Convergence won't show up in menu
RCA 52" R52WH74
ktracy3
  • garyberg Nov 24, 2008
    I recently changed out a fuse .. also changed the convergence board .... Now what?
    What is causing the convergence to leave the setup menu?
    After I replaced everything, it worked for a bit, then back to the way it was.
  • Anonymous Mar 22, 2009
    I have the same problem I can't find the convergence in my menu where are the fuses located?
  • 8,617 Answers
The convergence power supply baord has taken out fuse FL231 thats what causes the convergence option to disappear fromthe menu.
Posted on Aug 11, 2008
I have an RCA 52'' TV, model number R52WH74. I have replaced the FL231 fuse and re-soldered the flyback as well as some other places on the board who needed it. The picture looks fine, the only issue I...
Convergence should be showing on Menu. Hit menu then go to setup you should see it listed their.
Heres How to Enter Service Menu for alinement of
convergence BUT I MUST WARN YOU be very carefull of adjustments in wrong alinement. With TV turned off PRESS and HOLD Both CH- and VOL- release when set comes on Now you should be in Teachician Service Menu there you should be able to Do convergence alinement and set Auto convergence.
Oct 02, 2009 | Televison & Video
Can't figure out to find auto convergence on remote or tv
Go to menu then setup look for convergence if you do not see it listed you have a open fuse FL231 it is located on right side of FBT flyback transfomer there is 3 in a Roll small brown rectrangler looking caps but they are fuses it will be the one in the Middle.
Aug 22, 2009 | RCA R52WH73 Projection Television
I have a RCA R52WH74 52'' Projection and the color on the set is in red,green,and yellow. Tried adjusting, however, does not help. Any clue?
sounds like a convergence issue. IS the picture also pulled in from top and bottom. In customer setup menu do you have the convergence option. I suggest you read "the fl231 fuse problem" in the tips and tricks section of this website
Jun 05, 2009 | RCA Televison & Video
RCA projection tv R52WH74
quick question do you have the convergence option in the customer setup menu. if you do not then goto the tips and tricks section and read the fl231 fuse problem
Apr 23, 2009 | RCA HD52W58 52" TV
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
Rca r52wh74 - no auto convergance
Go to menu then setup look for convergence if it is missing on menu then you have a open FUSE/ FL231, But if you have convergence on menu then go into service mode turnTV off then PRESS and hold at same time ch- and vol- wait for set to come on then release TV should now be in Factory settings.
Feb 20, 2009 | RCA D52W23 52" HDTV CRT TV
Rca r52wh74 . Double picture .
Go to menu then setup look for convergence if you do not see convergence then you have a open FUSE FL231 it will be on right side of FBT flyback transfomer there will be 3 ina roll they are small brown rectranigler looking caps but are FUSES. It will be the one in the middle.
Feb 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA TV
I know this chassis pretty well, When you go to menu then go to setup is convergence listed in menu?If not replace Fuse FL231 it will be next to flyback transfomer there is 3 of them in a roll small brown square looking caps they are FUSES the one in the middle is it.
Dec 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a 52' rca rear projection model #r52wh74
If i am right you have losted convergence go to menu go to setup look and see if menu has convergence on it if not then you have a open fuse next to FBT on Deflection board located FL231 there are 3 of them it will be the one in the middle.they are small square like caps brown
Oct 08, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH74 52 in Blue & red in picture are shadowy Picture concave/convex
try goin to your menu and find settings ,,go to convergence,,if u got it ,,it may fix it,,it realines the colors,,good luck with that
Oct 06, 2008 | Televison & Video
Televison & Video Logo
799 people viewed this question
Top Televison & Video Experts
Electro Med Services...
