Question about Eureka 2971AV EZ Kleen Bagless Upright Vacuum
Extreamly Loud this vaccuum has great sucking power I have used it about 4 times it is very loud it sounds like a screeming banshee. It actualy hurts your ears to use it. the filters are new the roller is clean and rotates freely what is the problem with it?
  • Anonymous Nov 24, 2008
    Boo!  Mine is extremely loud as well :(, the pulley has blued and I bought it over a year ago....  new vacuum it is!
    Novelist:
  • 97 Answers
Most likely you have a bad motor bearing. It's a pretty common problem with vacuums of this type... a good way to check is to open the bottom where you replace the belt, and look at the motor pulley. If it's blued, your bearing is most likely generating heat and bluing out the pulley. (Bad.)
The less safe but more accurate method of checking this is to run the vacuum for a minute or so, then physically check the motor pulley for heat. If it's ridiculously hot, your motor is toast. (Please be careful when doing this: ensure that the machine is unplugged, and note that it can get hot enough to burn you... Ask someone you're not fond of to touch it if you don't want to get burned.)
It your motor bearings are bad, you need a new motor, which probably will cost almost as much as the machine did.
If you've only used it 4 times, I probably wouldn't try to fix it yourself, since it's probably still covered under warranty. My best recommendation would be to take it back to your point of purchase for refund or exchange.
-R
Posted on Aug 11, 2008
D.C. 17 makes a loud whining noise when beater brushes are engaged. Normal sound until then. Replaced belt. Still so loud it hurts my ears!
Could be the brush roll, remove brush roll and see if noise is still there when brush roll motor is running.
Sep 18, 2017 | Vacuums
Hi! My Dyson DC17 starts fine and then, within a second, gets very loud with an extra sucking noise.
Hi there, it's Jack at Dyson.
Like most Dyson vacuums, DC17 includes a suction relief valve. This allows extra airflow into the vacuum to protect the motor if the machine is used when blocked. If you've already washed the pre-motor filter and checked all the ducts for blockages, it's possible there's an issue with your machine's cyclone pack which has caused it to block.
We'd appreciate the opportunity to help you check for this - please do not continue to use your machine in the meantime as this may cause damage. When you have your DC17 easily to hand, please give the Dyson Customer Helpline a call on 1-866-693-9766 (US), or 1-877-397-6622 (CA).
We'll look forward to speaking with you.
Mar 14, 2015 | Dyson Vacuums
Motor loud
The beeter bar bearings are bad i just changed the beeter bar on a vacuum that fixed the loud noise check for play in the old beeter bar brush
Mar 21, 2014 | Eureka 4700A Maxima Bagless Upright Vacuum
It sucks great but sounds like a jet taking off extremely loud
Hey, dirty filters or clogs can change the sound of the vacuum. Here's a quick link to troubleshooting steps to assist you.
http://www.bissell.com/FAQDetail.aspx?id=1421&cid=ccsocial
Jan 26, 2013 | Bissell Vacuum - Momentum Cyclonic 1 ea...
My vaccuum seems to clean, but makes a louder noise than normal
I would check and clean any of the filters also check the pipes for any blockages etc.
Regards
Alan Hood
ami-man
Dec 04, 2009 | Dyson Vacuums
Makes a terrible loud noise. It hurts my ears.
time to check your filters
if you bought it used check your hoses also
some people think sunp pump hose is just like vacume hose but man does it whistle (almost enought to pop your ears loud )
Jul 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Accessory hose not sucking
Try taking the hose off, and making sure it is not stopped up, either in the hose, or where it attaches. Straighten a wire coat hanger and run down the hose to check for obstructions.
Hope this helps!!!
chad
Oct 08, 2008 | Dyson DC14 All floors Bagless Upright...
Kenmore progressive vaccuum
Did you replace the hepa filter with a new one? Those filters may not look bad, but after a period of time and use, air is restricted thru them. They should be changed at least once per year.
Sep 03, 2007 | Kenmore 31913 Progressive Direct Drive...
Eureka 2971AV EZ Kleen Bagless Upright Vacuum Logo
87 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
