Question about Sylvania Televison & Video
Setting up TV
I can't change from AUX to regular TV
  • rkrobeek Aug 13, 2008
    THis is a tv/vcr combo and I don't have a TV/Video button
  • 3 Answers
There probably is a TV/Video button on the bottom of your TV. Push the button until the screen changes to a regular screen. The TV/Video button is also on the remote most likely. Just keep pushing it. Often there are 2 or 3 aux channels. Hope it works!
Posted on Aug 11, 2008
I have the btt350 home theater system connected by a hdmi cable from blu ray player connected to a panasonic 50" plasma 3d tv when playing a disc or listening to the radio from the blu ray player the...
Page 22 in the Manual details the required input to be selected dependent on the connection type.
To enjoy sound from the TV (Page 29)
AUX*1: When using an Audio cable
ARC*1: When using an HDMI cable
(Available when using an ARC
compatible TV)
DIGITAL IN*1: When using an Optical
digital audio cable
And from Page 29
Turn on your TV and select the appropriate audio input mode
[AUX, ARC, D-IN] to suit the connections to this unit. (Page 22)
Page 30 details how to set the audio link.
Setting the audio link with the TV
With the remote control;
Select the actual TV audio connection on the main unit.
1 Press [START] and press [3, 4] to select "Other
Functions" and press [OK].
2 Press [3, 4] to select "Setup" and press [OK].
3 Press [3, 4] to select "TV / Device Connection" and press
[OK].
4 Press [3, 4] to select "TV Audio Input".
5 Press [2, 1] to switch "AUX","ARC" or "DIGITAL IN".
Select "AUX" or "ARC"*1 in "TV Audio Input" when the
DIGITAL AUDIO IN terminal is used for the STB
connection.
Whenever the connection or settings are changed, reconfirm
the points above.
Please leave feedback
Cheers
Andy
Apr 26, 2011 | Panasonic SCBTT350 Theater System
How to get system to play the sound from regular television.
Well this is a very common solution. Evry system has an AUX output and Every TV has the AUX input. All you have to do is connect the AUX output of the surround system to the AUX input that is found in your TV. Most tv's have this AUX input on its front or you might also find it on the rear of the TV.
Sep 12, 2010 | Philips HTS-3565 Theater System
I cannot figure out how to change my aux settings to on. Nor the d-aux. any help? I am also unable to change the display color.
try this
Setting the AUX Mode (V-Link)
AUX IN ON / AUX IN OFF (Initial setting)
You can input TV/video sound by connecting an optional Ai-NET/
RCA Interface cable (KCA-121B) or Versatile Link Terminal (KCA-
410C) to this component.
You can change the AUX name display when AUX ON is set. Select
the AUX name by pressing g or f. Then press BAND.
If the KCA-410C is connected, it is possible to select two AUX
names.
• Via KCA-410C, up to 2 external devices with RCA output can be
connected. In this case, press SOURCE/POWER to select AUX
mode and then press BAND to select your desired device.
Jan 28, 2010 | Alpine CDA-9847 CD Player
RCA Home Theater model RTD315W
  • You need to change your audio settings in your TVs audio menu. Sounds like it is set to play only external source when connected, There will be a setting for all speakers to play, including TV's. Have your TV's volume up just a hair when changing your settings and you will be able to hear when it changes to what you want.
Jan 27, 2010 | RCA Audio Players & Recorders
Receiver never stays on Aux 2 input...
Is the TV a Samsung as well? Check both devices to see if you have "Anynet+" is on, if so turn it off.
Jun 26, 2009 | Samsung HT-TZ312 Theater System
My sony tv is stuck in the aux mode
get a programable remote program it and just simply switch it over to cable or hit video it should do what it's made to do
Jun 07, 2009 | Zenith B27A11Z 27" TV
Aux setting
Unplug it! I have the same tv and cant figure out how to purposely turn the aux on. ( It always goes on aux when I'm channel surfing, and don't want it that way.)
Jan 31, 2009 | Broksonic CTGV-5463TCT TV
Can't play AUX inputs through Panasonic surround sound
Check the TV audio output setting. There may be 3 settings for audio output. Fixed/variable/none. Try all of the settings, and see if you get your audio back. If not, try a different cable between the TV and DVD player. I suspect this is a red/white RCA audio cable.
Dec 12, 2007 | Audio Players & Recorders
AUX to normal channels!
Have you done a hard reset? (Unplug the tv for a couple of hours, then power it up again).
Dec 05, 2007 | Sony KP-53V90 53" Rear Projection...
Televison & Video Logo
152 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
