My computer is a Dell Dimension 2400. Installed ASUS DVD RW drive in December 2007. It seemed to work just after installation but now it does not work. I get a Windows Media Player Error Message COOD11B1. I checked Windows Update and the software is uptodate. Dell Customer Service checked their hardware and advised me that their hardware is functioning properly. Dell suggested my contacting the DVD drive manufacturer, ASUS.
  • 6,487 Answers
But can you still use the DVDRW right? the only problem here is you cannot use media player because of the error message? Because if the DVDRW still read and write so there's no problem with it the problem is with the windows media player, Try using a different media player like VLC.
Hope that helps.........
Posted on Aug 11, 2008
I Firmware problem!!
check the jumpers are on master slave or both on CS Cable Select
Jul 15, 2010 | Dell Dimension 1100 PC Desktop
DVD does not work
Hi, could you let me know , the dvd drive , doesnot work at all or is it playing cds but not dvds .
Is there any error reported, when you try playing them
Aug 11, 2008 | Televison & Video
I want to know if I would have a problem if I removed the Roxio cd player burner program from my computer that Dell installed? I use windows media player.
You shouldn't. You may not be able to burn data to a dvd-rw if you do because windows doesn't support it, but you can always install a free program like imgburn to do that task. There might also be a rare chance your upper/lower filters will block the drive from reading, but there are tutorials online to fix it if that were to happen.
Dec 30, 2009 | Dell Dimension 2400 PC Desktop
I cannot play a DVD on my Dimension 2400. I can
Oops... Man sad but True, it isn't a DVD ROM, if it says CD-RW.
Aug 17, 2009 | Dell Dimension 2400 PC Desktop
I just installed an LG 22x Internal Super writer DVD and my computer is not recognizing it. I have a jumper connecting the other drive. It is not picking up either one. Both open but nothing else. The...
I suppose your's is a SATA drive. Disconnect all the sata cables except for the Hard Disk and that of the Writer in question. Boot up and check if the drives works. If not take pains and try installing the drive in another PC (one of your friends'). If it still has the same problem check with where you bought it.
Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
Does the dell dimension 2400 burn dvds?
Hi budliteman36
Dell Dimension 2400 series will not bur DVD, see the link blow for specifications.;rnav
You can replace the CD-RW drive with a DVD writer. Here is a list od DVD-R-RW writers.
Mar 31, 2009 | Dell Dimension 2400 PC Desktop
My dell dimension 2400 does not recognize the dvd wr when I try to burn a back up dvd
The dvd drive is faulty, the same thing happen to me, Took the dvd drive to work tested it on a different pc and it did not work, go a old dvd drive from work installed it and it worked.
Your dvd is faulty needs replacing
Mar 25, 2009 | Dell Dimension 2400 PC Desktop
Dell won't acknowledge installed DVD/RW Driver
try running this patch..
or try calling Dell Tech. They normally remotely access your system and run a patch and your dvd drive will show up in Sonic/Roxio
Nov 22, 2008 | Dell 16X DVD±RW Serial ATA Internal Drive...
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
CD burner
Sounds like an issue with the drive. Is your computer still under warranty? If so then I would call dell and get it replaced. If not, then I would replace it myself.
Jan 12, 2007 | Dell (1Y414) DVD+RW Burner
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
