Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
No Sound Sound very faint turning the tv up all the way. Same using external speakers.
    New Friend:
  • 50 Answers
There is leaking capacitor in the audio circuit or defective IC amplifier
Posted on Aug 11, 2008
SOURCE:
Zenith inteq iqb50m90w has no sound, hooked up cable box with component cables
To be honest I do not really understand clearly your issue so I will pose a few questions that might clear things for me up:
1. No sound from internal speakers.
2. Speakers have be checked and are not open, disconnected or switched to external or variable audio out only.
3 A DVD or similar connected to a rear video and audio input has no sound.
4. The set had sound when hooked to the bose system.
Do I understand correctly or did I miss something?
If all the above is correct the set has a audio output problem (old trick is put ear directly to a speaker and see if anything, a buzz, faint sound or nothing at all.)
Dec 04, 2012 | Zenith IQB50M90W 50" Rear Projection...
CANT FIND A EXTERNAL SPEAKER SET
before attempting that:
Look in set menu to see if speakers are switched ON or OFF.
Check on SET and a Box if used that sound is not turned off or low.
If set has hookup for external speakers is external or internal selected.
Does the set have sound when a DVD etc. is connected via one of the rear sets of audio/video input jacks?
SD TECH
Apr 24, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
The sound is not working on my Hitachi L42Vc04U tv
Before you assume the set has a audio problem here are some other possible causes to at least explore:
Speakers in the set (menu) are switched off.
Volume and set and or box turned way down or muted.
Internal/external speaker setting set to external
Audio works with a DVD etc connected to rear a/v jacks
Set suffered a power outage=unplug set and boxes and wait--plug both back and see if fixed or not.
Set does display on screen audio level or not--same for a box if used.
Check all audio settings in set and box carefully
If all these fail do you hear a hum or very faint audio from the speakers?
Apr 11, 2012 | Televison & Video
I have lost all sound on my tv. You can hear snapping or popping but the sound is real faint on highest setting.
I am sorry to hear about your misfortune. Unless you changed some sound settings right before that happened then the likely cause is that your tv's internal speakers have blown. Which will cause that really faint sound even when the volume is all the way up.
If your TV has an audio out connection you can try hooking it up to surround sound or a receiver with some speakers. You may be able to use your tv this way and get sound.
Otherwise you will have to make use of your warranty if the TV is still covered. If not then there is nothing more I can suggest. Repair cost might be more than hooking it up to an external sound system.
Post back if you have any further questions or comments.Thank you for choosing Fixya.
-Daniel
Oct 17, 2010 | Televison & Video
How do you use external speakers when you have no sound on the tv
Bring up the TV menu on screen by pushing the menu button on the remote that came with the TV, access the audio menu or you may have to select the set up menu(different TVs have different menu systems) but what you want to look for is make sure the TV speakers are turned "ON" TVs of today give you the option to have the TV speakers "ON" or "OFF". If all is well there, in order to connect external speakers to your TV you would have to send the audio signal out of the TV to an audio receiver/amp by way of RCA style patch cords. TVs these days do not have an internal amp that is capable of powering external speakers, that is why you do not see speaker wire terminals on the back of your TV. Good luck !
Jan 06, 2010 | Polaroid FLM-323B Television
Vostro 2510 microphone volume is faint even with an external mike. I have volume properties turned all the way up. Please help.
I have never seen a laptop with strong speakers, including the 3 in my family. It is my feeling that reinstalling Win XP would not accomplish the results you are looking for. That is why I asked which kind of speakers you are using. In my case, I have used a set of Logitech external powered speakers with a sub woofer when I'm home with the laptop and the difference is day and night.
Sirwriter
Nov 10, 2009 | Dell Sound Blaster Card
I have a panosonic plasma tv when i switch it on it tell me there is a speaker short and then switches it self of model number pdp507xda help
It's the internal circuitry problem. Try muting it and put audio connection to other speakers if it repeats, your TV audio system is internally dying.the audio connections has to be checked and faulty components should be replaced.
1. Speaker short.
Open it up and check the speaker connections. ONLY if you have basic skills working on electronics and don't have a warranty.
2. Sound Volume "Leveler"
Look in your sound option menu for a sound "balancer" option and turn it off.
If this doesn't work disable the sound and invest in that surround sound system (external speakers solution of your choice)
try this.for first unplug the main power cord of the tv for couple of minutes and then reconnect it.also before reconnecting the power cord of the tv again remove all the external device wires connected at its back such as dvd player/vcr etc etc.just connect only tv wire and check out.if still the same problem then its quite possible that the capacitors and ic on the audio circuit board are getting short in between so the circuit is not getting completed and cutting in between so the tv starts and turns off. if the tv is connected to externalk speakers then check out without connecting the external speakers and see whether it works.if it works that means tv is perfect.but if tv is having inbuilt speakers that its confirm problem with inter audio circuit of tv.so try connecting external speakers at the back of tv and check out.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Oct 20, 2009 | Panasonic PDP-428XDA 42 in. Plasma TV
I hooked up my stereo amp to my external speakers that were also still hooked up to my tv. now I don't get any audio from my tv just a high pitch sound. Is this an easy fix?
Hi, I can help. It sounds like the TV internal speakers were turned off so that the only speakers to have sound were the external ones. Go to your menu and find the sound area. There you can tell the TV to send sound to the internal speakers once again and not to external.
Jun 21, 2009 | Televison & Video
Problem with geting sound out of my external speakers.
adjust your sound or check the volume on the speakers itself, or try adjusting the sound on the computer, and check the sound card
Sep 02, 2008 | Audio Players & Recorders
Wish to use extension speakers with Bush IDLCD32TV22HD
You will need to get into menu and enable the external speakers. Some older TV may have a switch at the back to turn the external speakers ON.
Feb 25, 2008 | Televison & Video
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
