Question about Kenwood Car Audio & Video
How do i set up my bluetooth for my kenwood kvt-512. im trying to find the bluetooth app in the settings
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
The Kenwood 512 works with the Kenwood KCE-BT200 module. You need to have this box plugged into the main unit to work. If not, then Bluetooth will not be available. When you do have it connected, use your cellular phone to initiate the connection. when prompted on your phone for a passcode, it will be 0000. After successfully pairing your phone to the unit, you can access the telephone menu by holding the "FNC" key on the front of the Kenwood or pressing "TEL" from the source screen.
Posted on Aug 11, 2008
How to pair your phone to the bluetooth on th kenwood kvt-514
Go into your Setup menu and scroll down to bluetooth settings.
From here you should see a screen that says "HFP connect device", "A2DP connect device" and "Receiver pin code".
Press the "Set" button to the right side of "A2DP" and it should bring you to another screen that says Pair device.
Go onto your phone settings and make sure you have your bluetooth setting on your phone set to "make discoverable"
Press the search button on the Kenwood unit on the right side and it will start scanning for available devices in the vicinity
Also press the Search button on your phone so it also starts scanning.
Next you should get a message on both your phone that shows the Kvt-514 and also a message on the Kenwood that shows either the model of your phone or your "nickname" (if you named your phone)
Select the Kvt-514 on your phone and it will prompt you for the pin code that was on the first bluetooth setup screen...most likely 1111 (you can also set a different pin code using the "set" button to the right side of the "Receiver Pin Code" on the first bluetooth setup screen)
Enter the Pin code and select "Pair" on your phone.
You should get a confirmation on both the Kvt-514 and your phone that they are connected and you're good to go.
Apr 02, 2011 | Kenwood KVT-514 Car DVD Player
I need the site for kenwood kvt-512 update
try this I use this for getting user manual or leave them a question Good Luck!!!!
Techman
http://www.kenwood.ca/Support
May 14, 2010 | Kenwood KVT-512 Car DVD Player
Password code for kenwood kvt-512
The password code is something you set yourself by going into the settings. If there is a security code already set up it is because: A) you bought it used and the previous owner set it up...just ask them, or B) It came new from the factory with this settings error...call kenwood, or the place where you purchased.
Aug 14, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood KVT-512 with bluetooth setup troubles
With my BMW I had to connect both the solid blue (pwr ant) wire and the blue with white stripe (p conn) to the solid blue wire from the factory harness.
It isn't obvious that either of these are needed as the KVT-512 has it's own power supply but the way most factory power amps are installed the power from the KVT-512 is not used and the car manufacturers power amp needs to be turned on.
If you are listening to the radio the pwr ant wire will turn on the power amp, this didn't seem obvious because the BMW doesn't have a power antenna. And when you are using the DVD player or the iPod connection you need the P Conn wire to turn on the car power amp as the ant pwr is disabled because you are no longer using the radio and Kenwood assumes you will not need the antenna so no power to this lead.
Solder all three wires together and you should have sound all the time.
Mar 02, 2009 | Kenwood KVT-512 Car DVD Player
How do i connect my itouch to kenwood kvt-512???
Hi there! You need a Kenwood KCA-iP300V iPOD VIDEO DIRECT CABLE.
Feb 09, 2009 | Kenwood KVT-512 Car DVD Player
Kenwood kvt512 code
forgot my code how can i reset it
Jan 27, 2009 | Kenwood KVT-512 Car DVD Player
Need installation instructions
do you still ned the intructions on how to install your kenwood kvt-512??
Nov 20, 2008 | Kenwood KVT-512 Car DVD Player
Car Audio & Video Logo
214 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
