Question about Samsung LE40R72BDX 40 in. HD-Ready LCD Television
SONY HD TV 60"
I READ THAT SOMEONE HAD A LARGE GREEN SPOT ON HIS TV AND THEY WERE TOLD IT IS TOO EXPENSIVE TO FIX IS THIS TRUE?
    Problem Solver:
  • 6 Answers
It honestly depends on what type of TV. If it's a sony 60" it has to be a rear projection model, if it was bought recently or in the last few years it would be a LCD rear projection model. Repair is not impossible nor out of the question. If the green spot is a color stain burned on the screen it's replaceable. However, the cost of a new screen and with installation can be pretty high. Even if it's the LCD projector it's still repairable. Cost could be around 700-1000 dollars. If thats considered to expensive to repair then the answer is yes. Even if the TV did cost more than that you can find some awesome deals on new DLP TV's not to far off from that price range.
http://www.bestbuy.com/site/olspage.jsp?skuId=8824301&type=product&id=1212191771968
View this link for a good comparison.
Have a great day
Posted on Aug 11, 2008
I have a sony lcd projection tv model kf-60xbr800, green spots on the lower right corner , it start with one spot and now the spot are all over the screen
Those Rear LCD TVs get bad light engine on some. Causes fuzzy spots size of quarter. Or sharp small bright spots looks like road map or 'stars'. Need new/rebuilt light engine.
Apr 08, 2014 | Sony Grand WEGA KDF-60WF655 60" Rear...
I have a large yellow spot on my screen..... Will changing the bulb fix this - or is there another remedy?
Your set uses red, blue, and green lcd panels to produce your colors. The lamp provides the illumination. What has happened is the blue lcd panel has been damaged in the area you are seeing the yellow. The fix for this is to have the optical block (also known as the engine) replaced. This is a very expensive part,... you may want to move on to a flat panel tv.
Aug 29, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Yellow spot in middle of screen (sony-large screen-hd)
Sounds like the optical block (the projector part of TV is failing) The block cannot be repaired it has to be replaced. It can easily cost several hundred dollars to fix. Sony did extend the warranty on some models, you can try going on their website to see if your model is covered or not. good luck!
Jul 04, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
I have a sony 60 in rear proj. lcd that has no red in the picture other than faint red vertical lines all the way across about an inch apart. any ideas ?
It sounds like you do not have the red component cable firmly inserted. I had this problem on my first HD TV, when the green component cable popped out when I moved the TV back in place, and the picture was desaturated of any green, causing my wife to remark, "That sure doesn't look like HD..." I reinserted the green component cable, and the picture was excellent. Check those component cables.
Feb 06, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
Picture has a green hue to it. what could be
This is caused by a inherent defect in the optical block of the TV. This was a common failure and the only way to fix it is to replace the whole optical block which is very expensive( over $1000) and time consuming (need to take apart the whole TV). Sony is aware of this issue but have yet to extend the warranty for this TV. There is a class action pending against Sony because of this failure. You can add your name to the class action lawsuit here: http://www.sonysxrdtvclassaction.com/main/home.sfx
Oct 06, 2009 | Sony KDF-E60A20 60 in. LCD HDTV
Sony 50' LCD Projection KDS50A2000 has a green tint on the screen
Yes sounds like a bad light engine (Optic Block), expensive part, but sony has extended some warranties on these for two or three years
link hope this helps
Eric
Aug 26, 2009 | Sony Televison & Video
No blue color, green replaced blue, white is yellow/green
If the set is hooked up using Component cables (red, green, blue), then check to make sure the cables are hooked up correctly, and not defective (change them out). If the color problem remains, then the problem may be in the Optics block of the television (which is not unheard of in this unit).
If the menu of the TV displays blotchy discoloration, and the discoloring is the same for every input on the tv (stationary), then it is the Optics, and the optics need to be changed. It is not the easiest job in the world, and the block itself is quite expensive, although the unit my be under an extended warranty from Sony. Contact them directly to see if you can get any help (cost or service-wise). Hope this helps...
Dec 29, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Wega KP 46WT520 - Flickers Green
EVERYONE CALL SONY- SONY HAS EXTENDED ALL OF OUR WARRANTIES. i have this same problem with my 60" wega. i called sony and they explained to me that the problem was the optical light box. it cost a grip to fix even for them...so instead of fixing the problem they offered me the best true flats they had at way less than the actually price. i bought a 46" bravia for less than 550 including tax. i still have my 60" but until i get it fixed on my own this 46" will definitely do. i hope this helps you all
Sep 04, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Mitsubishi VS 60607 60" TV
From what i have been told the VS - 60607 was built in 2000 and i am not sure if it is HD or not.....
Aug 31, 2008 | Mitsubishi VS-60607 TV
Green spot on picture
Greenish yellow spot only means one thing. You have a defective lite engine. The only fix is to replace the engine. This part is very
expensive. Average cost $835.00 Part number A-1606-008-A
Best regards
circuitcity
Dec 08, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Samsung LE40R72BDX 40 in. HD-Ready LCD Television Logo
118 people viewed this question
Jerry Greenberg
Jerry Greenberg
