Question about Konica Minolta Zoom 160C Date 35mm Point and Shoot Camera
Konica Minolta Zoom 160c won't turn on--lens stuck out and open
Even after replacing the battery several times, the camera refuses to turn on. The little screen will simply flash once and then turn off. Sometimes, if the on/off switch is held it will make a sound similar to that of rewinding film. Also, the lens is stuck in a fully extended position and there seems to be no way to retract it or close the "eyelid" at the end. I do not know what can be done, if anything.
  • Konica Minolta Master
  • 6,100 Answers
There is some kind of grit or something in the lens gearing mechanism, preventing its movement. Take it to a repair facility, or replace it.
Posted on Jul 26, 2017
SOURCE:
SOURCE: Konica-Minolta Dimage Z2 can't turn on
Well, I also bought the DiMAGE Z2, and my problem was similar: It worked for some time, but then it started freezing sometimes, not responding to any button I pressed. One time, it froze, shut off, and I wasn't able to power it up again. In short, the camera was still under its warranty, so I gave it to their lab and they fixed the problem.
Posted on May 19, 2006
  • 217 Answers
SOURCE: Konica Minolta DiMAGE G500 5 MP Digital Camera
your lens mechanism is stuck up! try pulling the lens with slight force, if you are lucky the culprit that is blocking the mechanism will get loose. If you are not lucky theres no way you can remove or fix the problem than sending it to the authorized service center. =-( All digital cameras has a a life expectancy of around three years, or 5000 shots. Here in the Philippines, we use conversion method, since all cameras today are made of plastics, we convert those easy to break parts with metal.
Posted on Aug 24, 2007
  • 72 Answers
SOURCE: Shoots blank (dark) pictures after switching on.
This is a known design defect in the cameras and Sony is repairing them, even if your warranty is expired.
see this for Konica Minolta's official statement:
http://ca.konicaminolta.com/information/20070202/01_en.html
it'll direct you to a sony page where you can sign up to get your camera repaired!
more info can be seen here:
http://www.dyxum.com/columns/other/First_Black_Frame/First_Black_Frame.asp
Posted on Nov 16, 2007
  • 85 Answers
SOURCE: Film advance inoperative
check the polarities of the battery.
Posted on Apr 02, 2008
  • 480 Answers
SOURCE: Minolta Maxxumm 4 - rewinding too soon
Hey Pix4me,
I would make sure that the manual rewind button on the back of the camera is not stuck in, or you're not accidentally hitting the manual rewind button. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on Jun 06, 2008
My sony w370's flash doesnt work...i mean the flash does work bt only smtyms.....wen it is kept for a few weeks without being used...........then it work and after clicking 15-20 images it again doesnt...
Be aware your camera is not a professional DSLR with external flash lights.
Most camera's will get warm or even hot when you take several pictures with the flash on in a short time. Most manuals do have a warning about using the flash. Sometimes the camera is only allowed to take a picture with the flash on, once a minute or even once in a couple of minutes. When the camera becomes hot, it will prevent itself against overheating, by not charging the flash again.
Still it can be possible something els is wrong with your camera, but try to shoot with the flash, with greater intervals and look if you can use the flash any longer. Also when the battery is drained, the flash won't charge. When shooting continuously, you will drain your battery much quicker.
Jan 19, 2014 | Sony Cybershot DSCW370 Digital Camera
Camera won't turn on
replace batteries and check again
Jul 03, 2012 | Konica Minolta DiMAGE G600 Digital Camera
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Zoom stuck at telephoto
I had this same problem with 2 different Minoltas. One the zoom stuck when the battery got too low and the problem was fixed when I recharged the battery. The other was a mechanical problem and I had to have it replaced. Luckily it was still under warranty. Good luck!
Jan 14, 2011 | Konica Minolta DiMAGE Z3 Digital Camera
Won't turn on; I press power and it just "clicks" and the power light flashes once.
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Aug 02, 2010 | Kodak EasyShare Z915 Digital Camera
I have a Maxxum 7000i 35mm camera and in the display there is the word Help flashing what does this mean This happend after i tried a differnt lens, the lens opened than closed The lens that i tried was a...
Konica lenses do not fit Minolta cameras. I think you messed something up.
Minolta MC and MD lenses worked on the older manual focus Minolta bodies. They will also work on the Phoenix and Seagull clones of the old Minolta bodies.
The Konica lens should only ever be mounted on a Konica camera.
Your 7000i is now a Minolta paperweight. You need to send your 7000i for repair or replace it.
You could also look on Ebay for another Maxxum body to use your lenses designed for the Minolta A mount. As a rule, camera lenses are not interchangeable. You can use any Maxxum lens on any Maxxum body as a rule, but Minolta changed their flash shoe after the original 7000 series. Flashes that work with your 7000i will work with any subsequent Maxxum.
lightspiritphotography.com
Oct 25, 2009 | Minolta Maxxum 7000 35mm SLR Camera
My Olympus x-42 12 megapixel camera. Flash broken?
My new camera seems to be eating away at my batteries. I have only had it since xmas and already have been through about 20 batteries. Is my camera faulty?
Oct 19, 2009 | Cameras
Konica Minolta Zoom 160C Date 35mm Point and Shoot Camera Logo
120 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Ekse
Damen Wong
Damen Wong
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
