The television screen isn't centered. - Televison & Video
    New Friend:
  • 50 Answers
If you have a little skill in electronics you can do it yourself, try to adjust the vertical linearity located in the board of the t.v it is a trimmer resistor...
Posted on Aug 11, 2008
My center speaker connection is faulty?
There should be some fault to internal output circuit.
May 11, 2013 | Philips Audio Players & Recorders
Lines on screen
if the screen isn't working then the only solution is to buy a new television. I apologize for the inconvenience.
Hope this helps!
Apr 09, 2012 | Samsung UE37B6000 37 in. HDTV-Ready LED TV
Remove a message at the top of my screen
http://forum.electromaniacs.com/files/file/18962-lg-42ld450-service-manual/
http://www.manualowl.com/p/LG/42LD450/Manual/78365
Hi well this may simply be a setting of the onscreen display or it indeed maybe a "Fault" In any event I have given you the links above for a service manual and the user manual too.
Please use these to troubleshoot the issue, first check that it isn't an onscreen display setting that needs to be turned off, if it isn't this then it maybe the character generator with the microprocessor in the set that has faulted?
However if you cannot, or do-not wish to DIY, then the very best thing you can do to effect a repair is to contact an LG local or head office and ask them for a referral to an authorised service center, when in contact here and when face to face then ONLY first ask for a "Quote" as to what's wrong and prospective costings and go from there.
Oct 09, 2011 | LG 42LD450 42 in TV
I have a red and green line running up the tv. It isn't overbearing but the tv is only 5 months old.
You have a bad panel. Take your TV to a service center, you are covered under a 1 year warranty.
Jul 28, 2011 | Apex Digital Televison & Video
Loose cable connector- no feed
If the ANT or CABLE in coaxial connector is damaged, it often requires that the entire tuner module be replaced. Sometimes you can solder a new jack in, but it isn't a guarantee. You might wish to contact a local service center.
Jul 11, 2011 | Televison & Video
I purchared the philips screen cleaning gel can it be used on the outer part of the tv as well?
Screen cleaning gel isn't that strong as it is intended for sensitive screens so go ahead it shouldn't cause any damage
Elliott M
Jul 10, 2011 | Televison & Video
I have a 19in Emerson Flat Screen TV that I am using as a PC Monitor and it isn't using the full screen. How do I fix it to use the whole screen?
You might not be able to. If the screen size doesn't adjust with the wide/view mode/picture format button on the television remote control you have to change the resolution on the pc. You right click on an empty spot on the desktop, choose properties, and then choose the settings tab. A lower resolution will cause the image to fill the screen but the icons get really big. The image isn't as refined. However you may be able to play around with it enough to find a good enough resolution and a view mode with the Emerson remote that will work out for you (a combination of the two).
May 31, 2011 | Televison & Video
FELL OVER AND BROKE THE SCREEN THERES NO PICTURE . DO HAVE SOUND. ITS THE INNER SCREEN CAN IT BE FIXED/?
I'm sorry, no there isn't. Time to shop for a new set now.The price out weighs the cost of a new one.
May 07, 2011 | Hitachi 55HDS69 55 in. Plasma Television
A spot developed in center of screen next day black lines across screen from the original spot
it sounds like you have a small crack on your screen that has gotten worse over time, these black areas are where the lcd crystals aren't active anymore, unfortunately there isn't allot you can do apart from buy a new screen or put up with the black lines.
May 02, 2011 | Gateway FPD 1730 17" Flat Panel LCD...
LCD screen on back of camers isn' working - not image at all - nothing displayed - completly black How do I fix?
is there anything that indicates that its turned on? what you can do for a defective lcd is have it checked in a service center and probably ask if it needs replacement.
hope this helps
fixya!
Jan 30, 2008 | Olympus Stylus 770 SW Digital Camera
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
