Question about Dell Inspiron 1000 Notebook
DELL WILL NOT POWER UP
I HAVE A DELL INSPIRON 1000. IT WORKED FINE YESTERSDAY BUT TODAY I GET NO LIGHTS AT ALL TELLING ME THE UNIT IS EVEN GETTING POWER EVEN THOUGH THE OUTLET IS OK. IF THE BATTERY IS SHOT WOULD IT STILL WORK ON AC OR NOT THANKS GARY
  • Anonymous Mar 19, 2009
    And if the power adapter is working at 19volts? and the even the power is getting to the motherboard. Still no lights or signs of life.
  • 3,940 Answers
If the battery is shot, remove it and see if the system will power up on AC only.
If not change, check the output of the AC adapter with a Multimeter set on DC voltage. It should be 15 to 20 Volts DC current at the connection end for the computer. If low or no voltage, replace the AC adapter.
Posted on Aug 11, 2008
Is there a quick fix to replacing the processor fan on a Dell Inspron 1000
Not a quick fix, but you can buy a cooling base unit for it which plugs into one of your usb ports which supplies power for the built in fan.
Aug 20, 2014 | Dell Inspiron 1000 Notebook
Would like a circuit diagram for dell inspiron 1000 power circuit
There is a reverse polarity diode that prob popped. It doesn't allow the power to even reach the battery anymore. It'll prob charge in another laptop that takes that battery. The diode is on the mother board.
Nov 24, 2013 | Dell Inspiron 1000 Notebook
Dell Inspiron 1000 won't turn on. It is always
Well if it is always plugged to the wall then the laptop's power jack is the common problem there. You can have a Computer Technician check it and diagnose it for you. Be careful how much you pay, if that is the problem (i'm pretty sure it has to be) you can shop for the part online (ebay is a good place to find them for around ten bucks) and hand it to the computer guy. Otherwise you may be charged a fortune to get it fixed. Next time, use a power surge between the power adapter and the wall's power outlet.
Here's is a brief explanation of what happens with the power jack. Inside of it there are two or three pieces of metal that look like thick wires and what they do is transfer the current to the laptop. Eventually they wear out and break (common cause is having your laptop plugged to the wall continously exposing it to all sorts of power surges). Hope it helps, good luck.
Jan 03, 2010 | Dell Inspiron 1000 Notebook
Installed a rangeplus adapter on dell 1000 inspiron xp sp3 home
See if you can go into safe mode by hitting the F8 key right after the dell splash screen and right before the XP splash screen comes up. If you can get into safe mode try to uninstall the rangeplus adapter and try reinstalling again after rebooting the system normally.
Nov 15, 2009 | Dell Inspiron 1000 Notebook
Green LED on Dell Inspiron Desktop 530 - all OK?
Yes, on most desk top the green light in the back tells you that you have power to the cpu. Even though the unit is off it is telling you that the current supply is still there. This is a good feature if you move your unit as soon as you plug it in you know if the outlet is on or not.
Oct 17, 2009 | Dell Inspiron 530 PC Desktop
Dell inspiron 1000 power lite comes on then goes off cd works, num lock lite on, screen not on and then power light goes off other lights on and cd works, hd light not on.
Motherboard failure. You can find replacement motheboards on Ebay but this is such a low end system it isn't really worth repairing
Jan 20, 2009 | Dell Inspiron 1000 Notebook
Dell Inspiron 8600 Not Powering Up
have you checked all connections to the battery, make sure the battery terminals are free of cerrosion(rust&mold) make sure alll the power cables are intact. it does not sound like the power supply due to the fact that the light is coming on for a min or so.
May 11, 2008 | Dell Inspiron 8600 Notebook
Dell Inspiron 1000 Notebook Logo
252 people viewed this question
Alun Cox
