit fn button and try sum keys u can replce the keybord pretty easy get part on ebay install it yourself im open for chat thx nick helpap in saginaw michigan
Jan 07, 2008 | Compaq Keyboard
IBM ThinkPad T40 2373 Notebook Logo
1,337 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
