Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Convergence what is the stk number for kp-53hs20?????is it stk-392-110 or stk 392-560
  • Sony Master
  • 8,617 Answers
STK392-560 you will also likely need two 3.5 Amp pico fuses with the ICs you can get replacments with free instructions at the following link.
http://servicemanuals.vstore.ca/
Posted on Aug 15, 2008
SOURCE:
How do i fix red and green color alignment on a sony kp-43770 tv
Model number does not sound quite correct but if a convergence problem both chips the set uses will have to be replaced and the set adjusted with the Sony remote.
Confirm actual model number and Google it with "parts" to see what it uses. Most convergence chips will have the actual STK number right on the front of them and almost all Sony sets use two chips.
5_21_2012_12_31_29_pm.jpgtypical chip used in some later Sony sets
May 20, 2012 | Televison & Video
The writing is blured and color is messing up
That problem is on the convergence issue..
The problem is usually cause of bad convergence I.C the part # is usually start with letter STK####..and follow by numbers...
Hope it helps..
Dec 07, 2011 | Sony KP-53HS10 TV
I HAVE A SONY KP-53V90 53 INCH REAR PROJECTION TV AND THE COLORES ARE NOT MERGING TOGETHER PROPERLY I THINK THIS IS CALLED A GHOST IMAGE HOW CAN I FIX THIS
You have a convergence issue, will have to check convergence IC,S or just replace them there are usually two of them mounted on heat sinks they are usually STK'S with a number after. Also must check fuseable resistors supplying +15 and - 15 volt s to the chips. After replacement some convergence alignment may be needed. Good Luck.
Mike
Apr 15, 2010 | Sony KP-53V90 53" Rear Projection...
Sony KP-57WS510 convergence problem. One web site
You can get original Sony STK392-560 chips from www.TvRepairKits.com. They have a OEM chips from Sony and come in the original Sony boxes. There limited supply.
Sep 16, 2009 | Sony KP-57WS500 57" Rear Projection...
Convergence problem
If this is a kp-46wt510: You need to replace the two convergence ic's; they should be STK 392 types---look inside and you will see them on identical large metal heat sinks with fins--the ones your set uses will have the full stk number on them(stk-392-110 or stk-392-560 are the most common for Sony)
They both need to be replaced and any bad fuses or resistors around them that protect them found and replaced---Most of the time just the two chips need to be replaced and the set adjusted with the remote; I have done hundreds of these sets and usually the repair takes about an hour and can be done in your home.
If this has been helpful give me a vote here as I do this for free.
if you have questions or need help:
[email protected]
Aug 23, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Jun 12, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Won,t turn on.
FOUR Blinks---No Vert. Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. check the vertical deflection IC and circuit
Nov 05, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
The red convergence is off
replace the convergence ICs post your model and I will post a link where you can get the parts and they include step by step instructions with pictures so you can do the repair yourself takes an hour and will save you about a 400 dollar repair bill.
Mar 30, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Double vision
Convergence ICs are bad it causes the red and/or blue to jump out of alignment making it look 3D. You have to convergence ICs located on a large aluminum heat sink with an STK number stamped on them. You can purchase new ones for about 10.00 each. they have to be soldered in. If you can solder you should easily be able to repair this yourself. Let me know if you need anything further.
Jan 24, 2008 | Sony KP-53S65 53" Rear Projection...
Convergence problem
you will need to replace the stk ic's they are mounted to 2 large heat sinks in side the tv. the ic numbers are on the chips themselves. i do believe it is stk392-510 for sony. once you have the number you can buy these anywhere online. just put new ones in and should be good to go. if this doesnt work then there are a few resistors and fuses by the ic's that sometimes fail.
Oct 11, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
146 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
