Question about Car Audio & Video
Holden Rodeo Radio code. - Car Audio & Video
4 Suggested Answers
SOURCE:
SOURCE: how do i remove the
Refer to: http://www.installdr.com/InstallDocs/Isuzu/PDF/478001.pdf
and extrapolate for your Rodeo.
Posted on Sep 06, 2010
SOURCE: Showing "code 2" , vehicle
CONTACT HOLDEN WITH THE VIN NUMBER AND THEY WILL GIVE YOU THE CODE!
Posted on Sep 11, 2010
  • 5013 Answers
SOURCE: i have a holden rodeo
it looks as though you are using the wrong code
The radio SERIAL NUMBER is required for a code
First remove the radio from the dashboard.
Then post the radio make+model plus all the letters+numbers on any labels,barcodes or stamped in the metal casing.
This information can then be used to see if a code can be calculated
Further useful removal information can be found here CLICK HERE
Posted on Jun 28, 2011
Can someone tell me where I can find the code for radio for Holden rodeo 2004 please
Through Holden They may need to remove radio for any reference numbers. There are just to many codes for anyone to keep track of. Contact your local Dealer Good luck
Apr 22, 2018 | Holden Cars & Trucks
Have a Eurovox radio in my holden rodeo ute,have the s/n how do I get the code to set the radio again
Hi Bill The easiest way would be to get your local Holden dealer to look into it for you. They may have to remove the radio if they are unable to obtain the correct information via there diagnostic tool, unfortunately the serial number will not give them the information they require. There will probably be a charge for this so I would advise asking what the cost would be. Unfortunately there are far to many codes for radios to be able to help you, also if one was able to just give a code out It would be the wrong thing to do for security reasons Good luck
Jan 02, 2018 | Holden Cars & Trucks
Get radio code for 2005 holden rodeo
You need to go through the Holden dealer to get it.
Feb 18, 2015 | Holden Cars & Trucks
Holden rodeo 3lt turbo diesel Fault code P0087 fuel rail pressure to low was the best way to correct the problem
2004 holden rodeo 3L ITD. dt P1120. Saying tps fault. Used scan tool to inspect data list an ECU is recieving signal perfect. Goes from 16% to 100%. Double checked TPS output from TPS plug and goes from 0.6v to 4v nice an smoothly. Im suspect on ECU because when i erased code and started engine it revved up to red line by itself but only did once. Any help would be great....
Jan 23, 2012 | 2005 Holden Rodeo
Car Audio & Video Logo
1,396 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
