Question about Motorola Mobility RAZR V3i Cellular Phone
Unable to hear ring tone
When i make a call ,i cannot hear the ring tone but when i switch on the speaker i can hear.When i receive a call,i answer but i cannot hear anything and when i switch on speaker i can hear
  • drsujathaav Aug 11, 2008
    ear piece not working
Turn up the volume with the ringtone volume controler while on a call
Posted on Aug 11, 2008
How can I get the telephone on my Brother Fax T96 to work?
Step by step information at the link below.
Brother Fax T96
The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
If your fax machine hears these tones, it will receive the fax.
If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
(If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
  • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
  • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
  • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
  • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
    To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
  • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
Mar 28, 2011 | Office Equipment & Supplies
I have a Model MF 4150 , Serial No. JVM 73593 The Basic Guide that came with the purchase does not provide the necessary information. I have a phone on the same line as the fax machine (plugged into...
I'm going out on a limb here, and guessing it's a Canon imageClass MF4150... If not, please disregard this solution.
The advanced manual can be viewed / downloaded / printed here, directly from Canon:
http://gdlp01.c-wss.com/gds/0900006459/imageCLASS_MF4150_Advanced_Guide_EN.pdf
To stop it from interfering with the telephone conversation:
Issue: Fax interrupts telephone conversations in answering machine mode (AnsMode)
Solution: Setting the Receive Mode - ICMF 4150
  1. Press <Additional Functions>.
  2. Use <la.gif> or <ra.gif> to select [5 FAX SETTINGS], then press <OK>.
  3. Use <la.gif> or <ra.gif> to select [3 RX SETTINGS], then press <OK>.
  4. Use <la.gif> or <ra.gif> to select [3 RX MODE], then press <OK>.
  5. Use <la.gif> or <ra.gif> to select the desired receive mode, then press <OK>.
    round_note.gif - For [AnsMode], make sure an answering machine is connected to the machine.
    If [AnsMode], [FAX/TEL], or [DRPD] is selected, you can select some settings as below:
    [AnsMode]
    --- [AnsMode CHK TIME] (select time from 10 to 30 seconds for the answering machine to start playing outgoing message after receiving a call)
    --- [FAX DETECT TIME] (select the duration from 10 to 70 seconds for the fax to detect)
    [FAX/TEL]
    --- [RING START TIME] (select the time from 0 to 30 seconds for the phone to start ringing after receiving a call)
    --- [F/T RING TIME] (select the duration of ringing from 10 to 45 seconds)
    --- [F/T SWITCH ACTION] (select the action the machine will take after the ringing ends, Receive or Disconnect)
    [DRPD]
    --- [NORMAL RING]
    --- [DOUBLE RING]
    --- [SHORT-SHORT-LONG]
    --- [SHORT-LONG-SHORT]
    --- [OTHER RING TYPE]
  6. Press <Stop/Reset> to return to the standby display.
Apr 25, 2008 | Office Equipment & Supplies
The phone rings,states the number calling but you can't talk to the caller. When you answer the phone, the person on the other end can hear you, but you can't hear anything. You can't get a dial tone when...
The switch that the handpiece activates is not working. Could be optical, magnetic or physical. It may need cleaning, adjusting or a wire connection repaired. Also check the curly cord and its connections between the handpiece and telephone.
Nov 17, 2009 | Sakar Talking Caller-ID Speaker Phone
Can send faxes, but no fax tome coming on when the number is called
that's right,you would be able to send fax,but wont be able to hear the fax tone,your fax ring shoud be 2 rings higher than answering machine,or else,do 1 thing when you hear the ring,just pick up the receiver u wud be able to hear the fax tone,do not disconnect the call,just keep the receiver aside without disconnecting,and then press start fax...you will be able to receive fax...........
Aug 25, 2009 | HP Hewlett Packard Officejet Pro L7680...
Nokia N72 mobile phone, am unable to hear dial tone when dialling and unable to hear incoming call answering a call and unable to from them when I make outgoing calls.
increase the volumes of ring tones ,unscrew the phone to check if the ringer is not faulty or damaged,repair or replace it ok
Jul 11, 2009 | Nokia Cell Phones
Problems sending and receiving faxes.
  1. Open Lexmak Productiviti studio - 5600 - 6000 Series ( icon on Desktop)
  2. Open Setup and manage faxes link ( left bottom corner)
  3. On Ringing and Answering card look at the Manual Answer Code ( if some nuber inside delete it, it should be blank)
  4. On Dialing and sending card look at the Dial method (if you have a tone phone select Touch - tone, and if you have pulse phone select Pulse)
The diference betwen Touche Tone and Pulse is that Tone when you press nuber hear tone (like on cell phone), and Pulse when you dial nuber hear serie of short pulses (like when you dial nuber 5 you hear 5 short pulses like tttttt)
Mar 24, 2009 | Lexmark X5650 All-in-One InkJet Printer
Can not recieve fax. currently just hooked to phone line
Receive a fax
Depending on the Auto Answer setting, your HP All-in-One can receive faxes
automatically or manually. If you have set the Auto Answer option to Off, you will
need to receive faxes manually. If the Auto Answer option is set to On (the default
setting), your HP All-in-One will automatically answer incoming calls and receive faxes
after the number of rings specified by the Rings to Answer setting. (The default
Rings to Answer setting is five rings.)
Receive a fax manually
If you set up your HP All-in-One to receive faxes manually (the Auto Answer option is
set to Off) or you answer the phone and hear fax tones,
1. Make sure the HP All-in-One is turned on and you have paper loaded in the input
tray.
2. Remove any originals from the document feeder tray.
3. If you are currently on the phone with the sender, instruct the sender to press
Start on their fax machine.
4. When you hear fax tones from a sending fax machine, do the following:
a. Press Fax on the control panel of your HP All-in-One.
b. When prompted, press 2 to select Receive fax.
c. After the HP All-in-One begins to receive the fax, you can hang up the phone.
Jan 14, 2009 | HP Officejet 5610 All-In-One InkJet...
Can't hear ring tones. Vibrator works fine
turn of the vibrator mode
set on restore mobile settings and try
Jan 11, 2008 | Motorola Mobility V557 Cellular Phone
Unable to make or receive phonecalls
Your phone is barred. This means it has been blocked of making or receiving any calls.
Aug 18, 2007 | O2 Xda Orbit Smartphone
Motorola Mobility RAZR V3i Cellular Phone Logo
275 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
