Question about 2wire 1800HG Router (RG1800HG00)
2wire 1800HG Router with no software
My buddy gave me a 1800hg router. Only problem, he doesn't have the software. Is there a way around this, a download or something. Or am I just going to have to bite the bullet and go buy a new router?
  • coolbreeze41 Aug 11, 2008
    I'll give that a try
    Thanks for your quick response!
  • 2wire Master
  • 6,487 Answers
You can manually configure it , so I may suggest you to call the manufacturer of the router or your ISP and they can walk you through in manually configuring this router.
Hope that helps........
Posted on Aug 11, 2008
  • Mark Gil
    Mark Gil Aug 11, 2008
    You're welcome dont forget to rate the solution FIXYA..
    Thank you.......
AT&T 2Wire 1800HG set up on Ubuntu
https://help.ubuntu.com/7.04/internet/C/connect-to-internet.html
Jan 03, 2010 | 2wire 1800HG Router (RG1800HG00)
Can you tell me how to set up wireless connection?
You can find a detailed walkthrough of setting up wireless connections on your 2wire here.
If this helped you then please help me and vote kindly, thank you
Oct 15, 2009 | 2wire HomePortal 1800HG Router...
2wire 1800HG router keeps resetting
1) Check power cord. 2wire has known issues with power cords being defective. If you have a Multimeter, I would check to ensure the correct voltage and amperage and being delivered to the router first.
2) Need to resolve the "resetting problem" first. Then attack the port forwarding issue.
Aug 15, 2009 | 2wire 2700HG-B Router (2700HGB)
How to connect to XboxLive via 1800HG 2WIRE+Linksys adaptor?
The easiest way to connect to Xbox Live without using your pc is to buy a
wireless network adapter for your Xbox.
You would then go into the system settings on the Xbox and configure the settings for your wireless network.
http://www.xbox.com/en-US/hardware/x/xbox360wirelessnetadapter/
Xbox 360 - direct to internet - No PC.
Jul 31, 2009 | 2wire 1800HG Router (RG1800HG00)
1800HG DSL modem/router: Cannot access any of the setup pages.
you have to set the unit to default hold the reset button for about 30 seconds the small hole
Jul 11, 2009 | 2wire 1800HG Router (RG1800HG00)
2wire 1800hg-- HomePNA stopped working
What you can do, is take the HPNA adapter from the back of the computer and plug the phone cable portion of it directly to the 1800hg's phone port. Since your 1800hg only has 1 phone port though it will not surf the internet, but this is a suggestion to try to make sure the inside wiring in your house is not bad. If you do this though your computer should say its connected, if it doesnt then it could be a driver issue or the phone cable in the HPNA adapter (try a new one then). If its the driver then try support.2wire.com for the regular usb drivers.
Jan 21, 2009 | 2wire HomePortal 1800HG Router...
1800 hg 2 wire wireless
1.can i use my 2wire 1800hg with vista?hooked up to ethernet connection.- yes its possible make sure you enable dhcp on your lan side of you router and under tcp/ip on your pc set it to authomatic assign IP address and dns server address. most router use 192.168.1.1 as thier default address to access it.
to fix your passkey problem.need to access the router and try to change the passkey then save and don't forget to restart the router after you save it,by unplugging it. "make sure your passkey is 8 characters long"
Nov 11, 2008 | 2wire 1800HG Router (RG1800HG00)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
Need a copy of instructions
you can download the manual here, it's the bottom one, the '1000 series' http://www.2wire.com/index.php?p=266
Jul 15, 2007 | 2wire 1800HG Router (RG1800HG00)
2wire 1800HG Router (RG1800HG00) Logo
206 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
