1999 Pontiac Grand Am GT Logo
Posted on Aug 11, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Signal indicator brake lights and fm radio
I have a 1999 Grand am that seems to have a ghost .My signal lights and brake lights will at times work for a few minutes then stop working and a day later might work again for a few hours , The same with the fm radio every once in a while I can get in a station then after a few mins it go static . What is wrong with this stupid car??????
Anonymous
Level 2:
  • Expert 81 Answers
  • Posted on Aug 18, 2008
Anonymous
Expert
Level 2:
Answers
81
Questions
0
Helped
15173
Points
121
You may have an intermittent switch or possibly a shorted or broken wire. As for the radio, I'd yank it and put an after market deck in. GM radios aren't known for their quality. But, you could check the back of the radio to see if the antenna lead is plugged in securely.
Hope this helps.
My 99 Jeep grand Cherokee Laredo 4x4 has some brake light problems. The brake lights work fine during the day, but when I need to have my headlights on, my left brake light and tail light competley shut...
If you have any extra fuses, try replacing the ones for the head lights and tail lights. Make sure the fuses you replace are the same color as the ones you replace them with, that way the voltages are the same. Another issue is that a flasher could be going out.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/erik_3934b541f17c4e99
Taillight won't burn but turn signal works. Wrong bulb?
Some vehicles use a double filament bulb, if one of the filaments is 'burnt' out then the turn signal would work but the running/brake light would not work.
My 2002 windstar abs and brake lamp comes on then the turn signal indicator doe not flash when using the turn signals but tyey are workin
abs light ,trac cont light brake light all seems to happen when its damp or wet out now its got a new ghost in it worpping the left front rotor but ware seems to looks to be pretty even
2helpful
2answers
1999 jeep grand cherokee - brake lights and turn signals working but Right tail light out with all other lights on--HELP??? My 1999 Grand Cherokee has no parking lights in the rear. The brake lights work...
I have taken my car to many shops to solve this problem. Long story short your tail light has a bad circut and entire lamp must be replaced. (Lamp cost approximate $130.00)
1helpful
Got my stereo stolen out of my 2005 Grand Am, and now neither my turn signals or my hazard lights work. I looked for torn or pulled out wires, but the only four that were loose were all attached to a unit...
The only thing that should not be working would be the audible turn signal / hazard signal sound. When the turn signals are activated, the audio (radio) system generates a clicking sound that indicates the signals are working.
When the radio is missing, no sound is generated.
Are your turn signals working outside, but no sound or are the signals not working at all.
Let me know.
Regards,
4helpful
3answers
99 Grand Am Turn Signal Relay Actuates By Itself
This is a fairly common problem, to correct it you need to replace your flasher unit ($30) it is located directly behind the hazard light button on the dash.
My 2000 grand am anti theft radio is locked and I need help unlocking it
This solution is for a 1999 Grand Am SE am/fm radio with tape cassette player:
Ido not know if this works for other Grand Am products past or prior 1999.
If the lcd display of the radio indicates "LOC" if you do not see anything on the display the small light behind the display is out and you need electronics to go further. If LOC appears here is what to do:
First put the ignition key to the ACC position.
2- press the HR clock adjust button once only ; the display should read 000
3-push the HR button successively until you reach 17 on the radio displayffd4cd1.jpg 4-then press on the MN (minutes) button again until you reach the number 42
5-when the number 1742 appears on the display, press on the AM/FM button once and after on the POWER/VOL button to power up the radio.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
