Ethernet cable lites don't lite up when a cable is inserted in any of the four ethernet ports. I have Linksy-G router. I can't seem to communicate with my other computer on my network setup. Donald Hahne
    New Friend:
    Problem Solver:
  • 12 Answers
Hi i am James andrew. i want to share some information to all tech engineers .its all about Eathernetpedia App.if any one want to know information of networking cables then he use this Apps.
Posted on Jan 06, 2015
  • 6,487 Answers
If the light wont lit on the port where that cable is connected , that can mean the cable is bad or the router ports are bad so if you have an extra cable better try it and if that work so the problem is the ethernet cable but if still have the same result the problem is the ports on the router and better call Linksys tech support for that this is the number 800-3267114.
Hope that helps.....
Posted on Aug 11, 2008
I dont know how to connect a belkin wireless router to thr rca modern router?
You will need 2 ethernet cable to set it up Tha first one will go from the ethernet port in your cable modem to the ethernet port of the router mentionned Modem. The next cable will go fron one of the port of the router to the ethernet port of your Computer,
This second cable is placed temporarely to be able to do set the routers settings,
After this is done insert the Cd that came with your Belkin router and it should guide you through the different setting pages of the router.
Jul 25, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
CNet wireless router Model CWR-854V. is causing my Ethernet lite on my DSL modem to blink causing me not to be able to get on internet. Changed all cables no help disconnected Router and modem works...
Use an Ethernet cable to connect your computer directly to the DSL modem, bypassing the router, turn the modem off, turn the modem on, wait 60 seconds, and restart your computer.
Does the Ethernet lamp still blink when Windows is booting, and when you are using the Internet?
Turn the DSL modem off.
Turn the router off.
Turn the computer off.
Disconnect the Ethernet cable from the modem, and connect it from the computer to the router.
Turn the router on, and wait 60 seconds, then turn your computer on.
After Windows is running, click Start.
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: default gateway........ 192.168.123.456
If the string starts with '192.168', then your computer *IS* "talking" to the router.
Now, use an Ethernet cable to connect the WAN port on the router to the DSL modem.
Turn the modem on.
Turn the router on.
Wait 60 seconds.
Restart your computer, and you should be able to web-surf.
Jul 19, 2011 | Cnet CWR-854 Router
I dont know where the end of the blue cord goes
Hi !
Click the link below for proper cable connections in setting up your wireless network.
http://www.microsoft.com/windowsxp/using/networking/setup/wireless.mspx
Thanks.
Mongkey
"Understanding explains better..."
Jan 21, 2011 | Linksys WRT160N Wireless Router
My Ethernet lite will not come on on my modem, cannot get online thru this wireless router, tried reconnecting cables and power down the modem per set up instructions that came with the netgear router,...
if your modem has an ethernet connection the drivers should be on the disk provided by the internet provider
control panel admistrive tools,computer management,device manager scroll down network adapters +expand Ethernet driver right click update driver,disable,uninstall or select properties general you can trobleshoot or driver to update,rollback or uninstall
hope this helps
Nov 30, 2010 | NetGear WGR614 Wireless Router
I connected a 100/10 switch behind the router. The link led (uplink) flickers and data transfert through switch in drastically reduced (by factor 150) Can I connect a switch behind the Dsl rputer ?
1. Connect one end of your Ethernet cable to one of Four 10/100Mbps Ethernet LAN Ports.
2. Connect the other end of the Ethernet cable into one of the ports in the switch (try not to use the uplink port if it slows-down the connection)
Thanks
Aug 31, 2010 | D-Link DSL-G604T Wireless Router
What wires go where to hook up my linksy srx 200 router to my pc so I can view my laptop
In order for you to connect your desktop computer to this router you need to go get a CAT5 cable also called a Ethernet cable.
Jun 27, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
I have switched to a Westell VersaLink 327W from a older Westell Wirespeed. The Wirespeed communicated via USB and the new Westell communicates via Ethernet. How do I get the computer to see the modem?
If you are using a Westell DSL modem with ethernet connection, then you connect the modem's ethernet port to the computer's network card. This also uses an ethernet cable. Good Luck
Jul 19, 2009 | Westell Wirespeed VersaLink...
Please clarify what you mean by ''Connect with an ethernet cable''
Ethernet cable means CAT5 or UTP for others or LAN cable. The connection should be LAN port of your computer to LAN1 of your router.
And you can connect also the internet cable usually ethernet cable from your internet provider directly to (ethernet cable)WAN port of your router to get signal from your internet provider.
Also if you get this message, this could also means you still don't set up or configure the router's settings to communicate when your LAN and router. They must see each other to access the router's utility webpage.
Regards
Jul 10, 2009 | Linksys Wireless-G WRT54G Router
Desktop can no longer access the internet with Linksy router
Check the firmware of both your router and your wireless card and make sure they are both current.
In all honesty, it sounds like you have damage to an antenna or an electronics failure on either your router or wireless card.
You will prob end up exchanging equipment to find your resolution.
Jan 20, 2009 | Linksys Wireless-G Broadband Router
Westell 6100 seems unstable
if the ethernet ligth on modem is off, pc is not talking to the modem
check ethernet cable connection,, make sure it is properly and firmly plugged into the correct port...if still the same check network interface card,, right click my computer then click properties goto hardware tab,, click device manager button,, look for network adapters...right click adpter installed on pc then click update driver
Feb 22, 2008 | Westell Wirespeed LiteLine 6100...
Computers & Internet Logo
David Payne
David Payne
