Dvd player when the disc in inserted, it says "no disc" the last time it was used it worked just fine??
    Genius:
  • 1,689 Answers
This is a little risky, but you will be able to check if it is the lens causing this.
open the appliance up, then play a dvd, check if the lens is moving supposedly it will when initailizing the movie, if not, the lens assembly could be stuck
Posted on Aug 11, 2008
    Genius:
  • 1,847 Answers
The drive is not reading the disk, clean the lens using a cd len cleaner and then try,,
  • Legin Varghese
    Legin Varghese Aug 11, 2008
    Make sure the cd or dvd that you are tiring to play is compact able with the player.
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
FUNAI B2735 DVD/VCR COMBO
Have you tried a blank DVD with lower speed say 4X? Or for that matter, some other brand of blank DVDs?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 28, 2008 | Funai PY90VG DVD Player/VCR
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Irregular performance...
sounds to me like your laser is gone.
Some discs are harder to play than others as some are multilayed, check online as to whether it is suitable to use laser cleaners these are like discs with soft brushes attached, you can get them from pretty much any computing place, i wouldnt know whether its sensible to use on a DVD player, but couldnt hurt anymore eh?
Jan 08, 2009 | Sony DAV-S500 System
Won't play any DVDs
I mostly first always recommend a dvd lens cleaner to clean the lens incase there is something on the lens.
Is the player underwarranty? the lens may have a issue other than dirt and might need to be replaced.
What happened last time it worked fine? try unpluging the dvd player for 5 minutes and try again.
Jan 04, 2009 | Toshiba SD-6980 DVD Player
Disk Error, CD only
It may not recognize the CD if it is a copy. try an original CD and see if it works.
Nov 30, 2008 | Onkyo DV-C601 Multi-disc DVD Player
Navigation
I have found that copied dvd's don't always work properly and even the slightest blemish or scratch renders it inop also it is illegal to sell a copied disc as it infringes copyright, I understand that the genuine disc's are expensive but you get what you pay for.
Feb 24, 2008 | Pioneer AVH-P6500DVD Car DVD Player
"No Disc" error message
remove the cover of the unit and try to clean the lens with a soft clean dry cotton swab or if you have a compress air cleaner, just blow it. most of the time cleaning can solved this kind of problem. good luck!
Feb 21, 2008 | Panasonic DVD-S29 DVD Player
Televison & Video Logo
41 people viewed this question
Top Televison & Video Experts
