Question about Belkin Computers & Internet
I purchased a Hi-Speed USB 2.0 7-Port Hub recommended by the salesman at the office supply store. It does not work with my new Dell computer which uses Windows Vista operating system. Please advise. Thank you.
  • 39 Answers
Normally USB Hubs all new are 2.0 and they use a simple USB connection that should work with all computers, you can try a different USB port in your computer and if that still doesnt work then most likely that product is not a name brand and it does not have the built in driver for the mass device driver which is what usb ports use to function and multiplicate and you should return it and get a better / different one. Hope my answer gets you closer to a solution. Please Help rate me if I helped you out or not I am new but a very good tech.
Posted on Aug 11, 2008
Need power supply for kensington PocketHUB 7 Port USB
The K33366 POCKETHUB 7 PORT HI-SPEED USB HUB requires a 5volt supply at 4amps
Jul 02, 2014 | Kensington K33366 POCKETHUB 7 PORT...
HP LaserJet 2430 Printer Will Not Print since USB Power Surge Error
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
Feb 19, 2013 | HP LaserJet Office Equipment & Supplies
Need high speed usb driver
Unfortunately, being that you are using USB 1.1 ports, the high speed 2.0 devices cannot be used. They look the same, but are different hardwares. Even if you hook up a USB 2.0 hub to the USB 1.1 port, you are still stuck with USB 1.1 speed.
Sorry to break the bad news. Let me know if there are any more questions regarding this issue.
Feb 26, 2010 | Dell Latitude C400 (C400GH0E220LH06) PC...
New Dell desktop can't recognize external hard drive
I devised these simple steps that tend to remedy quite a few issues with most USB portable / external hard drives and devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especialy true if you move a HUB to another port
If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
Aug 28, 2009 | Dell Computers & Internet
External HD not recognizing USB ports as being Hi-speed ports
I have the same issue. I have 4 Simpletech Signature 250GB drives. They all worked fine at first. After about six months two of them started connecting at USB 1 speeds. It occurs on 4 different computers!!! The post about it being the computer assumes is wrong. How can it work fine for six months and then suddenly change. Also it occurs on different computers. I have submitted a tech support request with simpletech and will post the results.
Jun 14, 2009 | SimpleTech Signature Mini 160GB External...
Dell Inspiron 8000 - USB2 Universal Host controller
you can plug your pen drive backside. if its cant work your computer speed is slow.
Sep 20, 2008 | Dell Latitude Cp, Cpi, Cpx, C600, C800,...
"A HI SPEED USB device plugged into a non HI SPEED USB hub" error message, any idea? every time i plug a usb in to my computer it comes up that this device can perfom faster on a hi-speed usb port
This is not an error it just means that you are plugging in a usb 2.0 device into a usb 1.0 port. The devise will still function normally just not as fast. You could always add a usb 2.0 pci card to your computer.
May 05, 2008 | Samsung YP-K3 MP3 Player
Power sugre with m240
Hi there. This message would indicate any one of the following: 1. You have a lot of USB devices plugged in to your computer, and the maximum power supply for the USB ports has been exceeded by plugging this player to your computer. It would be best if you unplugged 1 or 2 of the USB devices connected for the time being. 2. You are plugging the player on your front USB port, and may need to plug it in the rear USB port to acquire ample power supply (front USB ports do not get as much power as the rear USB port -- sad but true) 3. You are using a laptop and may need to try another USB port on that computer. Purchasing a self-powered USB hub would be ideal as it gets its power supply directly from the wall electrical socket.
May 11, 2007 | SanDisk Sansa m240 MP3 Player
Computers & Internet Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
