Question about Canon PIXMA MP600 all-In-One InkJet Printer
Ink absorber I have Pixma ip2000. The ink absorber is full. How do I remove and clean it?
    President:
  • 2,306 Answers
You can't clean the pad, first it's under the printer covering the whole bottom of the case and second it's just cotton batting that will fall apart if you try to wash. Removing the printhead has nothing to do with the reset, You really need a shop to replace the ink absorbers and do the reset. If you reset without new pads the waste ink will soon overflow. It takes a good 3 hours labor to clean up the ink mess and then replace the pads.
Posted on Feb 22, 2010
  • 4,345 Answers
Canon PIXMA IP2000
You may RESET the printer code first if you like or do it after you clean the pad
In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
This is the correct code for the S and I (like i960) series of printers. (M series below this)
1) Power off printer
2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
3) Hold POWER and Release RESUME.
4) Press RESUME twice then release both POWER and RESUME buttons.
5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
6) Press power to set data.
7) Print away!
For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
Posted on Feb 18, 2010
6ya staff
SOURCE:
Waste ink absorber is. full. How do I empty it?
The waste ink absorber can sometimes be removed and cleaned out and put back into place. Although it is not always easy to get at. Usually once this happens it is time for a new printer. You can also contact Canon and see if they have a replacement part for this.
May 28, 2010 | Canon PIXMA iP2000 InkJet Printer
Printer shows warning
plz check the website http://www.fixyourownprinter.com/forums/inkjet/50418#1
Nov 18, 2009 | Canon PIXMA iP2000 InkJet Printer
My Canon PIXMA iP2000 photo printer Waste Ink Absorber
Hi there try see if this will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 10, 2009 | Canon PIXMA iP2000 InkJet Printer
How will i clean the ink waste absorber and reset it
use this link click here
this wil help you in cleaning the waste ink
you can also take halp of the following link
Jul 27, 2009 | Canon PIXMA iP2000 InkJet Printer
My printer canon pixma ip2000 wont print there is a message on the monitor saying that my ink waste absorber is full
follow the link
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jul 27, 2009 | Canon Office Equipment & Supplies
My printer, the Canon, Pixma Ip2000 stopped printing. It was giving me the message "the waste ink absorber is full". I took it to the only canon dealer in the city, and he reccommended that I replace the...
Reset Printer Canon IP2000 / IP3000
By pelda
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
http://freeresetterprinter.wordpress.com/2008/09/05/reset-printer-canon-ip2000-ip3000/
Mar 26, 2009 | Canon PIXMA iP2000 InkJet Printer
How do I reset the printer after washing the ink absobers
how do i clean the ink waste absorber of canon pixma ip2000 printer
Mar 24, 2009 | Canon PIXMA iP2000 InkJet Printer
Canon Pixma ip2000 saying waste ink absorber almost full
This is quoted from cannons website about your issue.
"This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk."
Here's the link
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10237&kbpage=yes
So what they are saying more or less is throw out the printer because it's going to cost more to replace the absorber than to just buy a new printer.
If you ak me it's just another way these printer companies screw customers. Just my opinion.
Sorry about the bad news but at least you have your answer.
Sean
Mar 12, 2009 | Canon PIXMA iP2000 InkJet Printer
WASTE INK ABSORBER IS FULL FOR CANON PIXMA iP2000
The machine needs to be taken in for the waste ink absorber to be replaced
Oct 03, 2008 | Canon PIXMA iP2000 InkJet Printer
Canon PIXMA MP600 all-In-One InkJet Printer Logo
231 people viewed this question
Clive
Clive
old marine
old marine
Ekse
