Question about Vizio P2 42 in. HD-Ready Plasma Television
TV changes video source randomly
The TV is about a year old, and just recently developed an odd problem. My cable signal is sent to the TV via component cables, but all of a sudden, the TV decided that it is actually looking for the cable source and cuts out (since there is no cable source)
And the TV will keep searching for a signal that is not there!
Sometimes, you can use the remote to switch it back; other times it simply jumps right back to the missing cable source.
  • rabele Sep 01, 2008
    Actually, the problem seems to have shifted for a bit, and has just today resumed.
    For a while, the volume became the issue, and it would just start adjusting itself with no input from me.
    Tonight, it resumed the original problem
    Brigadier General:
  • 6,966 Answers
Hi again,
At your convenience, would appreciate an update on status of your concern.
Posted on Aug 11, 2008
  • Louie  Role
    Louie Role Sep 01, 2008
    Pls check if any of the buttons on the front panel of the TV is stuck pressed down.
I keep getting a blue screen on my Insignia TV. Cable box still shows the channel and I can change channels but nothing on screen. No sound either. This TV is not even 3 years old yet.
A blue screen indicates no video signal, if you change the video input to a DVD player is it still a blue screen? If yes then the TV is defective. If no then some how the signal is being lost to the TV from whatever source you use for watching broadcast TV
Apr 05, 2017 | Televison & Video
My grandma has recently been gifted a Polaroid TV as a Christmas gift. When the free view channels had the TV reset she lost the signal to an outdoor cctv camera for the building. We can't seem to get it...
probably the camera is either analogue or video . How was it connected to the TV via the Aerial Cable or via an AV input
If the camera is Analogue it may be on a ATV channel. So you would need to switch the input Source on the remote for the tv and check the ATV channels. If it was on a AV then try checking the AV input sources.
The free view channels is probably DTV source . .
Jan 23, 2015 | Televison & Video
What is wrong with my TV's Ypbpr input???
is this the only input where the TV does this? what happens when you disconnect this source? May be your source.
If the TV does this no matter what input, perhaps you have some leaky caps on the power supply PCB,. These can usually be detected by their bulging tops & usually self replaced (if you have the wherewithall) at a cost of less than $10.00
May 08, 2014 | Hitachi Televison & Video
Our cable company just went digital. Since then, we have started having a problem with our 4 year old tv. The screen freezes then goes black at random times. We turn the tv off and back on and it is fine...
First thought would be to have a service call scheduled to check your signal at the TV. The cable co will meter it out. Some companies can do it via phone conversation. I would venture a solid guess that's your problem. Hope this helps. If you still have an issue, post a comment and I can help you troubleshoot further.
Jan 09, 2011 | Pioneer PDP-4270XD 42 in. HD-Ready Plasma...
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Random HDMI audio and video drop out & video noise
Hello, I am sorry about your issue. I suggest that your receiver be looked at by a service center. Thank you. Onkyo USA
Apr 03, 2017 | Onkyo TX-SR606 Receiver
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
Tuning to pick up sky feed
Sounds like from discription the sky feed is set up for analog channel 6. With my TV-HVR-1600 card, there is an option in the wintv application when you click the menu button in the application that says channel suite. If you select this option, you should find and option for analog source. Select analog source in this screen and you should be able to manually add channel 6 in the box at the top of the analog souce screen. Also if you have the sky feed connected and you you click the scan button on this screen, it should detect automatically is the sky feed is on.
Aug 20, 2008 | Hauppauge WinTV HVR-1600 - ATSC HDTV...
Video Shuts Off - Green Light Flashes
Your lamp most likely needs to be replaced. Not uncommon for this to happen.
Nov 30, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
No signal when connected via hdmi to dvi on tv
ya nothing shows up is all black no sound nothing
Oct 27, 2007 | Sony Playstation 3 (PS3) Console
Vizio P2 42 in. HD-Ready Plasma Television Logo
100 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
