Question about Whirlpool GEW9200L Electric Dryer
Dryer stops running and displays E1
My Whirpool Duet dryer, model number GEW9200LW0, stops drying clothes after a couple of minutes of being on and displays an error code E1. I have the same problem. I have checked the vents, they seem to be working fine -- I can feel air coming out of the vent on the outside of the house and there is no lint blocking it.
  • 2,071 Answers
WHAT IS WRONG WITH YOUR DRYER?
dryer stops running and displays E1 - small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Versiodryer stops running and displays E1 - redarrow.gif>redarrow.gif
Gas Maytag Style
redarrodryer stops running and displays E1 - redarrow.gif= Gas GE Style
Electric Whirlpool Style Version 1
redarrow.gif Electric dryer stops running and displays E1 - redarrow.gifyle Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Posted on Aug 11, 2008
My duet whirpool electric dryer keeps stoping before my clothes are dry
Make sure you are not using a timed drying setting. Use one of the pre programmed functions on the dial. These settings are meant to use a sensor and stop when the clothes are dry. If the problem continues on one of these settings, there is likely a problem with the sensor or your heating element
Sep 15, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
I ha a whirlpool model #GEW9200LW0 that runs and then stop after abot a minute and flashes E1
Hello there and thank you for choosing fixya
The dreaded E1 error code is telling you that the thermistor on the dryer has failed and needs to be replaced
Dryer thermister - Located on the blower housing next to the thermal fuse.
Part Number: AP3919451 made by WHIRLPOOL
HERE IS WHAT IT LOOKS LIKE
Aug 04, 2011 | Whirlpool GEW9200L Electric Dryer
Code E1
E1 or E2 Thermistor Failure
The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Take the top off the dryer and inside you'll find the "tech sheet." It has instructions for removing the front panel and locating the thermistor.
Apr 21, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Electric Duet Dryer starts, then stops after about 10min.
Your dryer is overdue for retirement.
Jan 29, 2018 | Dryers
My dryer starts runs for a few minutes then stops with an E1 on
clear the exhaust tube of lint and make sure you have good air flow out of house and also if you happen to keep anything on top of your dryer please i say this to all NEVER keep anything on top ot it. Clothes or stacked items on top insulates your cabinet and makes dryer run improperly. Nowadays with sensors and all, it fools your machine when you have stuff on top of it. Good Luck
Jan 06, 2009 | Kenmore 73952 Gas Dryer
Whirpool Senseon stops mid-cycle
there is a thermostat called a thermister on the blower box that will do that(run for few minutes and shut off) get the model number off dryer door or on inside dryer door wall ,go to sears .com click on parts put in model number and it will show you exactly where everything goes,let me know how you do-mike
Oct 02, 2008 | Whirlpool LER4634J Electric Dryer
Whrilpool Duet Dryer - Model GEW9200LW0
The repairman just took the front off my dryer and cleaned the dust from the components, now it works just fine, and I had the same problem as you.
Jun 14, 2008 | Whirlpool GEW9200L Electric Dryer
E-2 error code on whirlpool duet dryer
“E2” flashes if the thermistor has shorted.
The thermistor monitors the exhaust temperature
and cycles the high-limit thermostat on
and off to maintain the desired temperature.
1. Turn the dryer off but keep the electrical
supply connected.
2. Make sure that the dryer is empty and that
the lint screen is clean.
3. Close the dryer door.
4. Select Heavy Duty, Timed Dry, More Time
or Less Time, End of Cycle Signal (Louder)
and Start.
5. If error codes E1 or E2 flash on the display
after 1 minute and the dryer turns off,
the thermistor, or the wire harness, is either
shorted or open. Check the wire connections
at the thermistor or the machine
control electronics board. If wiring checks
okay, replace the thermistor.
6. If the dryer seems to operate normally, remove
the exhaust vent and start the dryer.
7. Select the desired temperature cycle to be
tested, and select 20 minutes of Timed Dry
heat using the More Time or Less Time
pushbuttons.
Feb 25, 2008 | Whirlpool GEW9250 Electric Dryer
Whirlpool GEW9200L Electric Dryer Logo
927 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
