Question about White Sewing 1521
White machine bobbin tention ajustment
There is no screw on the bobbin holder. Where do I ajust it? It is a white with model #1563.
How do you thread it ?can you give intructions?
Posted on Nov 08, 2008
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
How do i adjust the bobbin tension? white 935
There is an adjustment screw on the bobbin holder. Tighten if the tension is too loose, or loosen if too tight, but do not completely unscrew and lose the adjustment screw. I also suggest if you don't have a manual that you download one from: Enter the number "935"
May 17, 2011 | White Sewing 935 Mechanical Sewing Machine
Bobbin thread makes furry bottom stiches, how do I fix this?
Bobbin holder tention to tight , on the bobbin holder there is a small screw loosen it a bit.
May 11, 2010 | Sewing Machines
How do you set the tension on a drop in bobbin?
On bobbin holder there is a smaal screw tight or loosen to set tention.
May 10, 2010 | Kenmore Drop-In Bobbin 505S-21BH...
201 bobbin problems sews great but the bobbin thread will double up sometimes.
On the bobbin holder there is a smaal screw it needs to be tighten in order to adjust the bobbin tention.
May 10, 2010 | Sewing Machines
Needle thread tangling around bobbin
There should be a screw on the side of the bobbin also a screw on the bobbin holder so that you can ajust so you can time the mechin
Sep 14, 2008 | Kenmore 15516 Mechanical Sewing Machine
Brother VX-1120- The needle is not picking up bobbin thread.
I had the same problem with my brother vx-1120 sewing machine. I set the needle to lowest position by using the hand crank. Then I loosened the knerled set screw that holds needle in place. Then I moved needle shaft till the eye of needle is just lower than the hook on the shuttle loop maker. It made my mechine work. There are instuctions for ajusting timing on machine but I think these mechines are built to not fix and throw out. Just because there where no ajustment marks at all on machine, any machanical machine will needed to be ajusted sometime.
Jul 08, 2008 | Brother CS-8150 Computerized Sewing...
White Sewing 1521 Logo
95 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
