Question about Hitachi RAS-09UH Air Conditioner
Hitachi RAS-12UH air conditionner
The unit does not start. I changed the batteries but I'm not able to restart it.
2 Suggested Answers
  • 2692 Answers
SOURCE: Need a new remote for my Hitachi RAS-12UH Ductless Split
http://www.hitachi.com.au/productsearch.aspx?pId=62&
Posted on Jan 08, 2009
Compaq cq60-615dx errors on screen
It would be very helpful if you type in the error here.
Thank you
Nov 20, 2012 | HP Computers & Internet
I changed outside batteries; will not transmit out side temperature? need help
You may need to reset you inside unit by removing the batteries and restarting it. the outside unit should then be able to sycn to the base unit.
Dec 05, 2011 | SkyScan Audio Players & Recorders
Our Generac Generator 04675 (15 kW LP) ran for 3 days in a row due to a power outage. It shut off for low oil on the fourth day. We Added 1 qt oil and we restarted it and it ran great for another day...
The only time a battery will blow up is if the hydrogen gas ignites. Usually what happens is that when the battery is being drawn like during cranking, or trying to be recharged at a high rate the battery begins emitting hydrogen gas from the sulfuric acid. This is usually why the battery is kept away from anything that sparks usually. When the hydrogen gas comes out it also slowly bakes off pure water. When this happens and the level drops below the level of the plates in the battery, when the battery has to make amperage during cranking an ark occurs accross the plates igniting the hydrogen gas and making a miniature atom bomb. Loud isn't it?? To prevent this from happening keep an eye on the charge rates of the battery and if the battery has removable vent caps, keep the level topped off with distilled water. Please also note that many residential gensets do not charge their own battery and rely on the maintenance charger to always keep the battery charged. Make sure the maintenance charger is on a circuit that will be powered by the genset during a utility outage.
Jul 16, 2011 | General Electrical Supplies
I have a 1998 Ford Escort 1.8si, and when I started it, the battery seemed low (the starter turned slower than normal). It started though, but while driving, I think the battery went flat. The radio turned...
there two things to be aware of,
1 the condition of your battery, if it is more than 5 years old it could be the main problem
it can maybe no longer hold any change, (check battery condition, see if there is a little window on the top, if it is any colour than green it could need replacing, this is the first thing to change as the second maybe expensive but not needed.
2. your charging system is not working e.g. the alternator, (generator) and need replacing.
use jump leads or a slave unit to get your car started or use a change unit and charge your battery for a few hours, let it charge for a while and see if the red charge light is on while the engine is running, (it looks like a battery block with positive and negative symbols -+ if this stays on it means you battery (no matter what condition it is) is not getting a charge(suspect point 2). if this light is off and you experience the same problem again after your battery changed from a slave unit or from another car then suspect point 1.
i hope this was useful
Mar 27, 2011 | Ford Escort Cars & Trucks
When I push the power button to power the lap top up the light display that says outlet power changes from green to amber and the laptop will not power up.
try removing the battery and just use plug power only if it boots normally then change the battery and the change the power supply unit as well I would just start with the power supply unit first then see if the battery charges up if not the battery is bad replace it. Now if the computer will not start with the battery removed then you have a power supply issue.
Change and replace it. Hope this helps. Also when computer lap top get hot they will shut down to protect the computer wait and let it cool down then try to restart your computer. If this does work and the lap top restarts normally get a fan cooler that is USB powered and the lap top sits on top of it. Also make sure the fan is running and is not stopped. Clean and dust it out once in awhile. I hope this assists you with your problem. John
Jan 22, 2011 | Toshiba Satellite Pro 6100 Notebook
Tryed to turn laptop on and now it is saying operating systems not found
Please check your Hard Disk Drive in the BIOS is still functioning. At the BIOS Booting Setup the should be ON to boot your Operating System.
Try and try again.
Sep 30, 2009 | HP Compaq Presario C304NR Notebook
Toshiba laptop won't start up
Try this:
  • remove battery
  • replace battery
  • restart
Then:
  • with charging cord plugged into computer and wall restart
If it starts on the battery the computer has reset itself-- you're good to go...
If it starts on the wall charger but not the standalone battery... the battery is the problem.
If neither works replace the charger cord.
Good Luck
Jeff
Sep 13, 2009 | Toshiba Satellite A205-S4777 Notebook
Hitachi RAS-09UH Air Conditioner Logo
227 people viewed this question
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
