Question about ASUS P5S800-VM Motherboard
Vga My pc is working good but i decided to add some memory on it. The problem is i accidentaly placed a wrong memory card on my pc's memory slot with another memory card in it. when i boot it on, the pc just couldn't open. i took out the wrong memory but it wont open the same. Help me with this pls...thanks
  • 107 Answers
You could try new memory but chances are you killed you mobo
Posted on Dec 08, 2008
  • 162 Answers
Sounds like you could have fried something, I'd say if pulling memory all out and putting memory back in doesn't solve the issue you should go into hock and buy a new computer.
Posted on Aug 12, 2008
I have an. Hp p3017f3 it has black screen.
p3017f3?????????? what is that, a PSU #?
this HP has both a name and model number clearly stated on the service tag, use that or all answer will be wrong
the model we can work with.
the card smacks of Desktop but MY LAPTOP has one too an
elitebook LT has Video GPU card that comes out.
ILL run with desktop for now (a coin toss that)
PC's made for 36 years, now.
modern DT, PC have PCI-e slot the old PC's and AGP slots.
they can not be mixed, ever.
my wild guess, is pc is black screened,
the motor tests good.
so PC side is bad, and someone told you its a VIDEO card.
so what card is there now? it has name and number too.
if non, and is on board, VGA and its bad.
then yes add a new card, to PCI, slot.
but you never told the model of this PC./
AH you meant say, the MOBO has no VGA card
but does have rear edge MOBO VGA jack sure. (called onboard)
so you want to add one,,, sure.
we are not HP so cant help much.
but the real HP site has service page.
in fact HP will nag for this, until you tell it, 10,000 pc made at HP
https://support.hp.com/us-en/
this is the service tag.
the model is there. MODEL:xxxxxxxxxxx (what is XXXXXXXX)
hp tag-dt-2rdc5vtozdvuqbxau1bo5hq1-1-0.jpg what facts like this parts are easy to buy find and install.
in all cases.(no pun)
Aug 07, 2017 | HP Computers & Internet
I have a Gigabyte GA-K8VM800M Motherboard with 2gb ram. I want to disable the onboard graphics card and add another VGA card. Which card should I go for?? Will adding VGA card, show physical memory as 2gb...
Hello you can download the manual, and drivers here:
http://www.gigabyte.com/products/product-page.aspx?pid=1810#manual
You can add a graphic card 1 x AGP slot (8x/4x-AGP 3.0 compliant), supports 1.5v display card only.
And Max capacity: Up to 2GB DDR400 RAM by 2 DIMM slots.
ATI/AMD makes very good graphic cards.
Adding a graphic card on the mainboard will not slow the physical memory. It has it`s own ram.
Good luck
Jun 18, 2012 | Gigabyte GA-K8VM800M Motherboard
Can not make my pc work with dual monitor, one with the DVI and the other one VGA. My PC is a Dell Dimension 4700
You are right,you can not make that work.You need either dvi or vga,on both monitors.You can not mix them,sorry.Check for an empty pci or pcie slot and add another video card.
Aug 24, 2011 | Dell Dimension 4700 PC Desktop
1. I use on board vga before, now I got External vga card so that the Ram can work for window completely without sharing it, but still the same thing What can I do?1. I use on board vga before, now I got...
Your computer will use the shared memory for the VGA unless you disable or lower it.
Memory Upgrade for Acer Aspire E500 Series Computer, the Acer Aspire E500 Series Computer takes the PC2-3200 DDR2 SDRAM DIMMs,400.
You need to match this memory. The computer may not see the DDR2,533 DIMM
Jul 07, 2011 | Acer Aspire E500 PC Desktop
LG Flatron 1717S, sits in standby mode, screen black, green power light flashing, wont come on. Sometimes works as normal.and there is no LG customer care in place where I live.....pls help me
Take off the VGA cable from the Graphic card (on PC), do you see anything displayed? Something like SELF DIAGNOSTIC. If yes, there is something wrong with your Graphic Card. Open the case, check the connection to the slot, re-seating and clean it if necessary, do the same thing with the memory card.
Let's see the result n good luck
Apr 11, 2010 | Computers & Internet
MEMORY/RAM problem, system won't acknowledge both slots of memory
You might have on-board VGA card which take 8 Mb (shared) in memory taken from extended memory card.
My suggestion, use exactly similar memory card ( same PC clock, either 400/533/667/etc. If this won't work, try to clean the memory slots with brush.
Apr 10, 2010 | Computers & Internet
Beeping sound at boot up, screen showing auto save and not booting up
remove the memory chip, clean it, insert it back in the slot again. "be carefull" dont wrongly place the memory chip else it will burn, there r two clips on each end of the slot, and in the middle a separator. hope this will help. if u have a graphic card in it remove it, clean it, and insert it back on the slot. if doesnt work then replace the memory chip or graphic card. now if u have two or three memory chips in the slot, then test one by one. remove all, then place one, then turn on pc see if the display come, by this way u will know if the chips are good or not, then try the others.
Aug 09, 2009 | Dell Inspiron 530s Desktop Computer...
I can't video cards that fit within the confines of my computer housing
Good morning! please try to check with your acer aspire x1200 supplier if they have a bigger case that will replace the 4 inches wide case, in order to install a new VGA card. best regards
May 03, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Memory stick reader
It sounds like to me that either the slot is damaged, dirty or you may have the wrong kind of media for that slot. If you have a can of dust off (compressed air) you may want to blow out the dust in the slot. After doing this, try your memory stick again. If it still doesn't work but it has in the past for that slot you may want to consider replacing the card reader. Sometimes the pins get dislodged or bent inside. Good luck, let me know how it turns out. Thanks...
Dec 19, 2008 | E-Machines eMachines Desktop PC
Expandable Memory
If music won't load onto Micro Sd card:
1) go to settings
2) go to USB mode
3)change to MSC format
Now you're good to go.
Nov 03, 2007 | SanDisk Sansa e250 MP3 Player
ASUS P5S800-VM Motherboard Logo
209 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
