Question about JVC AV-56WP30 56" Rear Projection Television
SCREEN IS GREEN
MY SCREEN IS SHOWING PICTURE IN GREEN, WHAT COULD IT BE?
    New Friend:
  • 50 Answers
Check if there is any cold solder/ loss connection in the CRT board, also check the transistors in the CRT and resistors.
Posted on Aug 11, 2008
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
My 42 inch sylvania hdtv screen is broken and not showing a picture
If the display panel (PLASMA DISPLAY PANEL--PDP) is damaged or broken etc it is fatal as the cost of the part alone will exceed the cost of a new set.
Oct 15, 2012 | Sylvania 6842THG 42 in. Plasma HDTV
My LG HD tv screen suddenly went green. sound is
I disagree with info provided, if screen of your LG lcd tv becomes green that means inverter board is working and lcd tv does not have convergence ICs.
Please unplug tv from ac wall socket for minute to get it reset, replug back in and turn it On and check its picture.
If still showing green screen then change input source with remote, if tv shows same green screen on all inputs that means its either lcd panel problem or digital signal processor got bad loacted on main board. Local tv repairman is needed to confirm and fix it.
Thanks.
Jul 21, 2010 | LG 42LC2D 42 in. LCD HDTV
My RCA, HDTV projection screen tv is showing double red and green
Ur tv have a convergence problems,it dead.The 2 STK convergence ICS are defective,must be change and it supporting resistors.The shop will fix it for u for $300-350 for parts and labors.
May 09, 2010 | RCA D52W19 52" Rear Projection Television
Black is turning green on screen
The green cutoff level has drifted and the green gun is not turning off completely. You MAY have a user adjustment available.
Oct 23, 2009 | Philips Televison & Video
I have the same problem(redish screen with no green at all)
Does Tube Light up? with TV on Look down into Tubes and see if picture is clear or you can bearly see picture or not at all Your Projection fliuld may need changing Ive seen where tubes are still lighting but No picture showing inside tube---- Bad Coolant Fuild Call Mats for fuild and for Tube if thats what it is Call Encompass 1-800-638-3328
Oct 05, 2009 | Panasonic PT-47WXC43 47" Rear Projection...
Screen not showing picture
check on vertical ic supply is it 24vdc otherwise try to replace the ic first
Jun 01, 2009 | Symphonic ST413C 13" TV
50 inch hitachi green screen all the screen has a strong tint of green tried picture adjustment dont even get it close
I have the the same problem with my 60 inch Rear HD projection Hitachi. The bad part is we just bought a bulb 2 months prior to the green showing up.
Jul 02, 2008 | Televison & Video
Check and make sure you are on tv not video. Unplug and replug all the game systems or other things you might have plugged in your tv. And if those don't work make sure you are not on input channels (input1, input 2, and do on). If still you are having problems go to the tv menu and and make sure you are on antenna if you have a antenna or cable or satilite if you are on one of those. I hope this helps!
Apr 11, 2006 | Thomson AQUA14 TV
JVC AV-56WP30 56" Rear Projection Television Logo
59 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
