Question about Panasonic NN-S954WF Microwave Oven
Voltage in home down when start microwave
Why the voltage in my home goes down when the microwave is on?
  • Panasonic Master
  • 9,098 Answers
Either the outlet for the microwave is not on its own breaker (which it always should be) or there is a loose screw connection or oxidation in the circuit breaker panel.
If the bad connection is on the neutral wire, this can create a dangerous condition.
You should measure (or have a pro measure) your voltage in various outlet s in the home.
If you have low voltage on some and high on others, you have a faulty neutral.
This can be serious. It should be checked.
Posted on Aug 12, 2008
Microwave shorts out when start button hit
There are a few possible causes. The high voltage trafo is defective. The voltage doubler diode or capacitor are defective. (short). BE EXTREMELY CAREFULL WHEN WORKING ON THESE PARTS, THE VOLTAGES THERE ARE LETHAL !!
Oct 12, 2014 | Microwave Ovens
Light goes on, turntable goes round, but doesn't heat
It's most likely the magnetron. These can be replaced but it is a tricky home repair and needs precautions against residual high voltage on the capacitor. Replacement magnetrons are usually quite expensive, so it may be time for a new oven.
Mar 13, 2014 | Sharp R-242 Microwave Oven
Tappan microwave vent motor and cooktop lights not working
see this test . God bless youThis microwave oven repair is only for over the range(OTR) models. First, with microwave still installed, gain access to the control board and check for voltage from the fan relay. If you are not getting voltage from the fan relay on the control board, and your display says fan is on, then you need a new control board.
Again, this microwave oven repair is for OTR models. If you know your light bulbs are good and your display is telling you that they should be on, check the light relay on your control board. If no voltage is found at that relay, then replace the control board. Otherwise your problem is in the light socket, wiring, or wire connectors. You can get to all of that by unscrewing 6-8 screws under the unit and taking the bottom panel off.If voltage is present and the wiring that you can see looks good, then you will have to take the unit down and test for voltage at the fan itself. If the voltage is present there, then test the motor itself and/or start capacitor for the motor. The fan motor assembly will slide out of the top of the unit after you take it down and unscrew 2 screws. Below, in the list of component testing, you will see how to test the motor and start capacitor. get the part from
www.repairclinic.com
Apr 04, 2013 | Tappan Microwave Ovens
Magic Chef Microwave Shutting Down Problem in RV
your micrwave may run fine at 110 but it draws more power than the generator is putting out when the magnetron kicks on which is the part that creates the microwave causing the food to heat up. In other words the amperage is too low for the microwave. Amperage is what matters not voltage.
Apr 12, 2009 | Hotpoint RVM1435 Microwave Oven
Microwave fuse mystery
AHD_NZ
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
Guest
We're happy to help and we appreciate your thoughtful rating of our answer.
May 28, 2008 | Microwave Ovens
Panasonic dimension4 genius microwave oven
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing high-voltage capacitor and diode. If that doesn't solve it, then it needs a new magnatron. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 31, 2008 | Microwave Ovens
Spacemaker XL1400 (Microhood)
High voltage parts are suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Jan 31, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave not heating up
Magnatron is suspect. Need to put a voltmeter on the input (primary) side to the high-voltage transformer (big heavy iron thing in there) Should be getting 120Vac when it goes to cook cycle. Don't touch the other (high voltage) side of this transformer. If the power is there, you are looking at replacing either the magnatron or the high-voltage capacitor and diode. Its affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Jan 03, 2008 | Magic Chef CMV1000B Microwave Oven
Today is the day my microwave stopped working
If the power is there, you are looking at replacing the magnatron.
Could also be the high voltage capacitor or diode.
Jan 02, 2008 | Sanyo EM-Z2001S Microwave Oven
GE microwave
This is usually an indication that the magnetron has gone bad, or something in the high voltage network controls the magnetron. Any one of the following components could be at fault: 1. Magnetron 2. High Voltage Transformer 3. High Voltage Diode 4. Magnetron Thermal Cut-out 5. High Voltage Capacitor 6. Interconnecting wiring I do not advocate taking any voltage measurements inside the High Voltage section of a microwave since the voltages can be as much as 14,000 volts or higher. If you are savvy enough to attempt yourself, WITH THE MICROWAVE UNPLUGGED, you will need to disassemble the unit to get to the high voltage section and take resistance readings. The magnetron or diode are likely suspects. If the magnetron or the transformer are bad, the repair costs can meet or exceed the price of the oven. Let me know if you need further assistance.
Jul 16, 2007 | GE JE1540 Microwave Oven
Panasonic NN-S954WF Microwave Oven Logo
32 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
