Question about HP Pavilion dv8000t Notebook
Vertical lines in my laptop screen
Hello! I've been using my Compaq Presario (M2223AP) Laptop for 2 years now, then all of a sudden I saw 2 vertical lines on the screen. 1 line is a clear red line (but not so thick & dark) located about 1/3 from the left of the screen while the other is a very faint (thin, almost transparent) line located about 1/5 from the right of the screen. I think it might be a monitor problem. I'm not very good in fixing computers so I have not done anything about it yet. I'd appreciate your help very much. Thanks! I have a Toshiba Satellite and the whole right side of my screen is all vertical, colorful lines. Can this be fixed? Thanks. We have 2 vertical lines on our Toshiba Satellite P105 that is a little over a year old I have an HP Pavilion dv8000 laptop that now has 5 vertical lines, 2 pink & 3 pale green. It started happening about 1-2 months ago with one line & has progressed. I bought the computer in 2002 & have loved it up until now, with no problems. Is there any reasonable way to resolve this? Thanks! BB
  • HPBLUELINE Jan 19, 2009
    Yup I have a permanent vertical blue line an inch in from the left side
    on my hp pavilion dv8000 notebook monitor... and today I saw the
    beginning of a second blue line forming... is there a fix for this or
    is this a widespread hp problem?
  • 846 Answers
If the lines flicker and change when you put pressure on the screen it sounds defective lcd screen, there are these conductive rubber pieces that lead the signal into the lcd panel and once the connection deteriorates there is no going back. the screen could still be replaced, there are laptop repair places that do it, but you have to have to weigh your options with buying a new laptop, repair could be up to 50% of what your's is worth as a 2nd hand laptop.
you can try to fix it yourself, there are guides online on google and you usually get the screen on ebay for around 150.
Posted on Jun 18, 2009
    Scholar:
  • 38 Answers
This could be a failure in several areas along the path from the video card to the monitor.
Being that there is not an issue across the entire monitor the video card should be considered a last resort check.
Usually this is caused by a loose connection between the LCD driver and the LCD panel itself. Sometimes light pressure applied near the affected line will clear it up. If that does then it is a connection between the LCD panel and the connector to the LCD driver at the panel's edge.
Not much can be done unless you have it repaired by a professional or you can take it apart yourself and apply a pad of some type inside the monitor's edge to apply the needed pressure once assembled.
Posted on Apr 01, 2009
SOURCE:
Have you tried hooking it up to an external monitor?
This would ensure that it's the screen and not the video card..
If you do that and you receive a good picture then it could be something as simple as a loose video cable. Or it could also mean something like a bad video card or the expensive one, a bad screen.
Mar 08, 2009 | HP Pavilion dv8000t Notebook
I had the same problem - sent it in to Acer and they replaced the LCD for 500 bucks!
Aug 18, 2008 | Acer Aspire 9500 Notebook
the lcd (liquid crystal display) is damaged at this time, nor the inverter, that is of course inside of your pc, im afraid you need to send this to a repair shop
cheers
Aug 12, 2008 | Dell Inspiron XPS M140 Notebook
if this line is there during boot up then it is a monitor problem usually. but if it is not then it is a problem with your windows files. you could try reinstalling your windows from the disks you were given with it? otherwise i will look into it. email me if you need more help. [email protected]
thanks
matt
Jul 30, 2008 | Acer TravelMate 2300 Notebook
My understanding is that you have 2 laptops with the same problem, if that is the case, you need to replace the lcd. When you have lines on lcd's, that is a sign of a bad lcd.
Jun 10, 2008 | Toshiba G15-AV501 Qosmio Notebook
There can be 3 possible reasons for this
1)Screen connector cable is loose. You can try to re-seat it and see if works.
2)display card problem. Connect your laptop to an external monitor and see if the problem persists. If it does not then
3)You will need to get a replacement LCD screen.
Hope this helps!
May 04, 2008 | Dell Inspiron 6400 Notebook
what i recommend you to test is to press behind your monitor and see that the line goes off or not.If it does..that mean you have a loose connection,it can be fix.Incase no then you have problem with your LCD.Normally if its LCD problem then you fix this problem,all you have to do is change the LCD.
goodluck,takecare.
May 04, 2008 | Toshiba Satellite P30 P35 Series Notebook
thats monitor problem dude, better go to the nearest repair center of your toshiba to assist you bout this problem.
Mar 10, 2008 | AMD Compaq Presario Turion 64 Notebook
Check it on External monitor prior to replacing the screen.. If the problems there as well its not the screen..
Feb 06, 2008 | Toshiba Satellite P35-S609 Notebook
you could try and download a new display driver from here http://h10025.www1.hp.com/ewfrf/wc/product?cc=mx&lc=en&dlc=es&product=499234 if that dosent help Id imagine it is the screen that is at fault.
Jun 09, 2007 | Compaq Presario Laptop
Open Questions:
See all HP Pavilion dv8000t Notebook Questions
HP Pavilion dv8000t Notebook Logo
779 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
