Question about Philips SA5125/37 MP3 Player
Memory corruption i have no idea how to reformat my mp3 player, can you help me little_rogue_rage@yahoo.com
  • little_rogue Aug 11, 2008
    help me reformat mp3 player
  • FFlamehead11 Aug 20, 2008
    well.... it says music file corruption and ask to fix the problem and when it finishes it has the okay button and i click "ok" and it dont go no where. ive resetted it a couple times and try to turn on,..... and NOW every time i reset then turn it on it just dies within 2 seconds.. even tho my battery is good.. and once it shuts off it dont turn on until i reset it then turning it on. but never gets to the menu just dies shortly after.. so wat do i do?!
  • 8,596 Answers
You need to get the firmware upgrade from the Philips website, not reformat the player
Posted on Aug 14, 2008
Have a file system error, now the mp3 will not com...
Hello.
Scan your Mp3 for virus.
Try to reformat or reset it
especially reformat the memory card
as there might be corrupted files.
May 20, 2010 | Audio Players & Recorders
I tried turning my mp3 player on and it said "invalid memory, cant find MBR"
Invalid MBR = Invalid Master Boot Record.
This means that your player Flash Memory drive is corrupted and unfortunately may need to be reformatted if you cannot repair it using some Disk drive or Flash drive utility.
You can try to use 'Properties -> Tools -> Error Checking -> Check now' to fix the issue.
If you have a backup of the music on your player, I would simply use Windows Explorer and FORMAT it using FAT32.
Hope it helps.
Dec 22, 2009 | Mpio FL300 MP3 Player
Recognition by computer
It seems that the storage portion of your MP3 player is already corrupted. If the device is still under the warranty, take advantage of it and contact the manufacturer for memory card replacement.
The memory card (storage) should be replaced and NOT reformat. There could be bad sectors and it cannot be fixed by reformatting only.
Have a great day!
Oct 04, 2009 | SanDisk Sansa e250 MP3 Player
Device will not sync. i only have 1% memory on the gpx mtp. it says no file, when there is sonngs on the player.
it happens if the file is got corrupted or not getting read properly.reformat the mp3 player drive then check again by reloading the files again.then sync and check out.
Aug 30, 2009 | GPX MW-3847 MP3 Player
Used memory
Hi you need to reformat that unit to pc! because you have corrupted songs or you have virus in your unit!
Thanks! Likha!
Sep 17, 2008 | SanDisk Sansa e250 MP3 Player
Help
Your flash memory has become corrupted.. only the manufacturer can repair..I wouldn't try to reformat it...Never force it to run after it has shutdown from low battery. Don't leave it in high heat environment..You could try to connect it to your pc with the power switch in the off position let it charge fully and then before you disconnect turn the power switch on on the player..If thatdoesn't work make sure you are using the pc that connected to the player originally and plug the player with the power switch on and restart your pc. Good luck
Sep 10, 2008 | Mach Speed TRIO Onyx MP3 Player
Mp3 player problem! please help!
Go to RCA.com then download the software updates, maybe ur firmware has een corrupted so u nid to reformat it..
Apr 01, 2008 | RCA OPAL M4001 MP3 Player
My mp3 files have corupted
thats awful. i suggest that your should reformat your mp3 player. it was corrupt by certain viruses.
pls rate me up.
Jan 22, 2008 | RCA TH1101 MP3 Player
Memory corruption
My mp3 player Philip SA51xx 2gb says "memory corruption please repair it now" can I ask your hepl to fix the problem thank you
Dec 24, 2007 | Philips SA5125/37 MP3 Player
Philips SA5125/37 MP3 Player Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
