Mixers
Problem for Mixers
Generic problem for all Mixers
Hobart a-200
By chrisfwood on Aug 11, 2008
My wifes mixer does not have first gear unless it is under a load then it will engage in gear but does not have the same power it use too ! , Can you help ! My local hobart dealer is a **** and only wants to sell new ones and told my wife that she had no business with this mixer for her wedding cake business ? ! I am a equipment tech by trade so if i know what to do and where to get parts i think i can do the repair thanks chris
Solution #1
posted on Sep 06, 2008
Not Rated)
steinfeld
Rank: Apprentice
Rating: 0%, 0 votes
HI CHECK ALL GEARS FOR A SHEARED KEY. IF IT HAS A ROLLER CLUTCH, COULD BE WORN ROLLER CLUTCH OR SPRINGS MADE OF SPRING STEEL BEHIND EACH ROLLER IN CLUTCH FATIGUED. YOU CAN CAREFULLY RUN MACHINE JOGGING ON OFF SWITCH WITH GEAR CASE COVER OFF AND CHECK GEAR ROTATION FOR SHEARED KEY. IT'S ONE MESSY JOB!!! SOMETIMES NUT ON TOP OF MAIN SHAFT UNDER CAP OUT OF ADJUSTMENT. SHOULD BE APPX. 1/2 TO 1 TURN FROM TIGHTENED. HOPE I GAVE YOU SOME ASSISTANCE, JOE
Was this helpful?
Yes
No
Popular Solutions for Mixers
Questions and Unsolved Problems for Mixers
Answer
where can I buy the Kenwood Stand Mixer In Canada BC
Answer
Which Kitchenaid Mixer is the best 325 watts or 450 watts?
Answer
I didn't lock the bowl, turned it on and it bounced like crazy then the slide bar that locks the top... (More)
Answer
i have a sun beam mixer model #2350 the motor runs but the beaters don''t move what has to be done... (More)
Answer
how old is my mixer Serial # 11-1022852 , Its A H660T
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Mixer Experts
Top Small Appliance Repairmen
in , OH
(316) 283-4211
(316) 283-8664
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
