Question about Toys
Peg Perego Gator Ride On Toy
My gator will only go in high speed forward, and not reverse or low speed.
If I put it in low gear, and move the left wheel slightly forward, both wheels will engage and operate normally for several cycles.  But then, it stops working again, where you have to slightly move that left wheel to get it going again.
Any ideas would be greatly appreciated.
Lynn
    Problem Solver:
  • 19 Answers
I had a peg perego gator hpx that was soing the same thing and I replaced both the high low switch and the reverse switch.
I found them at this website http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
hope this helps
Posted on May 02, 2009
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Posted on Nov 13, 2008
SOURCE:
Do both wheels turn in second gear on john deere gator?
yes both wheels should turn in all 3 gears, high low reverse
Jun 08, 2014 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator only goes in low speed
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter
Jul 02, 2012 | Peg Perego John Deere Gator HPX Ride on...
My sons gator lost reverse, but still had forward 2 gears, then stopped working all together. I fully charged battery and still nothing. It will honk the horn, but wont move forward
horn runs off of a seperate power supply, check the battery nad charger with a multimeter and make sure that its putting out at least 12 volts
Jun 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Both wheels will not move in high gear, only one wheel will spin, they both work in reverse and low gear
It sounds like you need to replace the peg perego switch assembly for the gator, I upgraded my shifter and it works great now, but I also found the additional switches at http://www.mypegperegoparts.com/
Jun 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Gator will only drive in reverse
I would replace the reverse switch as seen in here http://www.shopjandl.com/mepu0003.html and also the high low switch for this peg perego gator.
Sometimes the high/low switch will cause it to not go in reverse, so I would replace both switches in the shifter just to make sure.
They are really easy to replace. You can call these guys http://www.shopjandl.com/.
They know what they are talking about because they sell and repair them.
Mar 28, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg perego gator wont work in forward but works in reverse
I would replace the high low switch for this peg perego gator.
The high low switch as seen here http://www.shopjandl.com/mepu0002.html will not allow it to go forward. The reverse switch will sometimes not work at all as well.
You can contact http://www.shopjandl.com/. They repair them and know how to figure out what is wrong.
I would also check the wiring on the motors. Sometimes the wiring comes loose and doesn't allow all the speeds to function properly.
hope this helps
Mar 24, 2009 | Peg Perego John Deere Gator HPX Ride on...
PEG PEREGO JOHN DEERE GATOR
Problem #1:If you have taken the high speed safety device off the stick shift(small red plastic block screwed on below the yellow stick shift housing) then your high/low speed switch has gone out. There are two motors(one on each back wheel) that both have to come on when in high speed. Only one comes on for low speed. It is the switch under shifter that is not spring loaded. hi/lo switch #MEPU0002 available at www.tigerimports.net for $11.00 plus $2.00shipping That is where I got mine.
Problem #2: Sounds like you need hi/lo switch and possibly forward/reverse switch too. Before buying forward/reverse switch try putting a little grease on the white plastic assembly that engages the forward/reverse switch between the top piece and the piece that pushes down on top of the switch. Sometimes they just stick enough to stop switch from depressing. It is the switch under shifter that is spring loaded.Forward/reverse switch #MEPU0003 $11.00 plus $2.00 shipping @tigerimports.net
Jul 19, 2008 | Toys
Open Questions:
Toys Logo
1,077 people viewed this question
Top Toys Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
