Question about Toshiba Satellite P305D-S8828 Notebook PC
Screen saver I can't get screen saver to come on when it idles for the set time of 2min dose a wireless mouse have anything to do with it?
  • 43 Answers
A wireless mouse don`t have anything with this. Until you move it or the table moves
Posted on Jul 29, 2009
The screensaver on my acer laptop running windows 7 does not start up when the computer is idle. I've tried setting and resetting it. One time it came of briefly a few minutes after startup when I didn't...
hi janstorz
Right click on your desktop screen>personlize> theres a screen saver tab at the corner right click it choose a screen saver change wait>Apply>ok
note: windows 7 basic os doesnt come with this option
Hope it helps
Sep 03, 2010 | Acer Aspire 5100 Notebook
I installed a wireless mouse and keyboard. Now my screen saver will not come on. What can I do to fix this problem?
Right click on the desk top then hit 'properties' and go to the screen saver tab and reset the screen saver time you want.
Oct 20, 2009 | Gateway FX542X INTEL QUAD CORE 2 1TB...
Screen saver will not come on
It sounds like you have some program running in the background that is preventing your screen saver from showing. This could be a virus scan, or some other program you unknowingly downloaded from the internet....(spyware, etc). Check to make sure nothing is running in background and do a full scan for virus, spyware, etc.
Jun 02, 2009 | Microsoft Windows XP Home Edition
Microsoft 4000 optical mouse
Try this - Go to control panel > mouse > hardware tab > properties > power management tab
Make sure the entry "Allow this device to bring the computer out of standby" is checked.
If you meant that your screen saver doesnt come on because the mouse is plugged in, it could be because the surface on which your mouse is rested is uneven or extremely smooth, causing the mouse to move, or that the mouse sensitivity properties are set very high. When not in use, try placing the mouse on a piece of dark cloth and see if this helps. Or in the steps mentioned above, make sure "Allow this device to bring the computer out of standby" is UNchecked. Note that you cannot use the mouse to get out of screen saver mode in this option. you will have to tap the spacebar..
Let me know how it goes.
Nov 05, 2008 | Microsoft Wireless Optical Notebook Mouse...
While connected on the internet (wireless) if we leave the computer idle for few minutes without touching anything it disconnects, and takes some time before we can reconnect again. The screen saver is not...
It could be a time-out setting that is on the router or a setting inside the computer. It could also be malware that has gotten in and affected certain settings that mess with the internet. Have you noticed any weird things going on with the computer lately?
Sep 07, 2008 | Computers & Internet
Screen Saver no longer runs when Microsoft wireless mouse 3000 is installed.
this is a common problem when using wireless equipment in windows. Especially on Dell notebooks. The PCMService.exe program starts when the computer starts and interaction at some level between this and the Wireless reciever prevents the computer from becoming idle. Therefore, the screen saver and the other idle-related features do not start. this issue may also occur if the PCM and DVDLauncher services are running in the background. This issue also occurs in Windows Vista premium and in Windows Vista Ultimate because of the media center functionality that is built in.
Microsoft reccommends plugging in your wireless device and visiting to get the "optional hardware update" named "Microsoft HID Non-User Input Data Filter." This should fix the problem.
Microsoft also reccommends two possible "workarounds" for this problem if you do not want to install the update or if the update does not work, both are relatively simple:
1- turn off the PCMService.exe program. to do this, first you open the system configuration (start->run->msconfig.exe). on the startup dab of the configuration window, click to clear the PCMService startup item check box. Apply, Close, and if/when prompted, restart your computer.
2- Remove the PowerDVD Software (not advised if you use this software for watching DVD's on your notebook). To do this, open the add or remove programs window (start->run->appwiz.cpl), locate PowerDVD, click change/remove, and follow the steps through for removal of the program.
Jun 30, 2008 | Microsoft Wireless Notebook Optical Mouse...
Background Problem
Check the screen power saving configuration in the display properties. Point the mouse in the blank screen then RIGHT CLICK THE MOUSE in select properties then select SCREEN SAVER click POWER in the power scheme select never for all options and also check the screen saver setting or disable the screen saver for the mean time.
Apr 23, 2008 | Acer Aspire 5100 Notebook
Microsoft wireless 4000
Screen saver mode, as you know, is entered when the computer senses no activity (including mouse) for a defined period of time. for some reason, the computer thinks there's been some kind of activity. If you have an extreamly sensitive mouse, vibrations could be being picked up "tricking" the computer into thinking there is activity.
The other possibility is that the computer might not be able to respond to the mouse if it went into screen saver mode (perhaps a preference setting with the wireless mouse) and has decided that while operating using a wireless mouse screen saver will be deactivated. Look into your preferences or settings relating to the wireless mouse.
Apr 15, 2008 | Microsoft Wireless Optical Notebook Mouse...
Wireless mouse
u need to get the wireless kit replaced
Dec 16, 2007 | Dell Wireless Keyboard Optical Mouse w0147
Screensaver will not activate...
I would remove the software for your keyboard. This will hand control of the screen saver back over to windows. Some keyboards come with third party software that conflicts with windows. If you want a functional set of "extra stuff" on your keyboard, then your best bet is to try one from another manufacturer.
Jun 16, 2007 | Logitech Cordless Laser Desktop MX 3000...
Toshiba Satellite P305D-S8828 Notebook PC Logo
98 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
