Question about Sony GV-D1000 Mini DV VCR
For Info Lithium Battery only
Hi. Great machine, but today when I attempted to rewind a cassette that I had shot, I got the message on the screen, "For infoLITHIUM Battery Only." Once that message is displayed, the machine goes dark.
What's the solution to this one?
Thanks,
Doc
  • yessicag Jan 28, 2009
    Same problem but, my clamshell is plugged into the outlet.
  • shashank_ddk May 01, 2009
    "For Info Lithium Battery only" message appear on lcd screen & switch off vcr when rewind/forward machine frequently, even on play mode often.
    pl solve any one.
I was having the same problem with a sony GV-D1000 which I don't even use a battery with. I use an AC adapter. Someone suggested that the contacts might be dirty, so I unplugged the small connector that plugs into the back of the deck and wiped it hard with my t-shirt. It seems to work fine now. SO try cleaning the contacts (wherever your adapter or battery connects with the deck or camera.)
Posted on Jun 21, 2009
  • 659 Answers
That just states to use a infolithium battery, so if you have a battery that is not a genuine sony battery for the unit this will be displayed at times if your battery indicator shows that there should have been more charge to the unit then charge the battery to full again and try again so the indicator is displaying the battery life correctly.
the InfoLithium is a lithium ion battery which can exchange data such as battery consumption with compatible electronic equipment.
your vcr only operates with the InfoLithium ion batteries, if you have tryed a different battery please get a genuine sony infolithium battery.
so if you charge and it happens again then see if you can find someone to use a voltage meter on the battery to make sure the battery is connecting properly to the unit and that there is no spikes in the batteries power.
Posted on Aug 11, 2008
Why doesn't it recognize the correct battery?
hi,
If your camera do not recognize the original battery, it means some wrong information is stored in its software data, to override this please open the camera take out the small memory backup lithium battery, short the battery contact , after a five minutes connect that battery again.
Mar 02, 2016 | Sony Video Cameras
Reinsert cassette - After inserting a cassette the on screen message reads as follows "reinsert cassette" a further message C:31:23
when ever to get this kind of message just try to fwd the tape mannualy, or just make sure tht when u are rew. the tape dont rewind tht completely....
Jan 04, 2010 | Sony DCR-TRV285E Digital-8 Digital...
I got Divorced 1 yr ago today YEAH !!!!!! I'm now slowley going through all of the things that my Ex left in my house when he ran off to be with his future ex-wife #9 (14 yrs of marraige & not a single...
just take another photo, if it reads 9 then the film is advancing. if it reads 7 then it's going to the cassette. no problem either way.
if the film is advancing, it will either rewind auto or there will be a rewind button or switch with a double arrow.
if the film is going to the cassette it will rewind auto.
Nov 13, 2009 | Minolta Vectis 25 APS Point and Shoot...
Will not rewind
Sony is pretty secretive about the :23 code. It can't be found anywhere. However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Sep 28, 2009 | Video Cameras
MX2, it displays the following: "remove the cassette" or eject. I thought it was a condensation problem but all attempts failed, please help me.
On Canon camcorders, "remove the tape" error is due to no data reading by video head. You may have clogged heads or somewhere along the area. Initially, I would try to insert good clean "video head cleaning tape" and run for about 7 seconds and see if that resolve the symptom. If it persists, it need a help from a technician. Good Luck. For further help, go to www.camerarepairjapan.com James
Feb 26, 2009 | Canon DM-XM2 Mini DV Digital Camcorder
DSC-F707 Digital Camera Problem
I did the same thing. What I found out was that it's very important to charge a lithium battery completely on the first use. You probably took it off the charger too soon. If it's not completely charged on the first use it won't be able to hold any charge.
Sadly, I ended up having to buy another one and try again.
Sorry.
Oct 26, 2008 | Sony Cyber-Shot DSC-F707 Digital Camera
Blinking film on screen.
Sounds like the batteries went dead, and the internal lithium memory battery was already dead, causing it to forget the settings. install fresh batteries, and reset the ISO of youtr film by holding down the ISO button, and pressing the up/down buttons behind the shutter release. That should return it to normal, but you will have the same problem again whenever you are changing the batteries until you replace the lithium cell. To change the lithium cell, remove tha battery pack, and open the metal plate in the camera's battery compartment. The cell is a lithium CR 2016.
If that does not fix it, you may have a broken camera.
-John
Sep 03, 2008 | Minolta Maxxum 7000 35mm SLR Camera
Sony handycam vision ccd-trv47e most buttons not working
receiving error no C:32:10, will not eject casette nor rewind and play the casette on on play.
Please advise of possible outcome to kazimfat@hotmail.com.\
Mar 19, 2008 | Video Cameras
Black screen
If one of these solutions doesnt work you will most likely need to purchase a new calculator.
Batteries:
Make sure to replace the "battery backup" too the little lithium ion battery
Try Adjusting contrast:
Hold down "[2nd]" key press up or down arrow repeatedly to lighten or darken contrast.
First attempt reseting:
Step 1: Remove all the batteries
Step 2: Hold "Clear" key down
Step 3: Still holding "Clear" key reinstall batteries
Step 4: Still holding "Clear" key press "On" key until home screen is displayed.
Second shot reseting:
remove all batteries including lithium ion (backup battery), wait 3 hours and reinstall batteries.
Third Shot reseting:
Step 1: Remove a battery
Step 2: Hold down "DEL" key reinstall battery
Step 3: Possible msg pops up saying "Waiting ... Please install software" IGNORE msg and take out battery again
Step 4: Reinstall battery do not hold down "DEL" key
reseting will cause the handheld to loose all of its stored memory.
Hope that helps!
Jan 12, 2008 | Texas Instruments TI-83 Plus Calculator
Sony GV-D1000 Mini DV VCR Logo
1,371 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
