VAX Appliances Vax X5 Bagless Upright Cyclonic Vacuum Logo
Posted on Aug 11, 2008
Vax v10 manual VACUUM CLEANER
Hello
I need help in finding a manual for the vax v10 model otherwise i have no idea how to use it.Do you know of a place where you can download such a manual.I have looked through allot of sites and none have come through with the goods.
Thankyou BROOKE
  • Anonymous Apr 12, 2009
    I also have a Vax V10 and no manual - seller was supposed to send it
5 Related Answers
Anonymous
  • Posted on Mar 24, 2011
SOURCE: i have a vax wet/dry
If you still need a manual, I have one I can scan and email?
Anonymous
  • Posted on Jun 23, 2008
SOURCE: can you reverse the vax 2000 vacuum cleaner to pump up a pool
theoretcally u can switch the two coils inside the vacume cleaner, u could get electricuted/ break the cleaner as a result.
if any one has suggestions on how exactly to do this(im building a furnace... gotta have a blower thin) then please email me at [email protected] or [email protected]
Anonymous
  • Posted on Dec 22, 2008
SOURCE: I can't put my vax vacuum cleaner back together
Contact Vax customer service, they are very helpfull!
Or use this link to find your local service agent: http://www.vax.co.uk/support/service_and_support.php
Hope this helps.
Dina
ukvacfan
Ryan S
  • 328 Answers
  • Posted on Mar 06, 2009
SOURCE: Hello I can not find my manual for my vax vs19
Check out this site;
http://www.vax.co.uk/support/vacuum-cleaner-user-guides
Scroll down to the one that's applicable.
Anonymous
  • 4 Answers
  • Posted on Apr 22, 2010
SOURCE: Vax V-091 Rewind Mechanism Broken
If you need help or advice, please call the Vax Customer Careline on 0844 412 8455 with your machine available, and an Advisor will be able to help you. The Vax Careline is open every day, from 8.30am until 6.30pm, Monday to Friday, and 9am until 5pm on Saturday and Sunday. Outside of these times please check the website support section which includes videos to demonstrate how to deal with everyday problems such as changing filters and belts and checking for blockages. With best wishes, The Vax Team.
2answers
Blocked vax 1700 does anyone know how to clear the blockage
The best way to clear a blockage on a Vax 1700 vacuum cleaner is to turn the machine off and remove the dust canister. Then remove the filter from the dust canister and rinse it in water to remove any debris. After the filter is dry, re-insert it into the dust canister and put the canister back into the machine. Finally, turn the vacuum back on to ensure the blockage has been cleared.
Mar 02, 2019 • Vax Vacuums
1helpful
Do you have a manual for a vax hoover vrs116
Many Vax vacuum cleaner trouble-shooting and maintenance tips are available here: https://support.vax.co.uk/ . The VRS116 support page is https://support.vax.co.uk/u90-ma-re-powerforce-version?___store=support_portal_uk .
The user guide for the VRS116 applies to several models. You can find a link to this manual from the above Vax support page link by searching on the VRS115: https://support.vax.co.uk/u91-ma-be-powerforce-version . The link to the manual is just above the Maintenance section. The direct link to the manual is http://library.vax.co.uk/resource/1387/vrs115/user-guide.pdf .
I hope this helps.
2helpful
VAX Petvax Operating Manual
Check Vax.co.uk they have an online user manual section.
Specificially:
Dont forget to rate appropriately, thanks.
I got a vacumn from a friend who ungraded and though i used at her home when i got it home it would not turn on when plugged in and i check everything and no use. my friend lost her manual. im in my 60's...
Hi In the UK we have similar machines but they are made by Vax. If you can't source the correct user manual from Hoover.com consider the following - it is a free download.
http://www.vax.co.uk/downloads/pdf/vzl-60156016_v2_(brushbar).pdf
The Vax Mach 5 and Hoover model you have are the same other than the name. Dont forget to rate, thanks.
2helpful
Hope this helps.
Dina
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintergrating do you think this can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553164
Generic problem for all Vacuums
I was using my vax
Posted by paulxlyn on Apr 28, 2008
I was using my vax rapide washer earlier and it blew my trip however noticed that the filter is disintegrating do you think this can be repaired?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Yes, you can contact your local vacuum cleaner dealer and if they don’t carry the Vax Model then feel free to contact the Vax Rapide Factory Manufacturer phone number or the website for further information and to order parts if needed. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.vaxusa.com/
If you have specific questions and you can't find the answer you’re looking for here, please call our Customer Service Department at 877.894.2031
M-F 8AM-7PM EST or check out our Contact Us page for more information.
Thanks, Don – The Vac Man
Apr 28, 2008 • Vacuums
1helpful
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits doyou think it can be repaired?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=553160
I have a Vax Rapide
I have a vax rapide carpet washer was using earlier and blew my trip switch noticed that the filter is falling to bits do you think it can be repaired?
Go Ahead. Use Us.
Top VAX Appliances Vacuums Experts
john h
Are you a VAX Appliances Vacuum Expert? Answer questions, earn points and help others
