Question about Toshiba TP50H95 50" Rear Projection Television
No picture or sound.
Hi the problem i'm having with my tv is when i plug it in to the wall, it automatically turns on with a 1 click noise like it normally does when i used to power it on. then when i unplug it, i get a flask on the screen and it turns off. with my understanding, I'm hearing this is a common problem with this model and some others. can you help please?
Thankx,
Dennis Savard
978-866-8999
DennisSavardJr@aol.com
    New Friend:
  • 50 Answers
Power supply problem, check if the regulator IC and the horizotal transistor...
Posted on Aug 11, 2008
Lost picture have sound on 55" Samsung led TV. Just went black all of a sudden two days ago.
Does the power light indicate power when it's plugged into the wall? When you press power, do you hear a clicking noise? If so, google your model # plus clicking noise power on
Not sure how old a Samsung TV you are talking about, but they had major problems with capacitors (widespread issue) in their TV's. Easy fix and something you can do yourself.
Mar 28, 2017 | Samsung Televison & Video
Toshiba model 42hp66 Plasma flat screen Problem No picture or sound. Pushing on button 2 clicks are heard A slight hum is heard at the Z SUS board. Green power light is on (power light is...
Hi
There are some factors of this kind of problem.
First you could have a failure in the power supply. Next could be the main board. Lastly you could have a problem with the panel itself, this would mean a new set for sure because the part cost is more than a new set.
However try troubleshooting the problem before spending money on repairing or replacing the television. Possibly you can restore the picture and sound to your television ...
Verify the TV is powered on by pressing the power button on the TV's remote or the front panel of the set. This may seem like an obvious step, but many TVs are equipped with a standby light that will illuminate if the TV is turned off, making it appear that the TV is on when it is not.Cycle through the TV's video inputs to verify that your TV is set to the right one. For instance, if you are attempting to use a digital cable converter box that is plugged into the Video 1 input and the TV is set to a Video 2 input that has nothing plugged into it, the TV will not display any picture or sound and may even say "No signal" on the screen. To cycle through the inputs, use the input selection button, typically labeled "input," "source," "TV/video" or the like.
Re-seat the video and audio input connections to verify a loose cable is not causing the TV's loss of signal. If you have a coaxial cable connected from your wall cable jack directly into the TV, it may have come loose thereby eliminating all picture and sound on the TV. Locate the connection cable or cables of whatever device you are attempting to watch and unplug them from where they plug into the TV. Plug them back in and check for a signal. If there is still no picture or sound at this point, the best option is to contact technical support for further assistance.
Apr 22, 2011 | Toshiba 42HP66 42 in. LCD Television
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
My Sony KDS-60A2000 is 41/2 years old. About 2 weeks ago I could not get the tv to power up. the green stand by light just kept blinking. I powered off, then powered up again and the tv started and and...
TV needs lamp replacement as existing lamp got weak or has been reached to end of its working life, please note that lamp is not dead or broken so that is why lamp lit is not lit at tv front.
Hope these info will help you.
Thanks.
Nov 03, 2010 | Sony KDS-60A2000 60" HDTV
My TV made a noise that sounded like a "pop" when i pushed the power button to turn it on. Then my lamp light came on and stayed on. I unplugged it from the wall outlet and then plugged it back...
The tv old projection lamp in the tv now like 1 1/2 or 2 yeears?The tv LED "LAMP" light up or flashes the projection lamp is dead.Yes,the tv require a new projection lamp.
Oct 31, 2010 | Mitsubishi WD-60735 Projection Television
Hello, have a 32 inch flat screen sharp tv. worked fine all day sunday, went to turn it on last nite no picture only sound. noticed when tv is off and plugged into the wall and you go to turn it on, there...
It can be that it has unstable power supply or the CPU/EPROM are getting scrambled by the noise and spike in the AC line, you may try better AC line conditioner to see if it will help.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Oct 05, 2010 | Sharp Televison & Video
Hi we have a samsung tv model LA46M81/BD. It is not turning on. When we turn it on we can hear a clicking noise like it is trying to switch on -
The click sound means that the wall socket, plug, wire and the switch are fine. That takes us to the Power Supply Unit. this is what is at fault. Please replace it with exactly the same one. It is the one that would have a transformer on it.
Feb 13, 2010 | Televison & Video
ICs + resistors swapped= blue power light auto on clicking noise
Unplug the power to the convergence board. If it turns on, you still have a problem in the convergence circuit.
Dec 16, 2009 | JVC AV-56P575 56" Rear Projection...
Green light is on ...white noise sound but no picture
This TV finds the connected input sources
automatically for AV1, AV2 and Component 1-
2. It is presumed that RGB and HDMI/DVI
sources are connected.
Check your setup to see if the audio is turn off but if you have a clear picture you should have sound.
Time to call a TV Tech if you are not going to repair the unit.
Jul 11, 2009 | LG 42PC3D 42 in. Plasma Television
My tv doesnt turn on but it has a clicking sound
Hi, this clicking sound is coming from the power supply board. this Board accepts the power stream from the wall outlet and regulates it with capacitors and resistors and transformers etc.. when these components are malfunctioning or damaged, your unit will make these clicking noises.
Simply replacing the power supply board and fly back, if installed, will fix this issue.
Please rate and have a great day:)
May 18, 2009 | Televison & Video
Televison & Video Logo
50 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
