Question about Pantech Duo Smartphone
Can't hear caller. phone slides open both ways at once.
Hi, I have 2 questions... I can't hear the caller tho they can hear me with a slight buzzing sound in the background.  How do I fix this?
Also my phone slides open both ways at the same time.  Is it supposed to do this?  Does this have anything to do with the hearing problem above? Thanks,  jas
  • Blondie_4 Apr 18, 2009
    My daughter is having the same problem with hers. The caller can hear her talk, but she can't hear them. Her phone also slides open both ways at once.
    Hope we can find an answer!
Your phone is not suppose to open both at the same time....
Posted on Sep 23, 2008
SOURCE:
My nokia 6700 slide callers can't hear me
If callers cannot hear you, you may have to replace or repair the mic. Since you can hear them, the speakers are working.
Dec 01, 2011 | Nokia 6700 Slide Cell Phone
I can hear callers but they cant hear me
Hi sounds like your mic has stopped working its quite an easy repair you can get a mic from ebay, on the bottom of your phone under the keypad, the keypad clips out theres two screws undo them and slide the plastic piece off, your mic is the part with the two gold bits on pull it out with a pin remembering what way it goes in then put your new one in and put it back together.
Dec 21, 2010 | Nokia N95 Cellular Phone
I am able to hear incoming call i.e. No voice of caller...on e72 nokia
Hi, when you can't hear the voice of the caller calling you ,it means that the earpiece of the phone which is located slightly above where the screen is. the earpiece is not ok and it needs to be replaced.
When you replace i,you will now be able to hear the incoming callers voice.
Have a nice day.
Sep 26, 2010 | Nokia E72 Smartphone
My Cect P168 I can hear caller but they can not hear me? Everything else works perfect? What could be the problem?
These phones have been known to have some mic problems (usually buzzing) when the mic's connector wire becomes loose from the mainboard. This happens most likely during shipment of the phone.
Though it definitely sounds as though the mic is not working, just to be more convinced it is the mic, try doing a voice recording to see if that fails as well.
Unfortunately the only 2 ways of fixing it are taking the chance yourself to take the phone all the way apart without breaking it to get at the mainboard connection and secure the mic wire, if that's truly all it was, or to send the phone back for replacement.
Mar 23, 2009 | Dual Electronics CECT P168 Cellular Phone
I can't hear the caller on my Blackberry Curve
my caller hears me but i dont hear them unless i use speaker phone how do i fix this
Mar 09, 2009 | RIM BlackBerry Curve 8310 Smartphone
Buzzing tone. Can barely hear caller's voice because of the buzz
Two things to look at:
First, check the base station isn't too close to some interfering item of electronic equipment - try moving it to see if the problem diminishes.
Second, unplug the cordless phone and put a traditional corded phone in instead (if you don't have one lying around, it would be a wise investment to get one, otherwise you'll be without a phone service if your power goes out). If the buzz is still there, the problem lies with your line rather than with the phone (and that's the TelCo's problem, not yours).
A.
Nov 28, 2008 | Uniden Cordless Phone
Cannot hear callers/callers cannot hear me/buzzing & crackling sound when connected
try pairing the bluetooth device to another phone, i had the same issue, i used a different phone for testing. it works, so i paired it to my phone and it also works
Dec 12, 2007 | Motorola Mobility H700 Wireless Headset
Pantech Duo Smartphone Logo
156 people viewed this question
Top Pantech Computers & Internet Experts
Ekse
Marvin
Marvin
Gadget Corner
Gadget Corner
Are you a Pantech Computer and Internet Expert? Answer questions, earn points and help others
