Question about ASUS P4P800 SE (890552603657) Motherboard
OVERCLOCKING FAIL/CPU FAN ERROR
MY PC FAN WILL RUN AFTER I SHUT DOWN AND THE POWER LIGHT FLASH'S OFF AND ON. SETTING WILL FLASH THAT " OVER NOT CLOCKING FAIL/CPU FAN FAIL. NOT TRYING FOR OVER CLOCKING.
    Problem Solver:
  • 7 Answers
First approach shold be the CMOS utility, check in FAILSAFE DEFAULTS that the error settings for shutdown are either null for overclocking or disabled if you don't have the failsafe defaults on your CMOS utility then set your settings to best performance (should be found on the main page of the CMOS utility). If you are unsure of touching the CMOs then you could try to remove the CMOS battery (small 3 volt battery about the size of a 20 cent coin) located on the motherboard this should reset the CMOS and fix the problem. hope i could help,thanks:)
Posted on Aug 11, 2008
Model# pcg 71318l
Overheating
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Apr 29, 2013 | Sony VAIO Computers & Internet
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
Overheat and shuts down
Following are the reasons for overheating, just take care of these things::
  • Stop Overclocking your CPU
  • Make sure your Heat Sink is placed properly above the processor
  • Clean the Processor fan, Heat Sink and other peripherals
  • Use High Speed fans
  • Use CPU Heat Sink Paste in the processor
  • Make sure your dint restrict the speed of CPU fan.
  • Use Additional Cooling Units
Also use a system utility tool like PCFresher to fix windows errors.
Apr 25, 2012 | Computers & Internet
My computer overheats and shuts down every time I run an intensive program, what can I do to better cool down the system. I already moved it to an open spot and cleaned out the dust
make sure all dust is clear of the processor heat sink. then if you overclocked the processor you may want to back off overclocking a little bit. make sure you have plenty of thermal silicone paste in between your processor heat sink and processor
Dec 23, 2010 | Dell XPS 625 DESKTOP GAMING MACHINE- Black...
I changed my cpu fan out, when i started it up it ran 30sec and shut down. So i replaced new mother board without fan., it still shuts down after a few sec. I disconected the 4 pin power source and it will...
From your problem description it sounds like the CPU was overheated (and failed) before you replaced the CPU fan - so the fan replacement was too late. Since the procesor already failed, installing a new motherboard without a fan did not accomplish anything.
The 4 pin power plug provides +12 volts DC to the processor. When you disconnected it, the processor essentially could not run at all and the system is no longer capable of detecting the CPU failure and shutting down the power supply.
You need to install a known good CPU which is the right type and speed for your computer. Unless you are experienced in replacing,CPU's, fans, heat-sinks and applying thermal grease I recommend that you have a PC technician perform these tasks.
If you believe that this information is of value to you please rate me on the FixYa website.
Regards,
Yavacotech
Nov 29, 2010 | Computers & Internet
One morning I turned on my PC, and it gave me Overclocking failed error. Press F1 for something I dnt remember.. access bios or w/e. so now I went to Bios , pressed f9 for the default settings then I...
If you had been overclocking you may have fried the CPU chip.
You MIGHT try cooling the thing better and for sure blow out any dust occluding the fans.
There is a chance you have a virus that deliberately clobbers the BIOS settings.
Oct 13, 2009 | Intel Motherboard
Overclocking on this board with an E2180?
When the CPU overheats it shuts down especially if you overclock it.
Did you put any heatsink compound between the CPU and the heatsink (this aids heat transfer from the CPU to the heatsink/fan)?
Your BIOS may have a setting that can adjust the CPU fan speed/temperature.
You can install additional fan/s in the case to draw more air into the computer case.
To further cool the CPU, you might have to install a better and more efficient cooling heatsink/device/fan on the CPU.
Feb 10, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Cpu fan error
POST troubleshooting steps. If a fan has failed (especially the heat sink fan for the CPU)
Good Luck, Please dont for get to Vote.Thank you.
Dec 16, 2007 | HP Pavilion dv1000 Notebook
Problem restrart pc /NO AUTORESTART
It sounds like you're trying to overclock your CPU, and you have exceeded what the CPU is capable of, under the current conditions. When you start the computer, enter BIOS setup (e.g. press the DEL key), and adjust the CPU settings to default. If you're not sure how to do this, choose the "LOAD OPTIMAL SETTINGS" or "LOAD DEFAULT SETTINGS" option from the main BIOS menu. If you are not getting this error until after Windows has started, then there is software installed that is trying to overclock the CPU for you. Uninstall it. It may be a program provided by Asus, or may be a third-party program. It will probably have "tweak" or "overclock" in the name. Overclocking can achieve an increase in performance, but will void the warranty, and does reduce the lifespan of the parts, and tends to make Windows crash more often. It can cause immediate failure of the parts. It should only be done if you understand and accept the risks, and have decided the reward is worthwhile. For most users, it is not worth it.
Oct 01, 2007 | ASUS P5LD2-VM Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
ASUS P4P800 SE (890552603657) Motherboard Logo
342 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
