Question about NetGear WGR614 Wireless Router
Router Suddenly stopped working...?
My router has been working just fine for over a year, and just this morning it started being unable to connect at more than 1mbps, and now the desktop computer that uses the wireless connection can't access the internet. It appears to be unable to find the router at all, because where it usually says 'Connected to Internet', it just has '-.-.-.-.-'. If there's any more information needed, please let me know!
    Sergeant:
    Champion:
  • 236 Answers
Try power cycling your network (turn off all of the hardware)
First turn off the computer,
second, the router;
lastly the router (wgr614).
Now, turn the hardware in this order:
  1. Turn on Modem. Wait 2 minutes.
  2. Turn on Router (wgr614). wait 1 minute.
  3. Now turn on the Computer(s).
this should refresh your internet connection. If not, check your routers settings for any wrong info.
to access your router's homepage, type this (http://www.routerlogin.net) into Internet Explorer.
Posted on Aug 11, 2008
Error 51030 shows. has worked fine until today
Unable to connect to your wireless network
Likely cause: Your wireless router may need to be power cycled, or the connection settings have changed.
How to fix: Power cycle your router; redo the connection settings on the Wii and try again.
  • Did this connection used to work but has suddenly stopped? "Power cycle" your router and modem. To do this, unplug both the modem and the router from the power outlet. Wait a few minutes, and plug the modem back in. Wait a couple of minutes for the modem to initialize, then plug in the router. Try to connect the Wii, Nintendo DS, or Nintendo 3DS online and test for proper response.
  • Erase your old connection settings on the Wii and set up a new one, as your router's settings may have changed since you last connected. We suggest following our guide to create a new connection file and start over.
May 29, 2011 | Nintendo Wii Console
The signal was still good but no-go to the web.
1. Clone your MAC address of the computers network card in the router and this should connect properly.
2. Power cycle the router.
May 16, 2010 | D-Link Xtreme N DIR-655 Wireless Router
D-link has stopped working with comcast internet.
Are you trying to install the router.You can do it manually
without the CD.
MAke sure that your computer is able to go
online through the modem.
If your computer is able to go online
through the modem
Then you need to connect the computer to the
router ad the modem to the router.
open the set up page of the
router and change the settings of the router according to the
ISP.
Click Here for step by step by instructions
Jan 16, 2010 | D-Link AirPlus Xtreme G DI-624 Wireless...
Wireless Router suddenly stopped working.
Try resetting the Linksys back to the factory defaults and configure it again.
Power up the router and press the pinhole RESET button on the back of the router for 30 sec
Connect a LAN cable to the wireless router and open a browser and enter to router's configuration IP address and configure the wireless settings, remove the LAN cable when configuration is completed.
You need to configure then wireless card in the computer/laptop with the router's wireless settings.
Dec 10, 2009 | Linksys Wireless-G Broadband Router
No longer able to connect laptop to the internet with wireless modem. Have had to disconnect and work only from desktop. Have used this for a couple of years and suddenly stopped working. I can see the...
What did you install last on the laptop?, if its anti virus disable it and try connecting.If after that it does not work ,reinstall the computer OS something is corrupted.It's definately not the router issue.
Dec 08, 2009 | Computers & Internet
My netgear DG834pn was working fine, but suddenly from today morning there is no wi-fi led burning and it is not emitting wifi signals too, i checked in router page and checked - wifi is on and ssid is...
If it has stopped working all of a sudden, could be a faulty router. But before that, I would suggest you to reset the router once.
Hope this helps
Thanks Ranjit
Sep 14, 2009 | NetGear RangeMax WPN824 Router
My laptop can detect my network but unable to connect
1) double click on the wireless network icon on the status bar
2) click on View wireless network
3) click on change advance settings
4) go to wireless networks
5) under the preferred networks, remove the SSID
6) try to connect again
Aug 30, 2009 | Dell XPS M1330 Notebook
My US Robotics USR8054 Wireless Modem stopped working
DHCP may not be working on the router. What IP address does the router give your computers? It should be a 192.168.123.xxx address as default. If you are not getting an IP, then you will have to set a static IP in the range above to connect to the router setup webpage and reenable DHCP.
Mar 07, 2009 | U.S. Robotics USR8054 Wireless Router
Wireless router
Make sure that the ehternet cable going from your modem is plugged into the slot on the router named internet.
Mar 30, 2008 | Computers & Internet
Actiontec GT704-WG wireless connection not working
you say it suddenly stopped working, if you can connect to the router via ethernet cable then try to access the router's web utility page and make sure your router is in mixed or G-only. If you can't still connect to the router through wireless then try restarting the Wireless Zero Configuration from windows. This is how it's made: Go to control panel and double-click "administrative tools", then double-click "services". You will see a list, scroll down to Wireless Zero Configuration and click "stop", you'll see a progress bar. After that click "start", you'll see another progress bar. Now try connecting to your router via wireless connection. If you still can't connect then repair the connection by right-clicking the wireless icon at the bottom right corner. Keep repairing until you connect.
Hope this works!
Feb 16, 2008 | Actiontec GT704WG Wireless Router...
NetGear WGR614 Wireless Router Logo
80 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
