Question about Philips Magnavox 9P6034C 60" Rear Projection Television
The TV will not come on.
Will not come on when plugged in. The on button is red.
  • rsgray Aug 15, 2008
    Tv will not turn on and the green light is blinking. (also, no sound)
    model no. 9P5034C102
    Chassi No. PTV835
    50 inch
    2000 year model
  • Philips Master
  • 3,459 Answers
This is a common problem with some older models. Check the site to see if they have a repair kit for your set.
Posted on Aug 13, 2008
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Sep 05, 2012 | Sharp Televison & Video
My lg telly has no sound or picture power button just flashing red
There are red,white,and yellow wires at the back of the T.V. Make sure
that the yellow wire is plugged into the yellow plug in hole, white wire has to be plugged into the white plug in hole, and the red wire plugged into the red plug in hole.Sometimes for the red wire you have to plug it in a black plug in hole. Make sure your T.V. is connected to you reciever. If this doesn't help I'd try calling somone to fix it for me.
Jun 24, 2012 | LG 42LC2D 42 in. LCD HDTV
I've connected the red, yellow and white plugs to
Hi where you plugged the rca cables into on the tv it will tell you what input it is. You must select that with the input button on the tv or remote.For example if it says vid1 you select vid1 whit the input button also make sure the yellow rca is plugged into yellow on the tv this is the video wire.
Jan 31, 2010 | Insignia Digital-to-Analog Converter for...
Television will not come on. Power light flashing red.
Hello Debbie ok the problem that your tv set is having is coming from the convergence board which is faulty and has to be replaced, you can find one at or by contacting the manufactuer of the tv set they should have one in stock, change out the board and you should be seeing tv in no time thank you hope this helps.
Aug 27, 2009 | Panasonic PT-47WX49 47" Rear Projection...
There is no picture anymore, all shows a blue screen.
do you have the orginal remote that has device button on it such as tv,dvd,av1,av2 or a input button on it if so play around with it such as when the blue screen comes on press the tv button or even better if you have cable box with the red,white and yellow plug in the back just plug the red,white,yellow cable from your cable box to the red,white and yellow into
the input of the tv
Jul 31, 2009 | Televison & Video
Toshiba tz43v61 TV just died. No red light.
does it have a power strip on the tv stand? if so plug the tv into a wall power strip went bad and the reset button did not work
Jul 17, 2009 | Toshiba TZ43V61 43" Rear Projection...
Use your input button on your television's remote control.... you should have plugged the wires into the COMP 1 area on the back of your TV.  You will also need to make sure your red and white audio cables are plugged in as well (Five total plugged wires) Press the input button until you see COMP1 at the bottom of the screen... there you will find your picture and sound.
Oct 19, 2007 | GE D52GW12 52" Rear Projection HDTV-Ready...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
53 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
