Question about Compaq Computers & Internet
After restoring a Presario 1700, a blue screen is displayed and the error says something about dumping physical memory. I have used the quick restore several times with the same result. Answers?
    Scholar:
  • 65 Answers
This could be a hardware problem. Open your tower,
1). check the inside of your tower for dirt and dust, give it a clean.
2). check your ram memory. be sure they're pushed in good. you may have a bad memory stick and need a new one. maby find a friend a use thiers to see for sure.
3). some times compatability problems can be conflicts enough to cause problems. check your hardware for compatability confilcts.
* but i'd check the memory first *
Posted on Aug 11, 2008
How to solve physical memory dump
Hi Good day!!!
Check your Memory (RAM) turn off your laptop and then remove your Memory then clean it same use a brush for cleaning.
I am sure you freak out when you computer screen suddenly turns blue and you see the error message that says "beginning of physical memory dump".
What do you do? Most people would just reboot the computer and pretend nothing happens. Some people want to know what happened and what they should do to fix it. It can be very daunting and stressful when you get the blue screen of death while doing important work. You would not have time to save it because it happens suddenly without any warnings. You must do the work all over again after rebooting.
What actually cause the physical memory dump?
  • DLL error
  • RAM Hardware Problems
  • Memory allocation error
  • COM error
  • HIVE crash
What should you do when it happens?
If it occurs because of your memory problem, then you should consider buying a new computer.
The ignorant way is doing a reboot and hoping that it does not happen again. The hard way is to address what caused the error and fix it manually. If it occurs because of your chaotic registry, you could find and fix it, which is very dangerous because one simple mistake can lead to a total error in your system. Reinstall your operation system might be a wiser decision to make.
The easy way is to pay a computer technician hundred of dollars to fix it for you. But in fact you could do what the technician would do to fix your computer; the wise way is to be a computer technician yourself. Did I said that you could actually do what a computer technician would do to fix your computer? Yes, it is very simple really. A technician uses a simple software to fix your registry.
If you could be the technician yourself and pay less to get the software that you can use forever, why should you pay a technician hundreds of dollars to fix it only one time for you?
You will want to do regular maintenance to keep your PC error-free so that this problem never re-occurs again.
Thank you for using FixYa
Nov 05, 2010 | HP Compaq Presario v3000z Notebook
Registry file failure
Do a clean installation from CD rather than simply doing a system restore. There's less chance for something to go wrong with a clean installation. The Stop: c0000218 (registry file failure) error is typically associated with one of several things, depending on how far through the recovery process you made it before encountering the error.
Jun 01, 2010 | HP Pavilion dv5000t Notebook
Computer restarting again and again and shows a blue screen with "Beginning dump of physical memory." Also when i scan the system using kaspersky internet security antivirus it got restarted and i couldn't...
sometimes it happen because you have installed a driver recently and it is creating a havoc there. try to run in safe mode and restore the configuration to the previous one.
other options, is that a memory went bad. try to read what error is telling before the beginning dump of physical memory.
if one bank of memory is bad, try running your computer with one of the banks at the time.
Apr 23, 2010 | Microsoft Windows XP Professional With...
A blue screen came up saying something about the memory module!
oh k..
so u mean whenever u start ur computer or whenever u work on it, it shows Blue screen...
This blue screen is called BSOD Error (Blue Screen Of Death)
It occurs due to several reasons but since u specified abt memory, this might be showing you Kernal Memory Dump, i hope..
Dont need to panic, try to start up computer in safe mode & restore it to previous known date at which u didn't had that problem..
It generally occurs after installing some new softwares or drivers that conflicts with the memory module.. so try to restore ur system else try removing ur newly installed software or driver...
Hope this helped u out..
Thanks....
Aug 27, 2009 | Toshiba Satellite A65-S1062 Notebook
Physical Dump of memory
Hi...
There are two thing you should try..
Check the memory.
Reinstall the OS.
Thanks
Kindly rate
Smith
Aug 13, 2009 | Dell Inspiron 1420 Notebook
Physical memory dump screen
This is a critical error that has occured due to a unstable core system 32 file base. this has cuased the OS to collapse. you will need to try a system restore. you may or may not be able to retrive your stored files. during the restore, some hard drive files may be deleted. this is the best way to regain stability.
In most cases, thsi is cuased by malware and virus attacks as well. you can initiate a restore by inserting the recovery disk that should have been shipped with your CPU. check in the box that it was packaged in for this recovery disk. if this disk is nto availibe, you will need to purchase a copy of you rOS. you can use this to re install the OS.
You should knwo that, when you use fresh copy of the original OS, it may wipe all stored files in this case.
May 27, 2009 | Dell LATITUDE D400 D500 D505 D600 D800...
Blue screen on start up
This may be related to faulty memory or your page file (virtual memory) may be damaged.
You can try to remove your ram chips one at a time (boot up) and see if one is bad or make sure your virtual member is set to system managed.
To change your VM settings follow these steps:
  1. Click Start, right-click My Computer, and then click Properties.
  2. Click the Advanced tab.
  3. Under Performance, click Settings.
  4. Click the Advanced tab.
  5. Under Virtual Memory, click Change.
  6. Click No paging file. Click OK, click OK, and then click OK.
  7. Restart your computer.
  8. Click Start, right-click My Computer, and then click Properties.
  9. Click the Advanced tab.
  10. Under Performance, click Settings.
  11. Click the Advanced tab.
  12. Under Virtual Memory, click Change.
  13. Click System managed sized. Click OK, click OK, and then click OK.
Apr 27, 2009 | Computers & Internet
Physical dumb of memory
THIS PHYSICAL DUMP MEMEORY IS DUE TO OPERATING SYSTEM ERRORS OR DUE TO MEMORY ERROR. TRY RESTORING THE OPERATING SYSTEM IF NOTHING WORKS OUT REFORMAT AND OR CHANGE THE MEMORY (RAM)
REGARDS
RAFIQUE
Feb 24, 2008 | Computers & Internet
Blue Screen Error Message
Your hard drive crashed. You need to buy a new hard drive and restore your computer using the restore disks. You can buy a hard drive here: http://www.interproshop.com/commerce/catalog/product.jsp?product_id=13055&czuid=1167865660865 They also sell larger hard drives. If you dont have a restore disk, you'll need to contact HP and they'll send you one. http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=423721&lc=en&cc=us&dlc=en&submit.y=9&submit.x=8&lang=en&cc=us
Jul 14, 2007 | HP Pavilion Ze4805us Notebook
Computers & Internet Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
