Question about GTech G-Tech G-Drive Mini 2.5 Portable Storage Solution, FireWire 400 / USB 2.0 Interfaces, 60 GB, 7200rpm... FireWire 400 (1394a) Hard Drive
G-Tech drive broken
I have a G-Tech Mini HD. It has been good as gold for over a year. Now it has has started making a strange rubbing noise inside and will not mount any longer.
Is it dead? Can the data be recovered?  Can it be repaired?
Hope you can help.
  • 734 Answers
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Posted on Dec 12, 2008
WHIRLPOOL WASHING MACHINE WILL NOT SPIN SEE ADDITIONAL DETAILS
Sounds like your gear casing is broken inside, motor is spinning but transmission shaft where agitator sits on, is not spinning.
Apr 15, 2015 | Whirlpool Washing Machines
My hard drive is making a strange noise when it is used. It sounds like a heartbeat and it occurs in a random time interval. I know it isnot much to start with but i cannot say anything else about it then...
Any strange noise like excessive clicking, grinding, some weird sounds etc. actually indicate a failing hard drive.
Failing hard drives often show warning signs of their imminent demise. If you're lucky enough to see or hear one of these signs, stop what you're doing and immediately back up your data. They say prevention is better than cure so if your computer's hard disk is making some strange clicking sounds, BACK UP YOUR DATA IMMEDIATELY (As the drive is not operating smooth and may fail anytime).
After making backup of your important data on CD/DVD or External Drive, you may scan the drive for surface errors, format it and see if it works properly or not. It would be better if you seek professional assistance for examination of the disk.
Hard drives are mostly under warranty for at least one year. Claim warranty, if possible.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 20, 2011 | Western Digital 2 TB SATA 6 GB/s 7200 RPM...
This AC makes a severe Churning noise when the compressor runs. It now makes a strange noise when your start the unit and then 'hums'. It seems to have problems with the compressor 'kicking...
lots of compressors make strange noises and run for years. I hate to suggest installing a hard start kit simply because I always wonder what we did before they came out with a hard start and machines lasted longer BUT, check amps on start up, amps while running, watch amps for a bit while it's running, install hard start kit. just like all mechanical equipment, it may last 5 weeks, it may last 5 years. Best Wishes!!
Oct 31, 2017 | Frigidaire FAS156N1A Air Conditioner
My Duet Washer by Whirlpool is about 6 years old and it started making a loud noise during spin leaving shredded plastic in tub. In talking to the repairman, he said if the arms are broken, they would...
i just had my washer do this to me last weekend. In the final spin out it made a loud noise and i noticed that the plastic between the metal tub and the outer plastic tub was rubbing away.I'm going to tear into it my self being that its out of warranty. Mine is about 6 years old too.
Nov 19, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
My Whirlpool Gold Ultimate Care washer doesnt agitate or spin. Makes a strange almost clicking like noise instead.
sounds like the drive block under the tub is stripped out or broken and it needs replacing,it sits under the tub to help drive the tub on direct drive models
Jul 18, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
G tech hard drive not recognized by my macbook pro
Hi Evan
The fact that you have tried all three connectors suggests that the fault lies with the drive. Either the interface board or the HD itself. If you have access
to another computer you should be able to prove it one way or another.
Over the years I have seen many external drives fail (I had two identical drives of my own fail on consecutive days one proved to be the firewire board in the box, the other was the circuit board built into the HD), and it's quite difficult to decide where the fault lies.
Do you hear the HD spinning when it powers up (press your ear against the case)? You should be able to differentiate between the HD and the noise of the fan. Is there any clicking?
Is it still under warranty?
Thinking about it, if you get nothing with the USB and the Firewire then it's a good chance that the HD inside has failed.
Jun 17, 2010 | GTech G-Tech G-Drive Combo 500GB...
When i start the computer it sounds very strange and the computer are very slow
it's hard to figure out the source of that noise by the "strange" word.
if it is like a metallic sound it could be you hard drive failing.. how old is it.. I had to replace mine after 5 years of normal-heavy usage. the slugging or your computer could also be due to the hard drive or it could be lack of maintenance (defragmentation, malware, viruses)
suggestion:
1. if the hd is old. save all your data as soon as possible as your description could mean an inminent hard drive failure in the way.
2. replaced as need.
if hd fairly new (1-2 years with normal usage) do this:
1. save your data in backups
2. download, install, update and run deep scans with at least 5 malware programs.
3. update your antivirus and run a full scan
4. defrag hd.
5. it may be convinient to do check your disk for errors
if the sound is a loud zumming.. undust the inside of your case and clear all vents from dust and gunk, (watch for electromagnetic discharge that could damage your computer if you are going to do it your self.
if the zumming continue, look for source as it may be a failing fan and replace as soon as possible.. fan's keep proper temperature on hardware components and will make them last.
post back with your findings if needed.
Mar 26, 2010 | Fujitsu Siemens Computers & Internet
Grinding/rubbing noise while driving
Could be the shield rubbing on the tire or could be a loose brake caliper. Get the brake assembly checked.
Mar 16, 2010 | 2005 Nissan Altima
Lacie 500gb external drive
The disks inside the HD are not spining. The creaking noise is the HD trying to start. Next time when it does start transfer all the files ASAP cause your drive is about to die.
rmatheson@wowway.com
Sep 30, 2008 | LaCie Ethernet Disk Mini, 500 GB Hard Disk...
Computer fails to recognise my external hard drive
I would suggest the external casing of the harddisk that contains its power supply is busted, so you need to change the casing or remive the harddisk from the casing and connect in inside
Feb 16, 2008 | Western Digital Caviar WD2500BB 250 GB...
GTech G-Tech G-Drive Mini 2.5 Portable Storage Solution, FireWire 400 / USB 2.0 Interfaces, 60 GB, 7200rpm... FireWire 400 (1394a) Hard Drive Logo
592 people viewed this question
Top GTech Computers & Internet Experts
Corey Bartlett
Level 1 Expert
richie46
Lawrence Oravetz
Are you a GTech Computer and Internet Expert? Answer questions, earn points and help others
