I cannot connect a dell 720 printer to dell laptop Inspiron 1501 (Vista). It says it is installed but a message comes up that communication is not available.
    Novelist:
  • 158 Answers
First, shut down your computer and priner. Unplug both from the wall outlet, Unplug the printer from the computers USB receptical. Next, plug both the computer and printer back into the wall, and turn on ONLY THE COMPUTER. After the computer is fully initialized, plug the printer into the computer's USB socket and turn printer on. A small window on your screen should say:NEW HARDWARE FOUND. it will ask if you want it installed, click on YES. and just follow the onscreen instructions, and make sure your printer driver is compatible with VISTA..To check, go to http://support.dell.com and left click on WINDOWS VISTA SUPPORT. Left click on LATEST VISTA DRIVER UPDATES, and follow the onscreen instructions to check what you have now, and what you may have to download.. If, after downloading and installing VISTA COMPATIBLE SOFTWARE,you still get the communication message, try this: On the windows screen, left click on START. left click on CONTROL PANEL, then left click on PRINTERS. Find your Dell printer icon and RIGHT CLICK on the icon.. On the drop down menu, left click on PROPERTIES. On the Properties window, left click on the PORTS tab. Make sure USB VIRTUAL PRINTER PORT FOR DELL is checked. If no, select that port, left click on the check box, also check ENABLE BIDIRECTIONAL SUPPORT and ENABLE PRINT SPOOLING boxes. Then left click on APPLY, then Ok. The Dell printer icon should show READY. Try a test print to check operation.
Posted on Aug 11, 2008
SOURCE:
Dell 720 printer won't print.
The problem could be because of ONE out of FOUR problems listed below. Try the steps recommended and it should fix the problem.
Thanks,
Abhishek
Jan 03, 2010 | Dell Inkjet 720 Printer
Error message 0141
This error comes when the system is not detecting the hard drive. just remove the battery and hard disk drive and connect it again.
Sep 15, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
My Dell 720 printer won't work withmy dell 1521
All printers are compatible to a degree.
What operating system are you running on your dell 1521 laptop? What drivers are supported on your Dell 720 printer?
If you are running Windows Vista on your laptop and there are only drivers for your printer up until Windows XP and nothing is on Dell's website for your printer in terms of drivers, then you can only try to run Windows Vista in Compatibility Mode.
If this doesn't work, then you'll need to get a new printer.
Aug 19, 2009 | Dell Inkjet 720 Printer
Drivers for dell inspiron 1501 with windows xp in it
No worries.I can help u with that.This link will give u the compatible drivers for ur system : http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=INS_PNT_1501&os=WW1&osl=en&catid=&impid=
Just beside the picture of the laptop in the website,u have the link which will help u installing the drivers in the right sequence. U can also visit support.dell.com for the same.
Mar 17, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
Computer will not communicate with printer
Go out to Lexmark web site and look for a vista update in their software download section. So this should solve your problem.Most of the cds which come with equipment do not contain vista software and drivers.
Aug 06, 2008 | Dell 962 Photo All-In-One InkJet Printer
Problem connecting printer to laptop
hi I'm trying to connect my lexmark printer to my compaq laptop
Sep 08, 2007 | Dell DJ MP3 Player
142 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
