Have a Samsung SyncMaster 930B just went blank and a floating message says check signal cable, digital. I have check cables and find no problem....what else can I do?
It means that the main board on the monitor is no longer functional you need to replace it or take it to a technician.
Posted on Mar 28, 2012
  • 65 Answers
I would check the video card, see if it's still good. also check for your drivers and update if necissary.
Posted on Aug 11, 2008
VGA Will not connect
Have you checked if the SyncMaster is compatible with a Mac? I do not use Macs, so I do not know. In the old times you had to buy everything Apple. You could try looking for an adapter to convert VGA or Digital to Mac Video.
Nov 27, 2013 | Samsung SyncMaster 2253LW Monitor
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
No picture...check signal cable Analog message following movement and re-connection
Check for bent pins in the signal cable. Unplug the cable from the back of the computer and look at the end, you will see small pins sticking out. We have seen many times when people move systems that a pin will get bent over and when you plug it in to the PC it gets flattened out all the way. If you find a bent pin you may be able to straighten it out with a pair of needle nose pliers but if it breaks you can get a replacement cable for $6.50 shipped,
I hope this helps, if so please rate our solution.
Corporate Computer
Apr 26, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Screen went out and flickers
Try swapping PC input cable with replacement.
Try Monitor on another PC.
If still no go check the manufacturers warranty.......some are 5 years.
Sounds like internal fault.
Dec 03, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung 930b analog to digital input
Did you check for new drivers to both vid card and display? That'd be the first thing to try.
May 30, 2008 | Samsung SyncMaster 930B 19" LCD Flat Panel...
New Monitor Installation
Does your computer have more than one video adapter installed. If so, try plugging into the other one.
Jan 13, 2008 | Samsung SyncMaster 216BW Monitor
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
