Question about Car Audio & Video
Dont know where to hookup the remote amp wire
  • 1,586 Answers
Tap into the blue antenna lead on the harness if you have an aftermarket head unit. If not, you can run from the switched ignition power wire on the factory head unit. If you pull the head unit out, it may have a diagram on it telling you which wire does what. There are two power wires - one is constant power to maintain radio presets, clock, etc, and the other one is triggered when you turn the key - that's the one you'd want. If you use constant power, your amp would never shut off, even when the key was out of the ignition. If none of that is feasible, run the wire from the battery to your remote turn-on connection on the amp, but put a switch on it up near the driver's seat, so you can turn the amp on manually.
Posted on Aug 11, 2008
Wheres do the remote wire hookup at
on the amp will be a connection point labeled remote..normally it is placed between or next to the power and negative connection points...ensure that the remote wire you run from the amp is connected to the correct wire on your deck...normally it will be blue, if not look for a wire that isnt black,red or yellow and isnt a speaker output
Jan 07, 2011 | Kenwood KAC-X201T Car Audio Amplifier
When i hook up my amp my speakers wont play music? ive hooked up my rca cables up but i ont know if you hook it up to the input or output frum the cd player?
you rca hookup, back of cd player is rca out, at the amp it is rca in, make shure you hook up blue remote wire, also make shure you have a good ground if not amp will not turn on. if you run wires make shure you run power wire down one side of car and remote and rca down the other, This will keep all motor noise out of system.
Oct 07, 2010 | Audiofonics Car Audio & Video
Well i want to hook up hifonix amp and one pioneer premier un my hyundai xg350l and i want my stock radio to stay i know i need some sort of adapter to create rca's and also where would the remote line go...
you need a (loc) line out convertor you can get at best buy or radio shack and the remote wire will need to be tap in at the fuse panel to the radio fuse. so that amp comes on when the car is turned on.
Feb 02, 2010 | Stingpro ST444 1850 Watts Complete...
RADIO AUX HOOKUP
If you are using an aftermarket cd player, than you will have audio output jacks on the back of the cd deck, One Red and One White.
If you are going to run an amp or external power, then remove your deck and you will see the blue remote wire, this wire should be connected to amp remote wire or screw.
Aug 04, 2009 | Mitsubishi Eclipse Cars & Trucks
Amplifier enable. Where to mount rmt hookup on pioneer deh-1400 (old) so my amp/sub can work!!!
Amp turn on wire should be a blue wire with a white stripe on that pioneer unit. extend that wire out to the amps remote turn on wire input. And once the radio is turned on it will sent a 12volt signl and turn on the amp.
Jun 09, 2009 | Pioneer DEH-1400 CD Player
DXZ545MP rcas to sub amp
Blue white is remote to amp.... Grey and black are your RCA out to amp...
Jan 26, 2009 | Clarion DXZ545MP CD Player
This car reciever is difficult
should be a blue wire to power the remote to the amp. Plug it into the amps remote hookup point and that should do it.
The same wire that is commonly used to power ant. owners.(makes the radio ant. go up and down per the radios on/off power status)
Nov 26, 2008 | Kenwood KDC-MP4032 CD Player
Install diagram?
i dont know where to find the instructions, but it shouldn't be all that difficult. I used to have one of these legacy amps .....what hookups do you have on it?
Mar 15, 2008 | Legacy 4CH 1000W RED AMP Car Audio...
1200 watt legacy amp not working right
your amp its protect by releas of [powerout]one this releys is dead you mast chenche
Apr 14, 2007 | Pyle Dryver PLAD213 Car Audio Amplifier
Car Audio & Video Logo
93 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
